Welke SVS Subwoofer: (2x) PB12-NSD of PB12-Plus?
Started by bjaytee, July 26, 2013, 16:23:46
de plus
Subwoofer Specs:
Cabinet Dimensions: 21.5" (H) x 19.75" (W) x 25.2"(D)
Overall Dimensions: 22" (H) x 19.75" (W) x 28.3"(D) (includes feet, grille, amplifier)
Weight (unboxed): 127 pounds
Shipped Dimensions: 33" (H) x 25" (W) x 40"(D)
Shipped Weight: 168 pounds
Rigid and braced Medium Density Fiberboard (MDF) cabinet
Black gloss or full veneer black oak finish
Front-firing driver
Front-firing triple 3" high-flow flared ports
Dense foam port blockers (3) included
Variable 20 Hz, 16 Hz and Sealed tuning modes
Protective non-resonant steel mesh grille
Driver Specs:
SVS 12" high performance Plus driver
Bifilar wound, 3" diameter, high-power aluminum voice coil
Polyimide impregnated fiberglass former/bobbin
Single, composite layered, linear roll long-throw spider
Integrated tinsel leads
Nickel-plated high-tension spring terminals
Proprietary injection molded gasket and parabolic SBR surround
Composite pulp/fiberglass press layered cone with stitched surround
Low carbon 1008 steel components, electrophoresis black plating
Finite Element Analysis (FEA)-optimized motor structure
Copper shorting sleeve reduces gap induction and distortion, and enhances thermal conductivity
Dual Genox 8H/Y-35 high grade ferrite magnets
Oversized pole vent for greater cooling and low noise
Amp Specs:
STA-800D Sledge with 800 watts RMS continuous power (2300 watts peak dynamic power)
High efficiency cool-running Class D switching topology
Detachable power cord with main power switch and ceramic fuse
RoHS compliant, lead-free construction and world-wide safety certifications
Auto-On / On switch with "green" standby mode
Stereo line-level RCA and balanced (XLR) input/output connections
Normal and Hi input voltage switch
Customized EQ and DSP limiter settings specifically for the PB12-Plus
Variable tuning with 20Hz, 16Hz, and Sealed settings to match subwoofer port settings
Fully adjustable (frequency and slope) phase-correct speaker/sub digital crossover
Intelligent Feature Control (IFC) with bright LCD display
Digital PEQ with adjustable frequency, cut/boost, and Q values
Room gain compensation control with adjustable frequency and slope
de 13
Cabinet Dimensions: 17.4" (H) x 17.4" (W) x 17.4"(D)
Overall Dimensions: 17.9" (H) x 17.4" (W) x 20.4"(D) (includes feet, grille, amplifier)
Weight (unboxed): 92 pounds
Shipped Dimensions: 23" (H) x 23" (W) x 27"(D)
Shipped Weight: 105 pounds
Rigid and braced MDF cabinet
Piano gloss black and real black oak veneer finish options
Front-firing driver
Driver Specs:
SVS 13.5" high-performance Ultra driver optimized for sealed applications
SVS custom-tooled die-cast aluminum basket
Flat-wire, 3" diameter, high-power, high-temp, 8-layer, aluminum voice coil - unique to SB13-Ultra
Dual 9", composite layered, linear roll, extreme excursion spiders
Proprietary injection molded gasket and parabolic SBR extreme-excursion surround
FEA-optimized overhung motor structure with custom gap extension plate enhances force/displacement symmetry, lower distortion and increases linear stroke
Amp Specs:
STA-1000D Sledge with 1000 watts RMS continuous power (3600 watts peak dynamic power)
Stereo line-level RCA and balanced (XLR) I/O connections
Customized EQ and DSP limiter settings specifically for the SB13-Ultra
Two (2) digital PEQs with adjustable frequency, cut/boost, and Q values
Adjustable digital delay on main speaker line-level outputs to time-align the speakers and subs
#26
ik zou voor de Plus gaan
Raymond187
Flavio
Denon AVC-X3800H | Behringer NX4-6000 | Buttkicker BKA1000-N
2x T+A TCI 2A | 2x Klipsch R-115SW | 2x T+A TLS 20 | 1x T+A TCI C2 | 2x T+A TAL 90 | 2x Teufel M 950 D | 2x T+A TAL X1
bjaytee
Duidelijk :).
Na al die raving reviews over de SB13-Ultra begon ik te twijfelen, vandaar.
Denon AVR 2313 - B&W 7NT - JVC HD 550 - PS3 - Xtreamer Prodigy - Panasonic P50VT30 - SVS PB12-Plus DSP
Mario D
Quote from: bjaytee on July 29, 2013, 12:54:18
Duidelijk :).
De SB13 ultra moet zeker niet onder doen voor de PB12+.  ;)
bjaytee
Quote from: kalimero on July 29, 2013, 14:52:20
Juist, jij hebt die, zeker? En je kan vergelijken met heel wat subwoofers als ik het goed heb :)?
Hoe groot is jouw luisterruimte ongeveer?
Mario D
#32
Quote from: bjaytee on July 29, 2013, 15:01:29
Ik heb nu de SB13 ultra inderdaad.  ;)
Deze kan ik inderdaad vergelijken met heel wat subwoofers die hier al in huis zijn geweest :
BK Monolith/Sunfire HRS-12 (X2)/Velodyne SPL1200 ultra
SVS 25-31PC+/20-39PC+/PB12+DSP/PC13 Ultra (1X Bash + 2X Sledge)/PC12 Utra (TC-Sounds driver)
(Daarvoor nog wat ander muk zoals een Yamaha YST-320 JBL 5.1 setje en een bose lifestyle maar dat tel ik niet mee als subwoofers)  :D
Je mag niet vergeten dan een gepoorte sub anders klinkt dan een geloten, dit is smaakgebonden denk ik.
Ik heb de PB12+ ook al in huis gehad en dit was ook een geweldige sub maar voor stereo vond ik hem minder. (toen nog met 12.4 driver)
Mijn luisterruimte is 3.75M x 9M en word goed onder druk gezet, enkel de PC-13 ultra ging nog een stapje verder maar op een andere manier dan de SB13.
De SB13 ga ik hier nooit op zijn maximum krijgen in mijn ruimte en dat is wel fijn om weten natuurlijk.  :thumbs-up:
bjaytee
Quote from: morca on July 29, 2013, 17:13:53
Is het hoofdzakelijk film of muziek?
Hoofdzakelijk film zal het zijn, al wil ik niets "boemerigs/ongecontroleerd" als ik naar muziek luister.
Ik heb ge-chat met SVS en zij raden ook de PB12-Plus aan.
de PC's heb ik echt nooit mooi vinden klinken
bjaytee
#37
Quote from: morca on July 29, 2013, 17:33:46
Ik denk dat de PC 13 met muziek wel een stukje beter/strakker zal spelen.
Maar dat kan Kalimero of RA je beter vertellen denk ik.
Je bedoelt waarschijnlijk de sb13?
bjaytee
Hopelijk lees je dit, kalimero  :).
Waar zie jij het verschil tussen de pb12-plus en de sb13-ultra?
De SB13-Ultra zal imo strakker met muziek klinken,
de PB12-PLUS is een beest voor film.
Bij de  PB12-PLUS zal je output in het laag harder gaan/overweldiging klinken bij film
De SB13-Ultra zal iets minder geweld geven,en dan met meer detail vooral bij muziek.
Anders zou je beide eerst eens moeten horen.
Kan je voorjezelf goed afwegen wat je mooier vind.
Remco
Tja dat is inderdaad een lastige, maar ik denk toch dat de 12 plus voor films meer brengt. Ik denk dat de gesloten strakker zal spelen, maar de 12 meer spektakel brengt. Het is maar wat je voorkeur heeft.
Luidsprekers 5.2.4 : Ascendo The6-P CM | Cabasse Eole-4 | Dual JL Audio E-112 |
Nou kan je verzekeren dat de Plus in mijn studio als aanvulling op m'n K&H's O300's z'n werk ook ERG goed en muzikaal doet.
yorkie13
Mario D
Quote from: bjaytee on July 29, 2013, 18:37:09
Een gesloten sub klinkt voor mij inderdaad juister (vooral in stereo)
kwa output (DB) ontlopen ze elkaar niet zo veel maar ze hebben beide een andere sound.
Beide zijn geweldige subwoofers dus je keuze zal enkel nog smaakgebonden zijn.  ;)
bjaytee
Dennis75
Gefeliciteerd! Laat wel nog ff weten hoe hij bevalt.
Mario D
