Nieuwe software pre4
Gestart door J.A.F._Doorhof, juni 7, 2003, 10:07:39
http://www.immersiveinc.com/holofiles/HOLO3D_v20pre4_Update.zip
(June 5) Version 2.0pre4 Changes:
New Advanced Menu (Third Menubar)
(Has 2 menu items on H3D-Original, and 4 menu items on H3D-II)
Easy Wraparound Menu Bar. Cycle through Main/Setup/Advanced Menus quickly!
- Mouse: Click the new little arrows at the ends of the menubar
- Remote: Click the << or >> buttons on remote
- Keyboard: Hit the PgUp or PgDn keys.
Also, you can also tap left/right beyond the ends of the menubar to loop around all three menus. Keep tapping the left/right buttons and see what happens! If you need to wife-proof or idiot-proof the setup to make the other menubars harder to access, you can still disable this feature by "Setup Menu" -> "Menubar Wraparound" -> "Off"
Several Setup Menu items have now been moved to Advanced Menu. Also several settings such as "VMR", "Reset To Defaults", "About", "Shutdown" have now been moved to new "Operations" pulldown in Setup Menu.
Refresh Rate Improvements. Preset Refresh and Custom Refresh merged into one setting.
New Refresh Rate Precision setting.
Fixed minor Refresh Rate switching problems that occured on some systems
Girder API Improvements / Discrete Macro Improvements
(Codes are now 4 digits in a new format. First digit is menubar number #1-3, second digit is pulldown menu #1-5, and last two digits is menu item #01-#99)
Several other minor bugfixes.
Frank heb je deze nieuwe beta al kunnen testen??
Er zaten in die andere versie volgens mij nog wel wat glitches... mede rond VMR. Heb jij het idee dat VMR nu goed loopt? Ik draai nu met Overlay.
groet
Bjorn
Hi,
VMR op de Geforce draait goed, op de ATI niet.
Na ongeveer 20-30 minuten krijg je tearing boven in het beeld, zeer jammer.
De glitch van het wisselen van de refresh rates is nu wel opgelost, hoewel dat niet echt een probleem was.
En er zijn wat nieuwe menu's bijgekomen.
De VMR ligt trouwens puur aan de ATI drivers.
MvrGr.
Dus wachten op catalyst 3.5 of 3.6 van ATI.. blijkbaar...
Allrighty!
Thx! Groet Bjorn
Snel beantwoorden
Naam:
E-mail:
Verificatie:
