Evolutie van het Goldmund Theatre
Gestart door jan-rotterdam, september 18, 2006, 22:55:12
papaleo
Citaat van: Sol op oktober 17, 2010, 06:58:40
Nee, menig stroomvoorziening wordt daar niet vrolijk van. :D
Nee,maar wel die de stroom levert...... >:D
Sol
jan-rotterdam
Om het even compleet te maken hier de details van de Goldmund - Mimesis 18.4's
Power
o   Nominal power : 200W RMS (2 - 8 Ohms), 120 W RMS (1 - 16 Ohms).
o   Instantaneous power (8 Ohms) : 400 W
o   Maximum instantaneous power : 500 W
o   Maximum voltage swing : 62 V peak.
o   Maximum current swing : 20 A peak.
Frequency Response
o   These figures are valid for the amplifier circuit alone, loaded by 8 Ohms and working at any level between 0 and nominal power.
o   +/- 0.1 dB, 0 - 300 kHz
o   +/- 1 dB, 0 - 800 kHz
o   +/- 3 dB, 0 - 2.5 MHz.
Input Sensitivity
o   Nominal level : 1.45 V RMS.
o   Voltage Gain : 29dB, adjustable by rear panel.
o   Input impedance : 52 kOhms.
Distortion
o   Figures valid for all levels from 0 to 26 V / 8 Ohms :
o   Dynamic : TID < 0.01 % (- 80 dB) unweighted.
o   Static : THD < 0.01 % (- 80 dB) unweighted.
Circuit Speed
o   Slew rate : > 200 V/us.
o   Rise time : < 300 ns.
Noise
o   Signal-to noise ratio : > 115 dB (0.01 Hz - 1 Mhz).
o   Weighted ASA A : > 130dBA.
Operating Temperature
o   Room temperature : -30 to +40 degrees Celsius (-22 to +104 degrees Fahrenheit).
o   Internal temperature : +45 to +65 degrees Celsius (+113 to +149 degrees Fahrenheit).
Power Supply
o   Nominal line voltage : 117, 234 V (switchable).
o   Input voltage range : +/- 10 %.
o   Maximum power consumption : 700 W.
o   Power used in standby : 70 W.
o   4 toroidal transformers
o   3 separated power supplies
Grounding
o   chassis connected to mains earth
Safety Features
o   AC voltage fuse : min 5 A slow-blow for 220 V / 8 A slow-blow for 110 V.
Front Panel Controls
o   power key
o   Red Led display for Over-heating, DC offset or HF protection and Overload.
o   Green Led display for Power on, operating mode (blinking in standby).
o   Yellow Led display for signal connection and digital Lock.
Rear Panel Connectors And Controls
o   Power cord: universal socket 3 lugs.
o   Main fuse (5A slow-blow 220V / 8 A slow-blow 110 V).
o   Green-yellow AC earth binding post.
o   Output speaker 1 x Coaxial for Goldmund Speaker wire in parallel.
o   Analogue Input connector RCA.
o   Input connector XLR for analogue balanced input.
o   Digital Spdif input and output RCA connector.
o   Switch between analog or digital input
o   Switch of right or left channel selection from the Spdif input
o   input attenuator: -9, -6, -3, 0, +3, +6, +9dB
Size and Weight
o   22 cm W x 44 cm D x 17 cm H
o   Weight : 25 Kg
Grindtegel
pas maar op dat je geen inval krijgt wegens verdacht veel stroomverbruik  ;D
jan-rotterdam
Citaat van: Grindtegel op oktober 17, 2010, 13:16:13
De energie rekening valt reuze mee dus zal wel loslopen  ;D
Groeten Jan
WickedGame
Citaat van: jan-rotterdam op oktober 17, 2010, 13:22:04
Groeten Jan
En anders compenseer je het door de warmte die ze leveren. Scheelt weer in je stookkosten  ;D
Geweldig mooie blokken trouwens.
BuSpu
jan-rotterdam
#782
Citaat van: BuSpu op oktober 25, 2010, 21:03:28
Misschien voor erbij ?  ;)
http://www.hifi.nl/tweedehands/tekoop/89665/Goldmund-Super-Dialogue.html
Voor in een 2e luisterruimte, hmmmmm......... Nee toch maar niet, ze zijn erg oud en reserve onderdelen voor deze luidsprekers zijn niet gemakkelijk verkrijgbaar. Klinken wel erg goed moet ik zeggen
Groeten Jan
jan-rotterdam
Zie mijn topic in de Animocheck voor mogelijke verkoop van de Goldmund Mimesis 18.4 mono eindversterkers  8)
http://www.htforum.nl/yabbse/index.php?topic=106726.0
Groeten Jan
jan-rotterdam
De Goldmund Mimesis 18.4 mono eindversterkers zijn verkocht, wat eerder dan verwacht dus nu even een paar weken geduld tot de nieuwe aanwinst komt.
Er komen een paar Goldmund Telos mono eindversterkers voor in de plaats.
