Classé onthult nieuwe pré/pro SSP-800
Gestart door Shorty, mei 22, 2008, 10:38:11
Shorty
CiteerClassé Introduces New Reference Preamp/Processor, the SSP-800
[...]The SSP-800 is a ten-channel preamp/processor, offering both balanced and single-ended connections for all channels. Audio Digital Signal Processing (DSP) is handled by a Texas Instruments-based platform, which operates in 64-bit double precision. It uses floating point arithmetic for all audio signal calculations to ensure the most accurate results possible.
All bass management filters, level adjustments and parametric filters also benefit from the added precision. To ensure the SSP-800 retains its value and competitive edge, the Classé Design Team has designed the DSP onto a replaceable module to accommodate a planned future upgrade.
Superior audio performance is achieved by combining powerful DSP with balanced topologies, advanced component parts and meticulous circuit layout. A dedicated linear power supply using a low-noise toroidal transformer powers the analog audio circuits. Digital and control circuits are powered by their own dual-output, low-noise, high-current switching supply.
High quality digital-to-analog converters and output stage components are configured to ensure exceptional dynamic range and resolution. Audio circuits are isolated from video and control circuits by optocouplers and low voltage differential signal (LVDS) pathways. Digital and analog circuits and grounds are isolated from each other among and within circuit boards.
Throughout the SSP-800 there are examples of HD technology executed at the highest quality level. It is the combination of advanced technology and genuine quality sets the SSP-800 apart. And while technology and quality give the SSP-800 its intrinsic value, we measure its true worth first on the test bench and then in the sound room.
Music First
Music listening remains the most reliable method of judging sound quality. In fact, no surround processor can accurately reproduce movie sound if it fails to reproduce music properly. At Classé, our first priority is developing components that perform exceptionally well with music. We then turn our attention to processor decoding capabilities and developing features that enhance flexibility and in-room performance.
With musical performance as its benchmark, the SSP-800 was conceived as a high-performance multichannel preamplifier. For two-channel listening both balanced and single-ended analog sources may bypass all analog-to-digital, DSP and digital-to-analog stages. Alternatively, the full range of processing capabilities including bass management and parametric equalization is available for both analog and digital sources.
The SSP-800 changes the game by doing what no preamp/processor has done before: it performs as well with music as a dedicated stereo DAC and preamplifier. The secret of its breathtaking performance lies not in some new parts or special features, although it has many. What sets the SSP-800 apart is the depth of experience never before brought to bear on a multichannel design.
Analog to Digital
Modern source components are increasingly optimized for use with digital interconnections and the SSP-800 capitalizes on this trend. Older surround processors are typically equipped with a vast array of analog inputs. These have been minimized in the SSP-800 and largely replaced by digital connectors. Four HDMI 1.3a (High Definition Multimedia Interface) inputs for audio/video sources are supplemented by standard SPDIF (coax) and EIAJ (optical) digital inputs for audio.
HDMI is the connection standard adopted for high definition A/V sources. An HDMI cable may carry 1080p HD video signals and uncompressed multichannel LPCM digital audio as well as the latest HD audio codecs (Dolby TrueHD and DTS-HD Master Audio) and certain control signals. Several versions of HDMI have been introduced, each surpassing the other in bandwidth and support for additional features. While the hardware used to transmit and receive on HDMI may be labeled by its version number (the SSP-800 uses version 1.3a for all HDMI inputs and outputs), there will be differences among products' actual capabilities.
The SSP-800 uses HDMI 1.3a primarily to support the component's long life in an evolving market. As new sources emerge, the SSP-800 offers the potential for transferring more information into and through its circuitry. For example, the video signal path supports 36-bit Deep Color video, even though Blu-ray Discs are only 24-bit video sources. In general, the bandwidth of components and circuitry in the SSP-800 is sufficient to accommodate all current and proposed next-generation sources.
Touchscreen Control and More
Classé Delta series components were the first A/V products to offer touchscreen control. Since then, touchscreen control has become an integral benefit for other consumer electronics products. Touchscreen control is more reliable and infinitely more flexible than the older style controls using push-buttons with fixed-segment displays.
The SSP-800 is custom installation friendly. It is equipped with bi-directional RS-232 control and status, rear panel IR, front panel IR transmitter/receiver, CAN BUS and DC triggers.
Video sources of all HDTV resolutions including 1080p are available for viewing on the touchscreen. On Screen Display (OSD) messages can be overlaid on all video signals. Older analog video sources are converted to digital and made available on the HDMI outputs. For displays lacking digital video connections, a component video output is available for analog video sources.
Real World Applications
In addition to quality and technology, the SSP-800 has flexibility built in. Its ten-channel design creates the possibility of configuring two channels for additional subwoofers or as mirrors of the front left and right channels for bi-amplifying the front left and right speakers. Alternatively, these two channels may be devoted to delivering audio to a separate room or system, with source selection shared with the main theater and either fixed or variable output.
Five-band parametric equalization is provided for each of the ten channels to help tune the system to its environment. Classé has elected to offer the system EQ as a manual feature. While several automated systems are available on the market, the complexity of room acoustics guarantees that no automatic system can achieve consistent, optimum results. Our experience is that the best results are obtained by combining measurements with human judgment. The filters used in the EQ are rendered accurately by our processor, which uses floating point arithmetic operating in 64-bit double-precision.
Available May 2008.
MSRP - $8,000.00
Bron: AvRev
VrGr,
Bart J.
Marcel_T.
Wild_Willy
...ik ben benieuwd naar de eerste echte reviews en hopelijk snel een head-to-head vergelijk met de Denon AVP-A1HD.
Wild_Willy
Denon AVR-4311
Dune HD Max
B&W N802 front's
B&W N803 rears
QED - Silver Anniversary speakerkabels, HDMI kabels, Sub kabel en Optical kabel
Pioneer KRP-500M
Audiofiel
Citaat van: Wild_Willy op mei 26, 2008, 13:02:45
Ik verwacht dat de Classé daar klankmatig gehakt van zal maken. ;D
Shorty
*Woensdag klankgehaktdag*  :P
VrGr,
Bart J.
Wild_Willy
Citaat van: Audiofiel op mei 26, 2008, 13:07:30
Ik hoop van niet....maar ik ben er wel bang voor ;) :)
Wild_Willy
......ach...de WAF van beide is niet verkeerd
Denon AVR-4311
Dune HD Max
B&W N802 front's
B&W N803 rears
Pioneer KRP-500M
BWzes03
Denk alleen dat de Classe wat vriendelijker is voor de rug..
Verwacht niet dat dat apparaat de 25kg zal overstijgen
Pana TH-42PY70
Geen vergelijk.....
Wat ik wel zou willen zien is een clock variant, waardoor HDMI meer gecontroleerd wordt en jitter flink omlaag gaat.
Bjorn
Wild_Willy
Audiofiel
Citaat van: bmateijsen op mei 26, 2008, 17:55:41
Weet jij meer dan wij?  ::)
Classé heeft hier verder niet over gerept, maar eerdere SSP-modellen hadden meerdere anti-jitter voorzieningen voor audio ingebouwd. Of bedoel je hiermee alleen het video-gedeelte? ;)
Citaat van: Audiofiel op mei 26, 2008, 19:07:02
Dit was meer in zijn algemeenheid. Wanneer je dit zou willen doen, dan moet natuurlijk het signaal vanaf de speler ook eenzelfde configuratie hebben. Tot op heden zijn het alleen de japanners die iets met HDMI audio doen via Blu-Ray.
Dus nee, ik weet niet meer, maar het valt op dat bij ieder technisch rapport over hdmi-audio dat de jitter cijfers weer flink aan de maat zijn.
CiteerClassé heeft hier verder niet over gerept, maar eerdere SSP-modellen hadden meerdere anti-jitter voorzieningen voor audio ingebouwd. Of bedoel je hiermee alleen het video-gedeelte? ;)
Dat geldt ook voor een bedrijf als Lexicon ;). Maar toch als ik stereo beluister via HDMI en via sp-dif bij diverse implementaties van div versterkers, dan klinken stemmen, maar ook strijkers en koperblazers allemaal wat glazig, soms zefls erg hard.
Ook recent in de Hifi-News bij de review van de Audiolab processor met HDMI (die een record vestigt voor jitter via HDMI en dat was  niet positief bedoeld ;D) werd de wens geuit voor een clock.
Audiofiel
Citaat van: bmateijsen op mei 26, 2008, 19:14:46
Nou noem je ook een merk dat weliswaar erg goed is in surround, maar in stereo (qua prijs/kwaliteit) teleurstelt. ;)
Audiofiel
Overigens weet je dat ik het gebruik van een goede (re)clock ten zeerste toejuich! 8)
Citaat van: Audiofiel op mei 26, 2008, 19:56:44
Zeikerd ;D. Allemaal aan de classe zeg ik! ;D.
WickedGame
Mooi apparaat, maar ik vind dat surround apparatuur zo snel onderhevig is aan veroudering in tegenstelling tot stereo apparatuur. Zeker met dit soort bedragen zou ik het zonde vinden om na verloop van tijd te moeten constateren dat er weer nieuwe codecs, bronnen, interfaces zijn.
Maar goed mijn bescheiden mening. Verder wel een pracht apparaat natuurlijk. Waarvan ik zeker weet dat de kwaliteit hoogstaand van is.
Het apparaat waar ik al maanden over roep dat het de mijne gaat worden.
Ik zoek alleen nog een koper die dit apparaat over zeg een jaar te koop aanbied ;D
De stereo kwaliteiten van deze SSP800 zouden naar verluid gelijk zijn aan de top stereo pre van Classe, en die schijnt erg goed te zijn. Als dat waar is hebben we een nieuwe topper naast de TAG DP, Lexicon etc. Maar dan WEL met de nieuwe formaten (al dan niet nu of met een upgrade).
Ben benieuwd. Alhoewel 8000 dollar prijs, heb ik al een 12000 euro prijs in Europa gehoord......
Nahpets
Citaat van: Blue-Eyes op mei 26, 2008, 21:25:07
Dat zijn een heleboel luiers....
Enno  :)
Ik geloof dat mjn AVP-2 dat ooit ook bijna gekost heeft.  :-X
I love everybody!
Some I love to be around,
some I love to avoid,
fikszo
Oei, na mijn onlangs ontvangen CA-3200 en de zojuist bestelde CDP-202 (welke ik na mijn vakantie laat komen eind juni) is dit toch wel het volgende dat bovenaan mijn wensenlijstje staat....
Wat een geld helaas weer, maar wat ongelooflijk mooi.
Ben heel benieuwd naar de verschillen tov de SSP-600..
Aurender N20 I Denafrips Terminator 12th I Dan D'agostino Progression pre I Dan D'agostino Progression S300 I Transparent MusicWave Ultra 5th Gen I Transparent MusicLink Ultra Gen 5 I Kharma DB7-S
papaleo
#17
Audiofiel
#18
De SSP-75 was ook al €11K dus de prijs verbaast mij niets. De Delta serie is zo'n 30% duurder geworden, dus een opvolger van de 75 zou waarschijnlijk dan tegen de €15K gaan kosten. :P
riwi
Kan deze nieuwe SSP800 nu ook de HD codecs TrueHD DTS-HD-HR en DTS-HD-MA decoderen?
Ik neem aan dat multichannel LPCM wel gaat werken.
In het bericht wordt uitgelegd wat de mogelijkheden van hdmi1.3 zijn, maar er staat nergens dat de SSP800 ook al deze zaken zal ondersteunen.
Audiofiel gezien zal het wel dik in orde zijn. Ook de bassmanagement waarover gesproken wordt klinkt veel belovend.
Er wordt daar wel over gesproken. Het is niet zeker of dit initieel gaat gebeuren of naderhand met een upgrade wordt gerealiseerd.
Zie ook het Classe forum.
jaco
Er staat in die aankondiging niets over support van HD audio formaten, of ik kan niet meer lezen.
Is er meer informatie ergens te vinden ?
riwi
#22
Citaat van: avsforum
The DSP will be an upgradeable MDS DAE-7 module which is based on the TI Aureus processor chip. Unlike other DAE kits all of the DSP support architecture and circuitry including power supplies, ADCs and DACs are engineered by Classe'. The DAE-7 will not support the decoding of the high-definition audio codecs like Dolby Digital Plus and TrueHD and DTS-HD HRA and MA but it will support all the standard audio codecs and multi-channel LPCM. HDMI 1.3a is included as is support for Deep Color video.
Classe's supplier of the DSP's could not make a solid commitment to produce a high-definition compatible module in time for the SSP's launch. Later when MDS makes an upgrade available that supports the new codecs Classe' may offer it to their customer's for no extra charge. Classe' is "expecting" something later this year, perhaps in the fall sometime but it's still up in the air.
posting is van januari 2008, dus al een beetje oud.
http://www.avsforum.com/avs-vb/showthread.php?t=980916
Ik verwacht eigenlijk dat de Denon beter uit de bus komt vanwege de gebruikte componenten en dat wil ik onderbouwen door de prijs.
Denon is altijd redelijk met hun prijs betreft tov de gebruikte componenten.
Ze hebben wereldwijd een behoorlijke omzet in hun spullen dus kunnen ze de marge relatief laag houden.
Classe ligt wat betreft omzet van deze pre/pro's een stuk lager en ze houden meestal (zover als ik weet) een veel hogere marge aan (vergelijkbaar met Lexicon).
Dus als beide apparaten een MSRP van resp. $7000 en $8000 hebben (vergelijkbaar dus) verwacht ik dat de Denon relatief betere componenten gebruikt en meer onafhankelijke voedingen. Ik zou dan ook graag de technische specificaties (aantal gebruikte en type DSP's, aantal voedingen, gebruikte DAC"s en ADC's etc.) van de Classe eens willen zien voor vergelijk met de door Denon vrijgegeven specs.
Oftewel ga niet alleen op merknaam af maar kijk ook eens onder de motorkap en naar de eindprestaties.
Gescheiden stereo en HT deel onder de motorkap. Ik weet niet of de Denon dat ook heeft?
Ik geloof absoluut dat de Denon een betere prijs/prestatie verhouding heeft. Op stereogebied lijkt me dat de Classe de Denon wegspeelt (gebaseerd op het feit dat de stereopre deel van de ssp800 gelijk is aan de 700 serie van Classe).
Nog even wat gevonden uit een oud topic:
Citaat van: Blue-Eyes op februari  3, 2008, 20:19:30
Houdt er rekening mee dat alhoewel er voor de Classe SSP800 8000 dollar gevraagd wordt, dit de USA prijs is. De verwachting is dat deze geweldenaar in Europa ongeveer 12000 euro gaat kosten.
Daarnaast is nog niet bekend wanneer hij in Europa uitgebracht gaat worden, maart 2008 is de USA datum.
En als laatste is ook nog niet 100% zeker dat deze PRE de nieuwe audioformaten gaat processen, er wordt gepraat over een softwareupdate tzt. Maar zowel de bevestigingen als de ontkenningen hierover zijn zowel vaag, als speculatief.
Maar HDMI heeft deze machine wel:
Video Output
2 HDMI 1.3a (36-Bit Deep Color Support)
Audio Input Digital
4 HDMI 1.3a (True HDMI repeater. Audio extracted from the inputs and put onto the outputs.)
CODECS: Dolby Digital, Dolby Digital EX, Dolby Pro Logic IIx, dts, dts-ES Matrix, dts-ES Discrete, dts Neo:6 2CH, dts 96 kHz/24 Bit, MCH LPCM 96 kHz/24 Bit, Plus other custom modes similar to those available in the current SSPs. (NO THX Post Processing)
(Potentially: Dolby Digital Plus, Dolby TrueHD, dts-HD HDA and MA)
- Optional +10 dB boost added to each MCH LPCM.
- Trim compensation features available for early DTS music recordings.
- Multiple configurations to level settings and manage bass engaged manually, by input or stream type.
Gescheiden MCH en stereo PRE.... Ze claimen dat deze PRE minimaal gelijkwaardig is aan hun beste stereo PRE uit de delta serie. Misschien verkooppraat, maar wel veelbelovende praat!
Ik ben iig al druk aan het sparen om een 2ehandse aan te kunnen schaffen over een jaar of 3 ;D
