Yippie
Author Topic: iRule Update  (Read 14800 times)
Offline CoSo
  • HT forum donateur
  • HT forum legend group
  • Trade Count: (+43)
  • Total likes: 0
  • Gender: Male
  • Never up, Never in.
    • Susano HT
iRule Update
« on: March 20, 2012, 16:13:24 »
iRule 2.3 Now Available for iOS!
We are excited to announce that iRule version 2.3 for the iPad, iPhone, and iPod touch is now available for download.
You asked us for these new features, and we're listening! From the iTunes Module that controls iTunes on a Mac or PC, to hidden navigation bar, screen dimming, and a new iPad panel transition, we worked really hard to add the features you wanted!
Announcing iTunes Module for iRule HD
With iRule, an iPad, and the iTunes Module, you don't have to launch a different app to see playlists, browse, and play music from iTunes! Add an iTunes Module to your iPad remote, and create a whole-house audio-video distribution system without spending a fortune. All you'll need is an AppleTV or two, an AirportExpress, or some other AirPlay device, and access all your music, movies, TV shows, podcasts and more - right from iRule.
iTunes Control - iRule’s first add-on module provides powerful control of iTunes running on a Mac or Windows PC.
AirPlay - AirPlay devices are automatically connected. Supported devices include AppleTV, AirPort Express, AV receivers, and compatible speakers.
For iPad - Initially iPad-only; later releases will support additional handset platforms.
Pricing - The iTunes module is $25 per handset and is available to both Basic and Pro users.
New Features in iRule version 2.3:
Hide Nav Bar (Pro) - Designers can now hide the Nav Bar on the remote, eliminating the page title, "panels", and "back" buttons while freeing up additional screen real estate.
Text on Buttons & Links - Yes, you can now overlay text on Buttons and Links!
Screen Dimming - iRule will now dim the screen after a period of inactivity. Leave iRule open and connected in a dark room and just tap the screen to brighten it up and use it.
Macro Pause Dialog - Added "wait" dialogs to direct users to wait while device macros execute.
Smooth Repeat IR - Faster repeating of infrared commands on supported devices, useful in applications like volume ramping.
Better Macro Handling - Macros are now queued for sequential execution.
Fade Transition - The "sliding" Panel transition on iRule HD (iPad) has been replaced with a more subtle dissolve for a more seamless user experience, especially with buttons such as source, volume or mute that are static from panel to panel.
Improved Command Execution - Command queuing has been improved.
"More" tab - This new tab in the Builder holds these new items:
  Actions - New Delay and Message elements for more reliable and polished macros.
  Modules (iTunes) - Drag-and-drop the iTunes Module into your layout from here.
  Widgets - Drag-and-drop Buttons, Links, Labels, and URLs from this new element group.
  Launch - Launch external apps, the Apple Mail app, an email to support, or a URL in the Safari browsers - right from a Button!
  Nav - Now that the Navgation Bar can be hidden from the user, use the Nav commands to add your own Back, Sync, Panels, and Gateways buttons to a remote.
Rounded Corners - URL element and iTunes Module can now be displayed in a remote with rounded corners or square corners.
Improved Background Image - Background images are easier to arrange and layer.
iOS 5.1 support - Tested and supported on newly-released iOS 5.1.
« Last Edit: December 4, 2012, 06:19:30 by CoSo »
Offline Durk
  • lid van de off-topic
  • HT forum donateur
  • Trade Count: (+3)
  • Total likes: 0
  • Gender: Male
  • HT forum: je baken op de woeste AV zee !
Re: Update iRule 2.3
« Reply #1 on: March 20, 2012, 16:32:37 »
25 euro.. voor een extra module..jammer dat ze overal geld voor vragen.
Het dimmen is wel een zeer welkome aanvulling.
Offline CoSo
  • HT forum donateur
  • Total likes: 0
  • Gender: Male
    • Susano HT
« Reply #2 on: March 20, 2012, 16:45:35 »
klopt maar Prontotunes koste ook geld, aan de andere kant is de app Remote weer gratis. :-\
Offline CoSo
  • HT forum donateur
  • Total likes: 0
  • Gender: Male
    • Susano HT
« Reply #3 on: March 20, 2012, 16:48:22 »
Het is me alleen niet duidelijk hoe ja aan die module kan komen en als ik het goed begrijp is het per apparaat :blink: :-\
Offline CoSo
  • HT forum donateur
  • Total likes: 0
  • Gender: Male
    • Susano HT
« Reply #4 on: December 4, 2012, 06:19:01 »
New Features in iRule for iOS Version 2.6
Sonos Module
You've been asking for it and we're happy to finally be able to deliver it! Like the iTunes Module, the Sonos Module integrates iRule system control and advanced music system control. With iRule, an iPad, and the Sonos Module, you can browse and play music from your audio library (streaming radio coming soon), yet still control system volume, inputs, lights, and more. No more constantly switching back-and-forth between apps!
Onkyo-Integra Module
Like an "app within an app", the Onkyo-Integra Module enables control Onkyo Integra network receivers and processors. Select input, network source, radio station, stream from internet radio stations, local network media, or USB, and display content information.
Automation Module for Leviton Z-Wave
Need a fast, simple way to add Z-Wave control to an iRule remote? The Automation Module controls Z-Wave devices via the Leviton VRC0P-1LW Vizia RF + Plug-In Serial Interface Module. Simply drag and drop the Automation Module into your remote, and control light switches, light dimmers (both horizontal and vertical layout), and even locks. This is only the beginning; there's more coming soon!
Offline CoSo
  • HT forum donateur
  • Total likes: 0
  • Gender: Male
    • Susano HT
Re: iRule Update
« Reply #5 on: December 17, 2012, 16:57:07 »
Nu met komst van de Leviton Z-wave module is dit ook een oplossing voor NL?
