goed nieuws! reclock alternatief in de maak
Gestart door THX-UltraII, oktober 16, 2007, 16:12:25
DickVD
wat is het nut van reclock?  ::)
als ik me goed herinner kan je daarmee je framerate mee veranderen, maar waarom ook al weer?  ::)
groetjes van Dick van Dijk uit Woerden.
Mijn huidige hardware:
Epson: EH‑TW9300; LG-OLED55C6V =55inch UHD-3D-TV; Velodyne SPL-1200 Ultra; Reciever: Pioneer VSX-1131: 7.2/5.2.2; Fronts: Magnat Monitor Supreme 2002; Center: Artsound TUTTO 2/4.1; Surrounds: Magnat Shadow 203 op standaards; Surroundback: Artsound TUTTO 2/4.1; Atmos-plafond: Magnat Symbol Pro; 3D-bluray speler: Philips BDP7750; DVR: Humax iHDR-5050c; Asus Laptop =ROG G751JY-T7136H= i7 4860HQ 16Gb 17" Nvidia GeForce GTX 980
kaajee
Citaat van: DickVD op oktober 19, 2007, 15:33:46
Even zelf zoeken en je hebt je antwoord meteen, in ieder geval sneller dan eerst hier posten en wachten/hopen op antwoord....... ;D :P
CiteerReClock DirectShow Filter
What is it ?
The purpose of ReClock is to definitely get rid of jerky playback of AVI and MPEG material on a PC (or a HTPC driving a TV, a flat panel, or a video-projector). It's a DirectShow filter which is loaded in place of the default directsound audio renderer.
It provides a new reference clock that is locked to the video card hardware clock, in order to ensure that frames are played at the exact speed of what is expected by the video card vertical sync.
It also provides a frame rate adaptator for media files that do not match a multiple of the video card refresh rate (ex: playback of 23,976fps IVTC NTSC on a PAL TV).
The combination of the two will give you the true experience of smooth playback with your PC.
Finally it is an audio renderer with hardware or software rate adaptation in real-time, multi-channel audio, audio timestretching (pal speedup compensation) and dynamic range compression capabilities.
(bron, eerste hit in google)
DickVD
ik heb tot nu toe zonder reclock weinig last van schokken, wel soms om het 1/2uur, maar dat lag aan de harddisk ::)
