Schiit Gungnir Multibit USB gen 5 750euro
Started by Mordante, February 21, 2019, 10:29:46
Mordante
Vraagprijs 750euro. (Inruil Anzus XLR series 2 interlink bespreekbaar)
Wegens het overstappen naar een all in one streamer bied ik hierbij mijn Schiit Gungnir Multibit USB gen 5 DAC te koop aan. (Foto's volgen).
Volgens mij behoeft deze R2R weinig uitleg. De USB input is voorzien van de nieuwste gen 5 USB input met galvanische scheiding. Deze upgrade heb ik zelf uitgevoerd.
De DAC is nu ongeveer 2-2.5 jaar oud.
Gungnir Multibit
D/A Conversion IC: Analog Devices AD5781BRUZ x 4 (2 per channel, hardware balanced configuration)
Digital Filter: proprietary Schiit bitperfect closed-form digital filter implemented on Analog Devices SHARC DSP processor
Analog Stages: Fully discrete JFET buffers for balanced output and discrete JFET summing stages for single-ended output, direct coupled throughout
Frequency Response, Analog Stage: 20Hz-20Khz, +/-0.1dB, 1Hz-200KHz, -1dB
Maximum Output: 4.0V RMS (balanced), 2.0V RMS (single-ended)
THD: Less than 0.005%, 20Hz-20KHz, at full output
IMD: <0.004%, CCIR
SNR: > 115dB, referenced to 2V RMS
All Gungnirs
Inputs: Coaxial RCA SPDIF, BNC SPDIF, Optical SPDIF, USB
Input Capability: up to 24/192 for all inputs
Input Receiver, SPDIF: AKM 4113
Input Receiver, USB: C-Media CM6631A
Output: One pair XLR balanced and two pairs RCA single-ended
Output Impedance: 75 ohms
Clock Management: Bitperfect clock management at all native sample rates via Adapticlock analysis and VCXO/VCO regeneration, plus asynchronous USB Gen 2 module
Power supply: two transformers (one for digital supplies, one for analog supplies) with 8 stages of regulation, including separate local supplies for critical digital and analog sections.
Upgradability: Separate, modular USB Input Card and DAC/Analog Cards are snap-in replaceable.
Power Consumption: 20W
Bas Akkerman
Dag Mordante,
Je topic heb ik net niet voor niets gesloten en verplaatst. Een eigen foto of foto's bij plaatsing is namelijk verplicht. Ik sluit dit topic dan ook weer en je kan een nieuw topic met foto's plaatsen.
Je mag me altijd een PM sturen met vragen.
Groeten,
Bas
