Set van Mario "HQPlayer set-up 🎼👌"
holco
My Showcase
Eversolo T8 streamer / Audio-GD DI-25HE / Audio-GD R8HE mk3 DAC / Audio-GD HE-1 mk3 preamp / Daudio ASP / Hypex Nilai-500 mono's (mid-hoog) / Hypex Nilai-500 mono's (woofers) / Daudio C1 (diy versie) / Rythmik F18 subwoofer / Mundorf Angelique (mid/hoog) /  Sommer Cable Elephant SPM440 (woofers) / Preffair X430 XLR kabels / Curious Evolved USB kabel / Pangea Premier SE mk2 HDMI-i2s kabel / Canare Digital coaxial 75 Ohm BNC kabel / Power regenerator AG1500S / Supra LoRad Power cables.
holco
Maar voor een 18" sub kan het niet veel kleiner inderdaad.
My Showcase
Komt door de servodrive
En hoe klinkt hij.... ;D
Leuk stukje over deze sub:
Finesse meets brute force
Our servo technology is scalable to all subwoofer designs as well as driver size. F18 is our largest single driver sealed subwoofer to meet the needs for a high power home theater solution that retains the dynamic, accurate, and deep bass that we have become known for. Its max output at 20hz is at least 8db higher than that of our 12" sealed model F12 and more than 11db higher than our competitior's 12" model SB** measured by data-bass.com. The amplifier is based on Hypex audiophile class-D module. With the combination of the servo feedback and stiff aluminum cone, we have achieved lower distortion than competitor's 18" servo subwoofers (DD18+) with the same or even higher maximum SPL output from 10hz to 100hz , as tested at data-bass.com. In fact, F18 has recorded the lowest THD numbers at the maximum SPL output than any other subs tested. Our servo technology is scalable to all subwoofer designs as well as driver sizes.
Direct Servo Technology
All our subwoofers use our patented Direct Servo technology. The servo enables precise control over the cone which is essential for tight, dynamic and accurate bass. It also counteracts many different driver non-linearities and allows us to use lighter drivers which avoid the need for excessive amounts of amplifier power.
Some of the benefits of Direct Servo include:
Dramatic boxy sound reduction of the re-radiation of bass from inside the box
Thermal compression are eliminated under normal operation
Higher efficiency allowing output which would normally require a more powerful amplifier
Deep bass extension can be achieved using a low mass driver with superior transient response
Mechanica creepl memory effects are reduced, further improving transient response
The effective Q value is 0.1 resulting in much tighter and accurate bass than conventional designs
holco
Nog niet ingeregeld al lekker, gaat ook errrg diep!!
My Showcase
Roeru117
Oef, mooi hoor. Ik weet uit eigen ervaring wat een E15HP kan en dat is al indrukwekkend. Met de F18 kun je volgens mij echt een huis afbreken. Veel plezier er mee.
NAD M66 - NAD M23 (2x, bridged) - Dynaudio Confidence 20 - Lyngdorf BW-2 (2x) - ROON - Nvidia Shield TV Pro - LG OLED65G1 - Powergrip YG-3 - LHY AS6 - Audioquest - Tellurium Q
holco
De Rythmik F18 nu ook rechtstreeks aan de MiniDSP DDRC-88A en dmv Dirac-Live een 2.1 meting gemaakt, daar mijn favoriete Bruel & Kjaer curve als filter op gezet, Xover op 80Hz LR 24dB/oct, ik wou eigenlijk rond de 30/40Hz gaan zitten maar dan zit de Kick-Bass niet meer in de sub.
Voorlopig ff genieten zo  :headbanging:
My Showcase
holco
Die F18 is echt Out of this World!!
De druk en laag detaillering die deze sub met zo'n gemak weergeeft zijn fenomenaal  :pompom: :pompom: :pompom:
My Showcase
fluissie
#1732
Nice 👌 fijn dat hij je bevalt
Klinkt beter als je Octo dus ...
holco
Thx  ;D
Ja deze presteert zoals verwacht wel een paar treden hoger, de MF van Rythmik is toch wel een dingetje wat niet te onderschatten is  :clapping:
Citaat van: fluissie op augustus  7, 2019, 16:59:11
My Showcase
fluissie
#1734
Zo zie je maar , de ene rythmik is de andere niet  ;D,
Vond die rythmik van Rudi echt zwaar tegen vallen
Fijn te horen
holco
Kan het mij echt niet voorstellen, maargoed bij mij pakt het iig super uit  ;D
Citaat van: fluissie op augustus  7, 2019, 17:13:24
Fijn te horen
My Showcase
holco
AV 9.1 is ondertussen ook ingeregeld, zal niet verassend zijn, ook hier presteert de F18 top!!  :clapping:
Ik zeg, heb je de ruimte en het geld kopen die handel  ;)
Redt je het net niet, is mijn Octo sub zeker een goede 2e  :D
My Showcase
holco
Bedankt Marco 🙂
Ben er helemaal mee in mijn nopjes  :inlove:
Citaat van: morca op augustus  7, 2019, 23:31:02
:clapping:
Veel plezier van je sub.
Echt mooi  :thumbs-up:
My Showcase
AudioEnZo
Dikke sub man, veel luisterplezier Mario  :clapping:
Dirk
en wanneer komt de 2e aan? die volgens de titel nog onderweg is
holco
My Showcase
holco
Hahahaha, zal het aanpassen  ;)
Citaat van: Dynky op augustus  8, 2019, 07:33:22
My Showcase
flakkees
mooie sub hoor
ik speel al wat langer met 18''
overweldigend
veel plezier ermee
:thumbs-up:
katwax
Gratz, het was dus het extra wachten wel waard blijkbaar :)
Veel luisterplezier.
holco
My Showcase
tdbakker
Veel plezier met je monster Sub [emoji1303]
Verstuurd vanaf mijn CMR-W09 met Tapatalk
Stereo:Xanadu HRS22YH//Cambridge Audio Edge NQ en W//Roon.
HT:Anthem MRX520//Rythmik E15//Xanadu Center HRC1 en Xanadu Rears//Sony KD-65AF8//Zidoo Z1000
holco
Thnx jongens  ;D
Broertje wou trouwens op de foto met de sub  8)
My Showcase
Trabuca
Zidoo Z9X 8K | Denon AVC-X3800h | NCore500mp | Kef R3, R2C | Sony 85X95L | JL Audio 12W6 DIY Sub
