Probleem met 1080p film op popcorn
Gestart door svmnb, mei 25, 2009, 20:14:58
svmnb
Deze mkv van The Rock 1080p levert wat problemen op op de PCH-A100 met de laatste firmware. Het beeld schokt en het geluid is 'slow motion'.
Iemand enig idee wat dit kan zijn? Op de pc loopt het wel prima.
General
Complete name                    : M:\Film\HD films\The_Rock 1080p\The_Rock.nlsubs2.mkv
Format                           : Matroska
File size                        : 16.1 GiB
Duration                         : 2h 16mn
Overall bit rate                 : 16.9 Mbps
Encoded date                     : UTC 2009-05-12 06:40:11
Writing application              : mkvmerge v2.5.3 ('Boogie') built on Mar  7 2009 15:00:41
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : [email protected]
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Muxing mode                      : Container [email protected]
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 2h 16mn
Nominal bit rate                 : 12.3 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16/9
Frame rate                       : 23.976 fps
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.247
Writing library                  : x264 core 65
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=1.0:1.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-4 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=240 / keyint_min=24 / scenecut=40(pre) / rc=2pass / bitrate=12286 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language                         : English
Audio
Format                           : PCM
Codec ID                         : A_PCM/INT/LIT
Duration                         : 2h 16mn
Bit rate mode                    : Constant
Channel(s)                       : 6 channels
Sampling rate                    : 48.0 KHz
Resolution                       : 16 bits
Language                         : English
Text
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Language                         : Dutch
Menu
00:00:00.000                     : :Chapter 1
