Zo kan het dus ook..........Chord media engine
Gestart door Teejoo, september 11, 2005, 23:29:11
Teejoo
En hier gaan we dus uiteindelijk allemaal naartoe:
The Media Engine has the ability to play DVDs and CDs to an incredible standard. It has terabytes of storage, creating capacity for hundreds of films and the biggest of music collections stored totally uncompressed. An entire music and film collection accessible within seconds via on screen displays, creating a virtual library.
KEY BENEFITS
Future-proof and upgradeable
Designed using the most modular architecture possible, we have ensured clear upgrade paths for the next generation of DVD formats.
Protected hot swappable storage
With 2.4 terabytes of hard drive space, the Chord electronics media engine is capable of storing up to 600 hours of film. With the ability to store most movie and music collections, there is still room to add further media engines networked together to provide almost unlimited storage capacity.
Perfect vision
Using some of the best image processing technology available the system gives you the flexibility to adjust the video output to match both the native resolution and refresh rates of your chosen display. The media engine provides powerful images that surpass that of high end DVD players and can also be used as a video scaler for external video sources. DVI-D connectivity ensures that the image stays in the digital domain and retains optimum clarity.
Audiophile Clarity
With 2.4 terabytes of hard drive storage, the Media Engine is capable of creating a virtual library fit for any audiophile. Using studio quality output stages via either single-ended or balanced analogue outputs, the Media Engine has audio clarity found only in the best high end CD players.
Product Specifications:
Media Engine Specifications
Disc Formats supported: DVD ROM & Video (single & dual layer), DVD-R, DVD-RW, CD-R, CD-RW, CD-DA (Audio CD), CD-ROM (Mode 1 & 2), CD-ROM XA, Video CD, Photo CD (single and multi session), CD-EXTRA (CD PLUS), Hybrid CD, CD-Text
Video formats supported: MPEG-2, DivX™, H.264 (MPEG-4 Part 10), VC-1 (WMV-HD)
Digital sound formats supported: DVD soundtracks whether they are mastered in Dolby® Digital (all formats including EX) or mastered in DTS®, DTS-ES™ Extended Surround (DTS 6.1 Matrix and/or DTS 6.1 Discrete)
Screen resolutions supported: Supports standard 4:3 resolutions including 800x600 (SVGA), 1024x768 (XGA), 1600x1200 and widescreen 16:9 resolutions including 856x480, 1280x720, 1280x768 and 1368x768 as well as non standard resolutions up to 2048x1536 including 1080P (1920x1080)
Operating System: Microsoft® Windows XP®
Processor: Intel® Pentium® 4
Hard drive: 6 x 400 GB RAID protected.
Video Outputs: DVI-I x 2, Component, Composite, SVHS.
Audio Outputs: S/PDIF via single RCA. Analogue via balanced XLR and single-ended RCAs.
Zie meer foto's http://www.chordelectronics.co.uk/products_detail.asp?id=41
Jimmy Conway
Spacebass
CitaatEn hier gaan we dus uiteindelijk allemaal naartoe:
Ik niet.
Draiz
IK heb dit al :)
alleen dan zelf opgebouwd.
2.2 terabyte aan hardeschijven (voor lossless audio, HD films en dvd)
Spdif out via externe geluidskaart naar de versterker
DVI (zsm HDMI als die kaarten uitkomen) uit naar projector
Ik hoef dus nooit cd's of zo te wisselen. Alleen video vreet gigabytes, dus er zullen nog wel wt terabytes bijkomen het komenede jaar. Ben binnenkort in Amerika en daar kosten 400 gb schijven 200 dollar. 2 terabyte erbij voor acht honderd euro, count me in :)
Sonus Faber                                           Nord Ost                               Lexicon           Chord           Tag Mclaren       Velodyne
Cremona Auditors + Center       Red Dawn + Super Flatlines  + Tyr            MC12          SPM 1900           CDT20R             DD12
Jimmy Conway
Valt mee dat ze er geen kernreactor bij leveren.  ;D
jowi
Leuke PC.
Afgezien van de hoeveelheid harddiskruimte heb ik dit inderdaad hier eigenlijk ook al staan... en dat van die audio vergelijkbaar met high end... jaja... eerst horen dan geloven. Het blijft een PC.
oud_account_1
Citaat van: Teejoo op september 11, 2005, 23:29:11
<knip >
</knip>
Hmm, ik zie geen 33rpm en geen 45 rpm, dus de mooiste formaten zijn non-supported. ;D
Enne, 2.4TB & 6 * 400GB Raid protected?
Volgens mij kan je met 6 disks van 400GB alleen maar aan 2.4TB komen als je raid 0 gebruikt, en om dat protected te noemen is overdreven (sterker nog, de kans op problemen is groter).
jaco
#7
Citaat van: squadra op september 12, 2005, 00:14:43
En een 400 GB disk heeft netto wellicht 380 GB, dus het is dan 'maar' 1.9 TB
Waar ik meer een probleem in zie is het opslaan van copy protected data op zo'n server. Zal de inustrie dan toestaan ?
Wat ik tevens wel vermakelijk vindt is het volgende:
CitaatSupports standard 4:3 resolutions including 800x600 (SVGA), 1024x768 (XGA), 1600x1200 and widescreen 16:9 resolutions including 856x480, 1280x720, 1280x768 and 1368x768 as well as non standard resolutions up to 2048x1536 including 1080P (1920x1080)
Enige standaard resolutie voor video content is 1280x720. Dan zit er bij de non standaard gelukkig ook nog 1080P,  de rest zijn allemaal PC formaten
Ik ben benieud wat voor prijs Chord voor deze 'PC' durft te vragen.  De gebruikte harddisk rackjes lijk ik te herkennen, kosten maar liefst 12 Euro per stuk bij Alternate.
Dit ding wordt schreeuwend duur, dat mag je van mij aannemen...  :o
Robbo
Maar is (zoals Teejoo zei) al wel een voorbode voor wat komen gaat.  Zoiets icm een EPG gestuurde PVR zal over een tijdje in vele huiskamers gebruikt gaan worden.   Maw een dergelijke opzet (met 1 harddisk weliswaar) is de HDD-recorder van morgen.
jowi
Citaat van: Robbo op september 12, 2005, 09:09:15
Wel eens van MCE gehoord? ;D
Zoals ik al zei, niets nieuws onder de zon. Dit concept staat al bijna een jaar bij mij thuis en is gewoon in de winkel te koop...
gepebril
Leuk apparaatje,
Of we hier naar toe gaan............DRM, HDMI...... laten we zeggen dat Hollywood dit niet
wil. Of ze moeten het net zo doen als bij de Ipod. Stel je voor dat je zo'n apparaat in de toekomst
kraakt, effe 2.2Tbyte aan neue Films, he he he
gr,
Albert
TV: LG OLED65C16LA
Reciever: Marantz SR5015
Speakers: 4x B&W603S3, 1x B&W CC6
Player: Oppo Clone M9201
Robbo
Citaat van: jowi op september 12, 2005, 09:11:16
MCE is leuk voor de tweaker, maar niet voor de gemiddelde consument.
Als je de nieuwe Samsung PVR hebt gezien, zul je begrijpen waarom (en tevens die MCE bak naar buiten keilen ;) )
Audiofiel
jowi
Citaat van: Robbo op september 12, 2005, 09:20:48
Valt wel mee hoor.
Speelt die Samsung PVR ook alle HD/WMV materiaal af? En heeft ie een opslag >1TB ? Stuurt ie uit in 1080i, 720p?
DrAce
Citaat van: Spacebass op september 11, 2005, 23:37:43
Citaat
Ik niet.
ik ook niet.
Dit is meer een extrapolatie van wat er al is.
Ik zie meer in een -liefst nabije- toekomst waar je films niet meer op zulk idioot grote media bewaart maar waar je via een wireless connectie films uitpikt die je wilt zien, tegen geringe vergoeding. Met als tussen stap films op een compactflash oid kaartje. Kan al, alleen moeten die dingen veel goedkoper worden.
Oracle
In feite dus een HTPC.
Ben wel benieuwd of Chord dan ook de voeding, e.d. stevig onder handen heeft genomen, om de invloed van EM-straling, en andere interferenties te onderdrukken. Ze claimen immers 'high-end sound'. Dat krijg je niet zomaar met een PC...
Ben wel nieuwsgierig naar de prijs inderdaad, en toch naar wat concrete gebruikservaringen (opstarttijd e.d...)
Design is kwestie van smaak: da's persoonlijk...
Mark
Citaat van: Mark Lemmens op september 12, 2005, 10:07:59
Chord kennende, hebben ze daar extreem veel aandacht aan besteed. Ze staan bekend om hun zeer goede voedingen...
CitaatDesign is kwestie van smaak: da's persoonlijk...
Ik vind Chord er altijd geweldig uitzien... 8)
Teejoo
#18
Nou, zoals ook boven staat zegt chord dat hij erg goed klinkt. Dat geloof ik ook wel als zij dit zeggen. Ik denk ook niet dat je dit apparaat zomaar met een WMC kunt / mag vergelijken. Op papier wellicht wel, maar in praktijk?
Ik denk toch dat iedereen uiteindelijk een soortgelijk apparaat in huis gaat krijgen. Één netwerk, één serverachtig iets, de rest allemaal hierop aangesloten. Ik ben nu bezig met een nieuw huis en daar komt in elke ruimte UTP te liggen. Ik gebruik nu al Pinnacle showcenter voor muziek, foto's en film in de woonkamer en slaapkamer. Werkt fantastisch, en de kwaliteit is voor deze ruimtes toereikend. Op het moment dat apparaten als de Chord met extreem goede kwaliteit gaan komen, zou ik die in de AV-ruimte plaatsen, en de rest van het huis eraan hangen. Lijkt me namelijk wel gemakkelijk om direct toegang te hebben tot alle nummers die ik heb zonder enig kwaliteitsverschil, ondanks dat ik nu ook geniet van mijn Tag DVD32R.
Oh ja Garmt, ik las ergens dat de prijs iets van 17K (in ponden!!) zou worden.... :o
Ik zie het ook als de toekomst, precies zoals Teejoo beschrijft...
En die prijs, allemachtig...  :o
Oracle
#20
Prijs: €23.000,- (bron:webwereld) tot €26.000,- (bron: engadget).
Eigenlijk absurd veel geld, voor wat in feite een high-end pc in een mooi doosje is...  ;) >:D
Maar ja, Chord is niet goedkoop; daar waren we al achter! ;D
Mark
Draiz
een dual opteron server, 4 gigabyte aan geheugen , een geforce 7800 kaart met hardwarematige HD ondersteuning, en een hele goede liefst externe geluidskaart. Wellicht een iram harddisk, dus geen harddisk maar ddr geheugen als harddisk voor het afspelen. En 40 terabyte aan hardeschijven. Dan loopt de prijs weer een beetje gelijk. Haha
jaco
Als je zoiets als server gebruikt heeft high end er helemaal niets meer mee van doen. Dan light de D/A omzetting om de timing op digitaal gebied bij het playback kastje wat in elke ruimte staat.
Dan zie ik ook meer in een concept met goede server software, en dan een settopbox welke goede kwaliteit D/A conversie/omzetting heeft.
Dan zit je niet vast aan PC hardware van een fabrikant die op dat terein niet thuis is, het dus inkoopt, rebadged en (veel te) duur verkoopt.
Als je overigens met HD begint is 2 terabyte nu ook weer niet zo veel..  Maar als straks de terabyte HD units komen kun je er daar wellicht een aantal van plaatsen en gaat de capaciteit behoorlijk omhoog.
Teejoo
Citaat van: jaco op september 12, 2005, 11:01:45
Ben ik wel met je eens, daarom zou ik de hoofdunit ook in mijn AV-ruimte plaatsen. Daar is de hoogste kwaliteit gewenst. Op de andere plaatsen moeten dan maar mini Chordjes komen. Linn is op dit gebied (multi room) nog altijd erg mooi, ook kwalitatief. Zij hebben dacht ik ook een soort server.
Maar, je kunt je inderdaad afvragen of je voor de overige ruimtes niet gewoon een pc neemt als server, zoals ik nu doe. Het neemt niet weg dat ik het ook als stand alone wel een goed idee vind omdat je veel gevarieerder muziek kunt luisteren zonder cd's te wisselen.
jaco
Citaat van: Teejoo op september 12, 2005, 12:42:08
Hier zijn ook dedicated oplossingen voor. Helaas zijn die niet erg goedkoop.
Volgens mij is Philips in het betaalbare segment bezig met zo'n concept. Overigens zag ik op de IBC ook al een aanbieder staan welke het via coax kabels met elkaar verbind en waar ook video over heen kon.
