Nieuwe H3D software.
Gestart door J.A.F._Doorhof, juni 25, 2003, 00:05:59
June 23) Version 2.0pre6 Changes:
Minor Revision Update mainly for HOLO3DGRAPH II
Autoformat now works on HOLO3DGRAPH II
Support for Sigma/RealMagic remote control. Configured via Setup Menu -> Setup OSD.
Fixed Pronto macros - delay between keypresses no longer needed.
HD-AUX Support delayed till next release
(June 17) Version 2.0pre5 Changes:
Properly detects shipping HOLO3D-II (Rev 2) rather than prototype HOLO3D-II boards (Rev 1)
Horizontal/Vertical Sync Offsets now has better defaults on HOLO3D - II
(If you tried 2.0pre4 on HOLO3D-II, please delete your HOLO3D.INI before trying 2.0pre5)
Advanced Menu pulldowns now correctly positioned under menu buttons
Please note that drivers for HOLO3D-II are still in beta stage
HIER TE DOWNLOADEN:
http://www.immersiveinc.com/holofiles/HOLO3D_v20pre6_Update.zip
MvrGr.
Snel beantwoorden
Naam:
E-mail:
Verificatie:
