Sony VPL HW30ES press release
Gestart door Annewiek, juni 10, 2011, 09:56:23
Annewiek
Sony Professional
PRESS RELEASE
Sony expands its groundbreaking 3D home projector range with the affordable VPL-HW30ES
9th June 2011
Basingstoke, UK, 9th June 2011: Sony has today announced it has expanded its range of market leading 3D home projectors with the new, more affordable, VPL-HW30ES. Incorporating Sony's latest lamp technology, dynamic lamp control system, movie fans have the opportunity to enjoy an unrivalled 3D cinematic experience, with stunning images that are three times as bright as Sony's first 3D home projector, the VPL-VW90ES.
In order to achieve an optimal movie experience which feels natural on the eye, the VPL-HW30ES is equipped with Sony's High Frame Rate SXRD Panel (1920x1080), which helps to reproduce dramatically sharp and smooth motion and reduces the image motion blur for a crisper image (Motionflow) and deliver a dynamic contrast ratio of 70,000:1 and brightness of 1,300lm. In addition, "3D crosstalk" is significantly reduced thanks to the 240Hz SXRD panel drive system. The VPL-HW30ES is also capable of taking 2D video and simulating 3D images, bringing new life to classic movies from the past and allowing a wide variety of video content, such as live sports, to be enjoyed.
The VPL-HW30ES also enhances the customer viewing experience by enabling them to enjoy 3D and 2D pictures more comfortably.  It has independent 2D/3D picture mode, which helps when you watch 2D and move on to watch 3D contents and you can watch the contents optimum picture image setting automatically. And the VPL-HW30ES runs very quietly with an advanced air discharge system by "22 db" which doesn't disturb the overall cinematic experience.
"The launch of the VPL-HW30ES demonstrates Sony's commitment to developing truly innovative products which allow more people than ever to experience 3D in their own living room," said Tak Nakane, product specialist at Sony Professional, Sony Europe. "Built using Sony's extensive 3D expertise, the VPL-HW30ES sets down a new benchmark for demanding movie-goers who want a high-end home cinema system at an affordable price."
The VPL-HW30ES is compatible with Sony's new active shutter glasses, the TDG-PJ1, which are 18 grams lighter than the previous model (59g compared to 77g). The TDG-PJ1 can be charged in 30 minutes to provide 30 hours of continuous watching. In conjunction with the new glasses, Sony has announced a new transmitter, the TMR-PJ1, which synchronises 3D content effortlessly to generate a high-quality natural 3D effect.
The VPL-HW30ES will be available across Europe in July 2011. The TDG-PJ1 and TMR-PJ1 are sold separately.
beschikbaar in Juli 2011
prijs volgt zo snel mogelijk
www.hometheater.nl
www.studioFD.nl
Annewiek
www.hometheater.nl
www.studioFD.nl
CineSmurf
Waar moet je zo'n signaalzender zetten? Ik zie dat er een ethernetaansluiting op zit, hoop niet dat ik dan een kabel naar mijn scherm moet trekken...
JVC DLA-NZ500; Marantz AV7702mkII; 5x Emotiva upa1; Ziggo next PVR; Oppo UDP-203; HD Dune 3.0; SVS 25-31PCi (custom tuned to 22Hz) subwoofer; Dali Suite 2.8, C 0.8 & 1.7 en (4 x) 0.7 aan het plafond.
Vaak kunnen ze gewoon in de buurt van de projector.
Die van ons bv zit gewoon in de projector.
papaleo
En dan nu de brandende vraag;
VPL-HW30ES vs VW90ES ?
riwi
3600 euro zie ik als prijs aangekondigd bij een bekende duitse forum sponsor :)
maximus79
Citaat van: papaleo op juni 11, 2011, 20:04:26
Ben ook benieuwd!!
Weet ik pas als we hem testen.
Maar ik verwacht dat het de kleine broer is, of wel waarschijnlijk ongeveer gelijke performance maar net iets minder op 2d en waarschijnlijk iets beter op 3D.
Maar goed dat is koffiedik kijken.
Ik verwacht dat de 3D ontwikkeling namelijk door is gegaan, met 2d is de vw90 gewoon al enorm goed en ik denk niet dat de goedkopere versie dit verbeterd.
Maar who knows. ;)
riwi
Citaat van: J.A.F._Doorhof op juni 12, 2011, 06:37:46
Ik denk dat de speciale lamp mode die zorgt voor 2.5 a 3x zoveel licht in 3D vergeleken met de vw90 wel een groot verschil in 3D beleving zal zijn.
Kwa 2D zal ie vast minder zijn dan de vw90.
Deze hw30 heeft ook manuele shift en zoom ipv motor shift en zoom, tenminste dat las ik.
papaleo
Citaat van: riwi op juni 12, 2011, 12:50:41
Manuele shift/zoom...,als dat het ergste zou zijn,btw..zag de wieltjes al boven op de HW30 zitten om dit te bedienen.
Even afwachten wat dit exemplaar te voorschijn tovert,Sony zou het niet toch kunnen maken om hun vlaggeschip voorbij te gaan,op alle fronten, met een 'instapmodel'.
riwi
Citaat van: papaleo op juni 12, 2011, 18:31:00
Met mijn doek met masking schuif ik voor iedere film het projectorbeeld met lens shift in het laagst mogelijk positie op het doek. En daarvoor is motorshift min of meer vereist. Ach, het zou ook wel manueel kunnen, maar ideaal zou dat niet zijn.
papaleo
#11
Ooh,is dat zo..,goed dat ik dat nu even mee krijg dan,is dit bij alle Masking schermen?  ;)
Dus als je een scherm hebt met Masking dan zou je iedere keer wanneer er een beeld voorgeschoteld word met een andere aspect verhouding,je projector in moeten om het beeld te shiften?
Als dat zo is,dan is het zeker een must om dit met je ab te doen,en niet steeds naar je pj te moeten om dit te bewerkstelligen...
@ Btw,Richard;
Ik ben 'n tijdje geleden naar Grobi/Patrick gereden, en ben verleden week ook geslaagd voor een 110" Masking scherm bij Grobi,deze voldeed 'precies' naar wat ik zocht...had natuurlijk liever een motor BDII scherm, maar die komen daar voorlopig nog niet mee,als ze er ubherhaut mee gaan komen dit jaar...dus is het dit 110" scherm geworden(zie link)
http://www.wsspalluto.de/ws-s-deckeneinbau-4-format.htm
riwi
#12
Beetje off topic : antwoord in mijn eigen thread
http://www.htforum.nl/yabbse/index.php?topic=108747.msg1962299#msg1962299
Ziet er veelbelovend uit. Die speciale lampmodus ben ik wel erg argwanend over want een normale lamp vind dit niet fijn. Ik hoop dan ook dat ze twee lampen gebruiken.
Ik ben ook benieuwd naar het antwoord van JVC. Als zij hun huiswerk niet veel beter doen mbt lumens op 3d en ook met FI dan ben ik bang dat ze dit marktsegment ook kwijt zijn.
Al zo vaak aan bod geweest.
De US prijs moet je 19% BTW bij tellen, 10% invoer rechten en gemiddeld 300.00 US shipping, tel uit je winst ;)
Citaat van: copycat op juni 16, 2011, 17:36:08
betaal ik liever 3700 dollar  wat een afzetterij
Beetje kort door de bocht!
Mijn ervaring is dat USA prijzen bijna 1 op 1 vertaald kunnen worden naar euro's, zie ook het comment van Frank.
Daarnaast zit er logischerwijs een extra marge op voor het bedrijf in Europa.
Cage
Frank,
Al een idee of en wanneer we hiervan een review kunnen verwachten?
:shaun: Arcam avr300 | Oppo BDP-103 | Epson TW-7200 | SqueezeBox Reciever + BOTWS| QNAP TS-119 NAS | Phonar Veritas P6 Edma, C4 Edma, M4 Edma :shaun:
Zodra we ze krijgen komt er direct een review.
pst
Citaat van: J.A.F._Doorhof op juni 17, 2011, 23:33:33
Is er al wat meer bekend over wanneer de uitlevering gaat beginnen? Ben in de markt voor een nieuwe beamer en wil dit apparaat zeker in de overwegingen meenemen.
Ze komen zodra ze komen.
Na verschillende ervaring met andere merken wil ik geen uitspraak doen, maar laten we het zo zeggen, het zal nog wel warm zijn in de home theaters.
papaleo
Citaat van: J.A.F._Doorhof op juni 30, 2011, 12:06:07
En ze zijn weg voordat ze verdwenen zijn...
evilniek
Citaat van: papaleo op juni 30, 2011, 21:11:07
:laugh: kom niet meer bij, deze verdiendt een tegeltje. :clapping:
Erik
#22
En ze zijn weg voordat als ze verdwenen zijn...
Verder prachtig bedacht  :D had speltip 10 kunnen zijn  :D
- Winston Churchill
pst
Meer hoef ik niet te weten. Ga trouwens toch nog op vakantie (wel opletten dat er nog geld over is.....  ;D )
Bedankt!
REVV
"Now listen to me, I'm older and I'm wiser." "Yeah, well, you're half right."
