Nieuwe holosoftware WAANZINNIG !!!
Gestart door J.A.F._Doorhof, april 4, 2003, 16:08:06
(Apr 4) Version 2.0pre1 Changes:
* Resolution & Refresh Rate automatic switching on NTSC/PAL!
(Accessed via Main Menu -> Resolutions -> Advanced Settings)
* Video Graphic Equalizer for precision control over greyscale & chroma
(For advanced users only, accessed via Setup Menu -> Setup Picture)
* New Menu Added: 'Setup Timings' as fifth menu in Setup Menu
('Setup TImings' can also be accessed via Main Menu -> Resolutions -> Advanced Settings)
* Simplified 'Resolutions' Menu, some settings moved to 'Setup Timings' Menu
* Added Freeze Frame
(Press pause button on remote, or 'A' key on keyboard)
* Ability to reset any setting to factory default
(Press the Mute button on the remote, or Backspace on the keyboard, during the process of adjusting a setting)
* Ability to use mouse to increment/decrement a setting by one step, without a mouse wheel
(Adjustment arrow buttons are now displayed on the slider)
* Ability to use mouse to drag a slider adjustment in both windowed mode and maximized mode.
* Fixed minor Sync Polarity adjustment issue
* Fixed minor window repaint issues
* Menubar title added to top of screen (Main Menu, Setup Menu)
* Improved appearance of crystalline menubar buttons at top of Setup Menu
* Onscreen Display Menus now less likely to cause video to stutter
* Clicking on a greyed-out (disabled) menu item now display a dialog message explaining why it is greyed-out.
* New users are now alerted if the power cable might not be connected to the HOLO3DGRAPH.
* Version now displayed in 'About' dialog.
* Click here for a list of previous changes in v1.6 releases
CiteerInstructions: Automatic Resolution & Refresh For NTSC/PAL
This is pretty straightforward if you are familiar with resolutions and refresh rates. This feature does require PowerStrip to be running in the background, however. You can either go to:
...... Main Menu -> Resolutions -> Advanced Settings
Or go to:
...... Setup Menu -> Setup Timings
Then after configuring resolution and/or refresh rate, you can select these menu items:
...... 'Save Current Mode for NTSC' or
...... 'Save Current Mode for PAL'
In order to memorize the display mode you wish to use for a particular video format. Also, all custom PowerStrip timings settings are also saved, if you made any other custom PowerStrip adjustments too! Also, you can have just resolution-switching or just refresh-rate-switching or you can have both.
Now, whenever the video format changes between NTSC and PAL, the display mode will change after a delay of approximately 2 seconds (to allow video format to stabilize first and be doubly sure that the video format has definitely changed).
Instructions: Video Graphic Equalizer
This is for advanced users only who understand what ISF calibration technicans do. In order to use the graphic equalizer, go to:
...... Setup Menu -> Setup Picture -> Video Graphic Equalizer
You are then presented with a fancy three-graph adjustment interface.
You can use the mouse or keyboard to adjust:
LEFT/RIGHT = Select datapoint in equalizer to adjust
UP/DOWN = Adjust equalizer datapoint
MUTE = Reset equalizer datapoint to factory default
OK/ENTER = Toggle onscreen display (so you can use a greyscale measuring device)
CHANNEL UP/DOWN = Select graph to adjust (Y, Pb or Pr)
MENU = Go back to Setup Menu
You can adjust the Y graph, Pr graph, and Pb graph. Please be noted that the behaviour of the Pr and Pb graphs can be very confusing and adjustment behaviour may change in later beta releases.
Volgens mij maakt dit de H3D uniek in de wereld (als het het al niet was), een videoequalizer is echt een waanzinnig selling point en ideaal voor mensen die geen RGB waarde instellingen kunnen instellen en toch een calibratie willen.
THUMBS UP for Immersive.
Hier kun je de nieuwe driver downloaden.
http://www.immersiveinc.com/holofiles/HOLO3D_v20pre1_Update.zip
MvrGr.
Net even bekeken en het is echt fantastisch.
De switch tussen PAL en NTSC werkt perfect, maar de echte knaller is de videoEQ.
Per kleur, Rood, Groen en Blauw zie je een grafiek die standaard (0) recht loopt.
op 0,10,20,30,40,50,60,70,80,90,100 IRE kun je de veranderingen maken zonder dat de andere waardes meelopen  ;D.
Dit heb ik echt nog nooit gezien...... Perfect.
MvrGr.
Tapeshirt
Met andere woorden, je grayscale kun je nu perfect instellen. Da's wel lekker natuuurlijk!!
Grindtegel
Waar kun je in de holosoftware zien welke versie je hebt?
Ik heb nl. al wel de automatische switch tussen pal en ntsc.
Hoe werkt de videoEQ?
Hi,
Je hebt wel een auto detectie maar GEEN switch.
De software is net 2-3 uur uit.
Je kunt gewoon de nieuwe versie over de oude heen installeren.
Echt ZEER de moeite waard.
Ik zal kijken of ik een screenshot kan maken van de EQ dit weekend.
MvrGr.
Grindtegel
Weer iets nieuws, wat is het verschil tussen de detectie en de switch?