Groeten Jan
Audia
Woonkamer: SF Magico S1 | Audia Flight FLS10 | Playback Designs MPS-3 | PS Audio P10 | Transparent MM2 | REL T9X Special Edition RED
diceman
Citaat van: jan-rotterdam op november 26, 2010, 15:13:40
Groeten Jan
Zo mooie maar vooral "zware"  upgrades hier op het forum de laatste tijd.
Gefeliciteerd.
Welke van de serie heb je genomen, de 1000?
jan-rotterdam
#787
Citaat van: Audia op november 26, 2010, 15:36:20
Feli.
Welke Telos gaat er komen?
Als het allemaal gaat zoals verwacht een paar Telos-600's  ::)
Absoluut niet volgens planning maar ik kon ze niet voorbij laten gaan....
Citaat van: diceman op november 26, 2010, 15:41:35
Zwaar klopt wel, 2 * 65 Kg  :P
Groeten Jan
Audia
diceman
Citaat van: jan-rotterdam op november 26, 2010, 20:20:58
Groeten Jan
Dat zijn ook zeer mooi en zware mono blokken.
Dat Goldmund  ziet er zeer gelikt uit zeg.
Als het te mooi is om te laten schieten en je kan het doen waarom niet.
Alvast veel luisterplezier toegewenst.
Audiofiel
Gefeliciteerd! Dat zijn weer hele serieuze upgrades, Jan! 8) :)
jan-rotterdam
Citaat van: Audiofiel op november 27, 2010, 07:01:07
Zal aardig vergelijkbaar zijn met jouw laatste Classe Audio aanwinsten wat eindversterkers betreft  :headbanging:
Groeten Jan
jan-rotterdam
Vanaf vandaag eigenaar van een paar Goldmund - Telos 600 mono eindversterkers die de Kharma - Exquisite Mini's gaan aansturen.
De Goldmund - Telos 400 mono eindversterkers verhuizen morgen naar het audiorack om vanaf daar de surround luidsprekers aan te gaan sturen. Het audiorack moet ik eerst even aanpassen wat beschikbare ruimte tussen de etage's betreft (de Telos 400's zijn net iets hoger dan de recent verkochte Mimesis 18.4's eindversterkers dus het past op dit moment net niet)  ::)
Eerst de rug weer even rust geven van het sjouwen met de Telos 600's  ;D
De details van de Goldmund - Telos 600's
Power
o   Nominal power : 350 W RMS (2 - 8 Ohms), 175 W RMS (1 - 16 Ohms).
o   Instantaneous power (8 Ohms) : > 600 W
o   Maximum instantaneous power : 1000 W
o   Maximum voltage swing : 84 V peak.
o   Maximum current swing : 28 A peak.
Frequency Response
o   These figures are valid for the amplifier circuit alone, at any level between 0 and nominal power.
Input Sensitivity
o   Voltage Gain : 29dB, adjustable input sensitivity on the back panel.
o   Input impedance : 10-52 kOhms.
Distortion
o   Figures valid for all levels from 0 to 40 V / 8 Ohms :
Circuit Speed
Noise
Power Supply
o   Maximum power consumption : 2000 W.
o   Power used in standby : 120 W.
o   8 toroidal transformers
o   4 separated power supplies
Grounding
o   Separated ground and earth.
o   Floating chassis connected to mains earth.
o   Possible link for optionally connecting both.
Safety Features
o   AC voltage fuse : min 10 A slow-blow for 220 V / 16 A slow-blow for 110 V.
o   2 control keys
o   Green Led display for Power on, operating mode.
o   Yellow Led display for AC line connection and digital Lock.
o   Main fuse (10A slow-blow 220V / 16 A slow-blow 110 V).
o   Output speaker 2 x 5 ways post in parallel.
o   Output speaker 2 x Coaxial for Goldmund Speaker wire in parallel.
Weight
o   afmetingen: 33.0 (B) * 47.0 (D) * 27,0 (H)
o   Weight : 65 Kg
Groeten Jan
diceman
Kijk dat zijn leuke kerstkado`s ( ook al zijn ze uit eigen zak weliswaar  ;D )
Veel plezier met het opnieuw beleven van je muziek verzameling.
Kun je nog wel je fototoestel sjouwen? (=hint) 8) Mooie aanwinsten Jan!
jan-rotterdam
#795
Citaat van: Jean Sibelius op december 11, 2010, 10:20:30
Jawel: wat foto's van de nieuwe aanwinsten:
Transport verpakking beide versterkers
1 versterker in z'n stofhoes
Vooraanzicht van een Telos-600 versterker
Voor- / bovenaanzicht van een Telos-600 versterker
Achter aanzicht van een Telos-600 versterker
Naast een luidspreker:
Groeten Jan
jan-rotterdam
#796
En wat foto's van een Telos-600 in vergelijking met een Telos-400  :P
Groeten Jan
wow  :inlove: en als je naar de prijzen kijkt een mindboggling set
LexiconLogan
