Nieuwe Firmaware MB100 / MB200 1.4.3
Gestart door richardnl, oktober 18, 2007, 11:29:20
richardnl
http://www.pixelmagicforum.com/forum/showthread.php?t=2926
directe download:
ftp://ftp.crystalio.com/Public/HDMB_Firmware/v1.4.3/MediaBox_v143.zip
ChangeLog:
- added Playlist support.
On the top level browser screen there is a new "PLAYLIST" entry. User can add any file or folder from all accessable location using the remote button "Vol+" and the file/folder will be added under the "PLAYLIST" entry. Under the "PLAYLIST" entry, use remote button "Vol-" to remove the item in the playlist.
- added Dynamic font file for external .SRT subtitle format.
To use the feature, please set the Setup->System->Subtitle Encoding->Western New. User can use their own TTF (TrueTypeFont) font file with the same filename as the media file and the .srt subtitle file under the same folder. The system will automatically load and use the .ttf font file for subtitle display.
- added scrolling filename for long filename info
- added UPnP (Universal Plug and Play) network streaming, from the top level file browser enter the Network(UPnP), it should list all the UPnP device/service in the local network
- added MPEG2 media file (.vob, .mpg, .ts etc) seamless playback in full folder playback and repeat all track playback
- added Windows Vista file sharing support
under Windows Vista, create a "HDMB" folder and share it. It will be listed in Mediabox under the Windows Vista PC name in Network(Samba)
Paul Landsmeer
Citaat van: richardnl op oktober 18, 2007, 11:29:20
Eindelijk! Kan ik mijn MP3 collectie weer hele middagen continu laten draaien zonder steeds van folder te hoeven wisselen.
Communicator
^^ Ja...als je tenminste eerst drie dagen alle files handmatig hebt lopen toevoegen in die lijst....Waarom niet gewoon ondersteuning voor een m3u of andere list-file? Die maak je eenvoudig op je PC...
Wederom een non-firmware wat mij betreft: De annoyances die er al in zaten zijn er niet uit. Verder geen dingen die ik moet hebben, dus: Laat maar gaan deze.
Paul Landsmeer
Citaat van: Communicator op oktober 20, 2007, 14:32:20
Het is misschien niet ideaal, maar het is beter dan niets.
richardnl
wat ik jammer vind is dat het delen onder vista niet werkt.
Ik krijg het namelijk niet voor elkaar terwijl met windows XP de samba share prima werkt
Zelf als ik een share aanmaak hdmb en de firewall uitzet werkt het nog niet
Het apparaat voldoet prima voor .ts en dvd's (iso. img en vob files).
daniel.benjamins
Sinds dit weekend heb ik opeens problemen met het streamen (via NFS) van mijn NAS. Firmware is 1.4.3.
Zie ook deze thread: http://www.pixelmagicforum.com/forum/showthread.php?t=2986
Ik kan nu niets meer afspelen... de bestanden en mappen zijn wel zichtbaar, maar wanneer ik ze wil afspelen, blijft 'ie hangen op "Please wait..." en is er geen andere oplossing dan de spanning er af halen.
Via USB iets afspelen gaat zonder problemen.
Iemand een idee?
Paul Landsmeer
Sinds de laatste firmware upgrade heb ik ook meer vastlopers met de MB200, soms gewoon midden in een film. De enige manier om 'm dan weer op gang te krijgen, is door de stroom eraf te halen. Niet echt een verbetering dus.
richardnl
Citaat van: Paull op november  8, 2007, 23:01:25
heb ik ook en soms reboot het apparaat
ga binnenkort weer terug naar een oudere versie :-(
Be nu al weer bijna een jaar van m'n MB100 en MB200 af.... En kijk via een HTPC die alle formaten afspeelt en nooit vastslaat. Als ik dit zo weer lees destijds de juiste keuze gemaakt. Nagenoeg géén vooruitgang met de MB met betrekking tot firmware
Paul Landsmeer
Citaat van: Raphie op november  9, 2007, 09:27:05
Dat is dan ook weer wat kort door de bocht, want hoewel soms wat wispelturig, vind ik de MB200 nog steeds een prima apparaat. Bovendien zijn de meeste HTPC's ook bepaald niet probleemloos.
Het is zeker een goed apparaat en oet wat hij moet doen, maar paste destijds niet zo goed meer bij mijn gebruik
daniel.benjamins
Ik ben al teruggegaan naar firmware 1.3.6, welke altijd goed werkte.
Maar ik kan nog steeds niets afspelen via NFS. De mappen en bestanden bekijken is geen probleem...  ???
daniel.benjamins
Citaat van: daniel.benjamins op november 10, 2007, 13:13:06
Heeft iemand hier misschien een idee hoe bovenstaand probleem opgelost kan worden?
Van PMS zelf (via het forum) krijg ik geen antwoord...
Als je de mappen kunt bekijken moet afspelen ook willen, heb je toevallig een rechten kwestie verkeerd staan misschien ?
Over het vastslaan van de box.
Ik kijk regelmatig HD streams en wat Divx via de mediaplayer maar heb tot nu toe geen hangs, ISO's heb ik zelden getest.
Als ik kijk naar mijn oude HT-PC ben ik juist blij dat het ding weg is, altijd geklooi met codecs, nu weet je wat wel en wat niet draait :D
En voor H264 heb ik de Tvix4100 erbij.
Een dure maar perfecte combinatie, de MB200 voor het perfecte geluid en beeld, de Tvix voor alles wat de MB niet afspeelt.
Marcel_T.
Citaat van: J.A.F._Doorhof op november 14, 2007, 23:43:32
Ik wou dat ik dezelfde ervaring had. Maar helaas kan ik geen HD film kijken zonder gemiddeld 4x per film op de media resync knop te moeten drukken en 18 seconden te wachten alvorens ik verder kan kijken.
Het lukt me trouwens ook niet om van 1.4.0.2 te upgraden. Moet ik dan eerst terug naar 1.3.6?
Heb je wel eens getest met HDTV repair ?
Het lijkt me dat er ergens iets misgaat met je audiosync in de file zelf.
Marcel_T.
Ik voeg de ts-files samen met mpeg2repair, ik weet niet of je die bedoelt?
Maar ook met onbewerkte bestanden (o.a. D-theater rips) heb ik toch vastlopers.
vreemd.
Eventueel kun je hem een keer met ons swappen (als hij via ons is aangekocht) en kijken of een andere het niet heeft.
Wat ik hoor van de mensen is juist dat TS streams bijna allemaal vlekkeloos lopen.
Marcel_T.
Als dit exemplarisch is dan wil ik een swap wel overwegen. Het toestel is door Frankly bij jullie gekocht en ik heb hem van Frankly overgenomen omdat ie bijna niet gebruikt werd. Bon is ook nog aanwezig.
daniel.benjamins
PMS heeft het over een factory reset (helpt niet) en een rescue firmware (hoe werkt dat?).
Daarnaast denken ze dat het aan de NAS ligt en niet aan de MB200 zelf, wat ik wel vreemd vind omdat er veel meer mensen op dit moment hetzelfde probleem hebben.
Ik zal nog eens wat instellingen op de NAS nakijken, maar denk niet dat het veel helpt.
Die instellingen zijn nl. nooit veranderd door mijzelf, maar misschien wel door een firmware update van de NAS.
jaco
Citaat van: Marcel_T. op november 15, 2007, 15:53:31
Dat moet je niet doen, mpeg2repair vernield de structuur van mpeg-2. Dat is ooit gemaakt om captures via Firewire te herestellen, maar werkt niet altijd goed voor huidige captures.
Joinen doe je het beste met HDTV2MPEG.
Video streams repareren met VideoRedo
Marcel_T.
Citaat van: jaco op november 17, 2007, 09:23:59
Die gebruikte ik eerst, maar daarmee was het resultaat even slecht. Mogelijk dat het toch exemplarisch is, ook de nieuweste firmware bracht geen verbetering. Zal binnenkort toch even contact met Frank opnemen.
Snel beantwoorden
Naam:
E-mail:
Verificatie:
