The MATRIX Blu Ray hakerig?
Gestart door paul groot, oktober 26, 2008, 22:24:59
paul groot
Jullie iets opgevallen aan de Matrix?
The Matrix 1,2 en3 aangeschaft en deel 1 gekeken. 2 en 3 komen later.
Erg mooi beeld alleen bij camera bewegingen links/rechts blijven de personen scherp maar is de achtergrond nu en dan hakerig.
Vreemde zaak.
Op de higdefdigest recensie geen woord daarover. Zowel niet bij de HD-dvd als bij de blu ray.
Het is de enige blu ray waarbij ik dit heb.
Iemand anders ook opgevallen? Of is er iets anders aan de hand.
Vanavond bij Indiana Jones weer perfect beeld.
Mijn configuratie is;
Sony 300 speler
Barco 1209/2
Dvdo vp50 scaler
Hd-Fury.
http://bluray.highdefdigest.com/300/matrix_umc.html
Quote uit de BluRay en HD-DVD tekst'"
The Video: Sizing Up the Picture
Finally, compression artifacts are not an issue. There isn't a moment of macroblocking or any noise, even on the many flat surfaces and static shots, which often hold on a particular image for what seems like minutes. And the source itself is beautifully maintained -- there is a bit of grain here or there, but it is clearly part of the intended effect and there are no instances of dirt or blemishes. This is really fantastic stuff -- 'The Matrix' trilogy easily earns an exemplary five-star video rating.
HD-DVD
Finally, compression artifacts are not an issue. There is not a moment of macroblocking or any noise, even on the many flat surfaces and static shots, which often hold on a particular image for what seems like minutes. And the source itself is beautifully maintained -- there is a bit of grain here or there, but it is clearly part of the intended effect and there are no instances of dirt or blemishes. This is really fantastic stuff -- 'The Matrix' trilogy easily earns an exemplary five-star video rating.
Unquote"
Identieke commentaren.
Paul
Sony 4k, Ziggo Next 4K, Div Audio, PS4, Sony player4k, Eigenbouw speakers open baffle.
jantje112
Waarschijnlijk draai je op 60 hz en heb je dan last van de 3/2 deinterlacing.
Draai je vp50 maar eens op 1920*817 (voor 2.35:1) 72 hz.
jaco
Het schijnt precies dezelfde video transfer te zijn..
Dan zou het commentaar kloppen dus..
paul groot
Citaat van: jantje112 op oktober 27, 2008, 08:53:14
Okee
morgen ga ik dat even uitproberen,
thanks
paul
paul groot
Deinterlacing stond op 2;2, wat dat ook mogen zijn ???, op standje "auto" gezet, en probleem opgelost.
Bedankt Jan.
gr
paul
jaco
Citaat van: paul groot op oktober 28, 2008, 22:44:14
2/2 is voor PAL rommel (50 Hz interlaced)
