Yadis
Gestart door skank1, juni 5, 2011, 21:22:35
skank1
Laatste versie: 2.2
Hier:
http://www.mediafire.com/?6i66avohuqw3dmw
Hoogtijd dat Yadis hier een eigen topic krijgt, waar alles gecentreerd is lijkt me :)
Nu staat het wat overal en nergens..
Bij deze geopend  ;D
From version 2.1, make sure your Dune has the latest beta firmware installed.
Don't forget to make a backup of your "workspace" folder before any update !
In order to get yaDIS 2 running on your PC, there is only one pre-requisite: Microsoft .Net Framework 4
Setting up yaDIS 2.0 (by dbone1026)
German User Manual 1.1 (by XAlien)
Change log:
2.2
   - Added the management of selections of movies (groups)
   - Added the ability to add shortcuts to selections of movies (main menu or
     movies submenu)
   - Added 2 new filters for the media list: Sagas and Selections
   - Added the option to invert the current filter for the media list
   - Added the detection of DTS-HD MA and HRA (instead of only DTS-HD)
   - Added the ability to reload only technical information of a media
   - Template engine additions:
      - Added the possibility to define the size and position of the
        poster within the frame
      - Images can now be used (in addition of texts) for video
        resolution, aspect ratio and framerate/frequency
      - Ability to display in the synopsis the saga a movie belongs to
   - Added support for tv show posters in addition to banners
   - Added quality option for jpeg synopsis
   - Added the update of episode thumbnails if they were not available at the
     previous processing
   - Added the indication of the number of seasons/episodes for a tv show (in
     the status bar)
   - Added the prefill of the search field when changing the title of a media
   - Added posters in the list of results when changing the title of a tv show
   - Fixed program crash when using right mouse button on a empty media list
   - Fixed cleaning of the interface when switching from one image format to
     another
Om de roadmap en stand van zaken te bekijken:
http://yadis.whisperingvault.net/projects/yadis/roadmap
treky22
Yadis heb ik ook op mijn Dune Base 3.0 draaien.
Werkt perfect, en ziet er mooi uit  :thumbs-up:
skank1
De komende ziet er toch net weer gelikter uit :)
B.J.
Ik wacht al een tijdje op 2.1. Ik wil namelijk dat de opslag van de data weer gaat als bij 1.0
treky22
Citaat van: skank1 op juni  6, 2011, 12:52:24
Wanneer gaat die uitkomen dan ?
skank1
Citaat van: treky22 op juni  6, 2011, 12:56:31
deze maand?
de skin hier downloaden http://www.mediafire.com/?kc1cxe41djqekjl
het zip bestand zet je ergens op je usb stick, en gewoon op de file klikken via je dune en done ;)
treky22
Citaat van: skank1 op juni  6, 2011, 12:57:56
Krijg em niet gedownload.
Kun je em via email sturen ?
PM
Denon Focal
Ik wil graag Yadis op mijn Dune zetten. Ik heb geen HD in de Dune en speel alles van een Nas.
Kan ik dan toch Yadis draaien en doet ie wat met mijn bestanden en structuur op mijn NAS?
treky22
Citaat van: Denon Focal op juni  6, 2011, 19:51:41
Yadis draait vanaf mijn usb-stick die in de Dune zit (aan de achterzijde).
Met mijn bestanden op de PC doet ie verder niks. Yadis zet er verder ook niks bij.
Dit zet ie allemaal op m'n usb-stick.
Met een NAS heb ik nog geen ervaring, maar lijkt me dat ie ook daar niks bijzet bij de bestanden op je NAS.
Denon Focal
tnx, ik heb een 4gb hdsd card erin zitten dus dat moet wel lukken denk ik
skank1
Citaat van: treky22 op juni  6, 2011, 20:02:41
Klopt, gewoon yadis op je NAS zetten, in een eigen map, en klaar ben je :)
skank1
Citaat van: treky22 op juni  6, 2011, 17:02:55
PM
mail
treky22
B.J.
Ik draai Yadis op de pc, de benodigde bestanden plaatst Yadis automatisch op de NAS, met de dune doet hij juist niks.
skank1
Citaat van: Bas Janssen op juni  7, 2011, 09:02:28
Beetje vervelend zo niet?
Dan moet je NAS (waar je films op staan?) altijd aanstaan, je pc moet ook altijd aanstaan (vermits yadis daar op staat zeg je) en dan nog eens je dune.
Als je yadis ook op je nas zet, dan hoeft je pc niet aan te staan...
B.J.
Citaat van: skank1 op juni  7, 2011, 09:04:19
Na de download van een aantal films draai ik Yadis op mijn PC en die maakt alle icoontjes en texten en plaatst die in de film folder op de NAS. Bij het kijken van een film staat NAS+Dune alleen aan.
Ik kan Yadis vast ook op de NAS of dune zetten maar heb daar nog niet meer geƫxperimenteerd. Ik gebruik ook nog 1.0 beta
skank1
Citaat van: Bas Janssen op juni  7, 2011, 09:50:21
Dus yadis staat op je NAS en niet op je pc :)
Het programma zelf staat uiteraard op je pc...
Beetje misverstand :)
B.J.
Citaat van: skank1 op juni  7, 2011, 10:07:01
Ja  ;D
skank1
Mooie nieuwe feature:
In the next version, you will be able to manage a selection of movies. This selection of movies will be available on the Dune as a new movie category (besides 'All movies', 'Recently added', 'Genres', ...).
So, on the PC, you will manage unwatched movies by selecting them in yaDIS. Each time you need to change this selection, start yaDIS, select/unselect movies and export.
This category is named "Selection" to allow everyone to choose the purpose of it (new movies, unwatched movies, favorites, ...).
skank1
2.1 is at 100%
Verwacht dus ieder moment een link :)
treky22
Citaat van: skank1 op juni 13, 2011, 08:27:56
2.1 is at 100%
Cool, laat maar komen  :clapping:
clockwork
Wat zijn eigenlijk de oordelen van Yadis t.o.v. Zappiti? Ik heb er nu Zappiti op staan.
Kun je bij Yadis die moviewall aanpassen zoat de covers groter worden?
Ze zijn hier nauwelijks te lezen. En ik zelf vind dit wel een goede aanleiding om een 60" te kopen, maar mijn betere helft is hier nog niet van overtuigd.  ;D
Nordost/ Shunyata bekabeling
frankp
Ik heb in het begin beide programma's gebruikt, maar ben nu volledig over op Yadis.
Vooral als je de moviewall naar persoonlijke voorkeuren wil aanpassen dan is Yadis echt de betere.
Dus ja, je kan in Yadis de afmetingen van de covers aanpassen, alsmede het aantal kolommen, rijen, achtergronden, enz enz.
clockwork
Citaat van: frankp op juni 16, 2011, 13:27:25
Oke. Duidelijk. Zodra de nieuwe versie van Yadis uit is ga ik deze installeren. Thanks.
WilcoD
Sinds vandaag heb ik een Dune smart D1 en daar wil ik natuurlijk ook Yadis op draaien maar ik stuit op een klein probleempje waar ik niet uit kom.
Ik heb nu slechts 1 dvd op de harde schijf staan en ben bezig met Yadis en dat lukt tot nu toe prima alleen als ik daadwerkelijk de film wil gaan kijken en druk op enter van de afstandsbediening of op play krijg ik de volgende melding.
"Openen van URL is mislukt"
Waar ligt dit aan  :sadlike:
Het gaat in dit geval om een VIDEO_TS
Alvast bedankt voor de hulp.