Hi,
Bij de switch kun je nu instellen dat als er PAL gedetecteerd wordt de resolutie naar 1440x1152 @ 50hz springt en bij NTSC naar 1440x960 @ 59,94 hz (of elke andere resolutie en refresh).
Je hoeft dus HELEMAAL niets meer te doen.
MvrGr.
Robbo
@Grindtegel
In jouw versie (1.6p dacht ik) detecteert hij al wel PAL & NTSC.    Maar schakelt alleen van NTSC naar PAL maar niet terug.   Daarnaast kun je nu aangeven welke resolutie aan welk videoformaat hoort.
Grindtegel
Grindtegel
Nou, geinstalleerd en die videoEQ gevonden, nu nog gaan uitproberen...
Helaas heb ik een probleem(pje). Dit had ik al vanaf het begin maar nu wordt het vervelend. Toen Robbo bij me een nieuwe resolutie heeft aangemaakt gooide mijn pc na het toepassen van die resolutie mijn moinitor eruit. Wat bleek, als powerstrip aanstaat kan ik geen beeld meer krijgen op mijn monito alsof iw het signaal niet ontvangt.
Zodra ik powerstrip uitzet werkt het wel op de aangemaakte resolutie.
Holosoftware geeft nu aan bij het instellen van de automatische switch dat dit alleen kan als powerstrip draait...  :P.
Wat te doen?? svp niet te technische antwoorden geven want die begrijp ik niet  :-\
Hi,
Zet aub dat herstelpunt terug dat zou alles moeten oplossen.
MvrGr.
Grindtegel
Je krijgt dan weer de PC terug zoals hij bij ons wegging.
Zet gewoon het herstelpunt van die datum terug of één dag daarna.
MvrGr.
Grindtegel
Ik heb het inmiddels terruggezet naar het begin.
Alles draait nu weer soepeltjes, zelfs op de aangepaste resolutie (1080*720). Happy  ;D
searcher
mm slik  :-[ hier houd het weer even op voor mij.
Moet ik nu deze nieuwe software installeren en hoe?
De Goliath gebruik ik voor mijn Ugo DlP op een 1024*768 resolutie of maakt het bij mij niets uit.
Ik blijf graag van pc's af zal mijn leeftijd wel zijn ;)
        m.v.g Searcher
Aangezien de PAL/NTSC switch niet helemaal van toepassing is voor je DLP kun je met de huidige software blijven draaien.
Anders kun je hem gewoon erover heen installeren.
MvrGr.
Robbo
Beeldinstellingen na schakelen van PAL naar NTSC vv. veranderen volgens een tester blijkbaar niet mee. Mark Rejhon heeft het al opgelost en wordt in release 2.0beta2 uitgebracht (nog niet te downloaden)
Vreemd, bij mij veranderd alles mee.
Maar ik heb alles ook op 0 staan ;D.
Zonder gekheid, ik had mijn brightness op -2.5 staan (voor Regio3) en bij de switch naar PAL zette hij hem netjes op 0.
Wat er wel aan de hand is volgens mij is dat als je met SDI schakelt het beeld niet goed geïnitaliseerd wordt en je even van input moet wisselen.
MvrGr.
Robbo
Ja precies. Als je van input wisselt is het ook opgelost. Of even wachten op 2.0pre2 ;D
Grindtegel
Ik begrijp het niet, zodra ik powerstrip opstart krijg ik geen beeld meer op mijn barco. als powerstrip is uitgeschakeld krijg ik wel beeld.
Wat doe ik nu toch verkeerd??
(Resolutie 1080*720. Refresh 59,94. Hor. + Vert. synch allebei + en composiet staat aangevinkt.)
#21
Hi,
Je had het toch weer werkend na het terug zetten van het herstel punt ?
CiteerIk heb het inmiddels terruggezet naar het begin.
Zet dit punt weer terug en hou in de gaten wat je veranderd.
MvrGr.
Grindtegel
Ja, ik had alles weer teruggezet.
In principe niks veranderd, alleen de resolutie (denk ik ::) )
Grindtegel
Gisteravond weer aan het klooien geweest.
Als ik alles terugzet naar het begin werkt het in principe. Alleen heb ik dan een resolutie van 1024*768. Maar ik wil een resolutie van 1080*720. Dus maak ik die aan in powerstrip.
Bij de 1024*768 zijn de hor. en vert. instellingen negatief en staat composiet uitgevinkt. Bij 1080*720 moet ik hor+ver op positief zetten en composiet aanvinken wil het werken. Maar zodra ik dan met powerstrip opstart valt het beeld weg en geeft de barco aan dat ie geen signaal ontvangt. Ikke niet begrijpe  :'(
Wat ik ook vreemd vind is dat als ik in de holosoftware de resolutie verander ik totaal geen verschil in beeld kan waarnemen. Doe ik nu iets fout? Dat lijkt me ook niet te kloppen.
Hi,
Je Barco moet in ieder geval negatieve sync ontvangen.
In de holosoftware moet je wel eerst op APPLY drukken, anders veranderd er inderdaad niets.
MvrGr.
Snel beantwoorden
Naam:
E-mail:
Verificatie:
