Kit TentLabs CD-speler
Gestart door Shorty, september 22, 2006, 16:44:57
Shorty
CiteerWe are proud to introduce the DIY CD player, bringing high end digital playback at a very competitive price!
"Despite its' relatively low price, it appears to be a megastar "
" Very much reccomended !! "
(Jo Mullers, Music Emotion May 2006). Available end of September
What others say
" High resolution, authority en relaxed playback "
" Low frequency response was phenomenal and staging is unmatched "
(Jo Mullers, Music Emotion May 2006). See the full test:
• Dutch
• English (translated by Guido Tent & Bruno Putzeys)
Exclusive offer !
We are now taking pre-orders. As a special service, we offer to engrave your own name on the front panel, at no additional cost. This will make a truly special, personalized version ! Apply for more information, this offer stands until October 31.
DIY
The CD player is build up fully modular. All modules come pre assembled and tested. Required wiring is prepared and the cabinet comes as a set of parts. Total assembly does not require high levels of experience in electronics but does ask for some time and secure way of working.
General Description
This DIY version fills the gap between much cheaper multi format playback devices and highly priced CD players. This machine plays back CD and CDr discs, it does not handle higher resolution formats like SACD or DVD audio. It has both analog and digital outputs. An optional module (available end 2006) accepts SPDIF and USB audio as inputs, which converts the player to a universal playback device for either discs or PC based audio files.
The players uses non-oversampling conversion, and has a tube based output stage. It has extensive power supplies and is housed in an elegant solid cabinet, made of aluminium and wood.
Technical description
Drive
The player uses the well appreciated Philips CDproM drive, ensuring secure playback of discs. It is clocked by a separate low jitter Tentlabs clock and puts out its' data using the I2S digital interface format, which intrinsically is independant to jitter.
DAC
The DAC takes in the I2S data, reclocks it and processes the 16 bits data to be accepted by the 20 bit DA converters. These run in non oversampling mode, main advantage is that less jitter enters the DACs due to the absence of a digital filter and the DACs run at a lower bitclock rate which makes their life much easier. Prior to entering the PCM1704 DACs, all data is reclocked again. This takes place by the onboard Tentlabs master clock. This clock is powered by a fast, low noise shunt regulator, of which in total 6 are present. 4 others feed the analog supplies of the 1704's and the last one the reclocking circuits. Another 6 regulators take care of the supply of other, less critical, circuitry.
IV converter and output stage
The IV converter uses an E88CC valve as transimpedance amplifier. It fully operates in the current domain, and is a new and novel design. The advantage over existing tube based output stage is the low input impedance (typically well below 1 ohm) which reduces the distortion generated in the DAC chips when these are loaded with say 100 ohm. After the E88CC stage, a passive filter follows. The actual IV conversion takes place using an Audio Note tantalum resistor, signal coupling is achieved using Audio Note copper foil paper-in-oil capacitors. 2 pairs of outputs are available, a straight output with a moderate 2500 ohms output impedance, and a buffered one with output impedance well below 200 ohms. The IV stage is fed by a custom made toroidal transformer, the well regarded 6X4 takes care of high voltage rectification.
Power supplies
The IV converter, DAC and drive all have their own toroidal power transformer. The drive is fed by 2 external Tentlabs power supplies, a third one supplies the Display. The power supplies incorporate Schottky Barier diodes.
Prijs: € 2495 incl. BTW
Zie Tentlabs
VrGr,
Bart J.
Wow, goed doordacht ontwerp! Wat mij betreft volgens de regelen der kunst!
Shorty
Zeven aparte voedingen!  :-*
Maar - als 'fan' van Audio Synthesis hou ik altijd hun bezwaren tegen I2S in gedachten:
CiteerThe usual method for data communication within a converter is I2S or similar. But the residual noise generated by this coding system contains a large audio frequency component, effectively in the form of a square wave, superimposed on the digital data and whose amplitude increases as the digitally represented component's amplitude reduces. The result is an inherent background level of jitter, ultimately responsible for a clouding of the air and ambience information present in the original digital source.
(Bron)
Maar dit pakket lijkt me ook voor nitwits als mezelf geschikt om in elkaar te lijmen - geen SML-gepruts en gedoe met zelf gemaakte kasten.... :D
VrGr,
Bart J.
Gydotron
Guido is vorige week bij mij thuis geweest met zijn speler en ik was behoorlijk onder de indruk. Een heel rustige klank, nooit hardheid. Een fenomenale goede plaatsing van de instrumenten en dit ook met de juiste verhoudingen.
Na enkele nummers stop je gewoon met technisch luisteren, gewoon muziek! Volgens mij een echte aanrader!
Grtn  Guido
Audiofiel
Het ziet er zeer veelbelovend uit. Tsja, die houten zijkantjes vind ik niet zoveel (Sony ES begin jaren 90 anyone?)... maar voor de rest lijkt het mij een aardig potente speler. Zeker voor het geld! :o :D
Duck Twacy
#5
Citaat van: Shorty op september 22, 2006, 23:42:16
VrGr,
Bart J.
Je kunt ook gewoon een cd speler kopen.
diy gepruts, nogal een belediging voor veel huisvlijt dat je her en der op inet kunt vinden.  >:(
bv
zonder toestemming van, maar met respect voor de bouwers.
2500 euro is wel nogal aan de prijs, cd pro2 loopwerk kost rond 220 euro...
Gydotron
Juist ja, zonder display, voeding, behuizing, Tentklok, Dac, afstandsbediening enz.
Je mag deze speler gerust vergelijken met eentje die 2x zo duur is!
Grtn  Guido
beunky
#7
Dat is inderdaad wel een beetje kort door de bocht Duck...
Afgezien van de genoemde punten zal dit ding ook wel de nodige research-uren in zich hebben en daarnaast moet er nog wat op verdiend worden...
Als ik alles zo hoor over die speler en ook als ik de componenten zie, denk ik dat de prijs best redelijk is.
Ik vind hem zelf niet geweldig om te zien :-X, maargoed, dat is een smaakkwestie...
Audiofiel
Niet lelijker dan de meeste andere high-end CD-spelers... :P
Zou me trouwens wordt wezen hoe hij er uit ziet. Het gaat er om hoe hij klinkt! :D
hifiman
Ik vond de perspex uitvoering (zoals die voorheen op Guido's site stond) toch een stuk mooier  :)
Duck Twacy
Uiteraard is het enige wat echt telt de klank. Toch zou ik voor deze prijs eerder denken aan een productie model (Lyngdorf of NAD master bv). Maar misschien verandert dat na een luister sessie.
Vind dat de foto's op de site best wat meer mogen tonen. Hoe gaat het klepje open wat voor afstandbediening zit erbij? etc. Hoe is de opbouw van de kast (plaatstaal?).
Toch wel leuk dat Tentlab zoiets op de markt brengt. En natuurllijk moet de pijp ook roken in hun lab.
Citaat van: Audioloog op september 24, 2006, 10:52:13
Ik ook!
Citaat van: Audiofiel op september 24, 2006, 10:00:49
Ik vind de meeste dan ook lelijk... :)
CiteerZou me trouwens wordt wezen hoe hij er uit ziet. Het gaat er om hoe hij klinkt! :D
Uiteraard. Maar uiterlijk is voor mij toch wel gewoon een keuzepunt. En voor velen denk ik wel.
M
#14
Hier een link naar een test van deze speler, het beloofd wel wat. Met een mooie foto van de plexi  :D
http://www.tentlabs.com/Products/diycd/assets/57-59_ME_nr5_06.pdf
Wie van de kenners hier, onderwerpt deze speler eens aan een test. En voordat jullie zeggen waarom jij niet, ik ben niet zo'n kenner :D
LG G2 83
Panasonic DP-UB824
Apple 4K 2022
JBL Bar 1300 MK2
B&W PX 8 S2
DA BoSS
#15
vrees wel dat 't lastig word de zelfgebouwde cd-speler uit de kit weer door te verkopen, tweedehands :-\
tiptop
Ik vind beide uitvoeringen wel mooi om te zien. :-*
Alleen mogen van mij ook de houten paneeltjes vervangen worden door aluminium.
Ik ben ook erg benieuwd naar de klank.
Zou die ook op de VAD-show komen 8) ???
S1; Primare SC15/Trans Audio GT/Marantz UD7007/ Monitoraudio Silver 300 G7/ Isotek Orion/AQ Dragonfly Red en Cobalt, Jitter bug FMJ, Dragontail, AQ Nightowl/ Panasonic TX-58JX800/ heel veel neppe en echte AQ kabels.
S2; Fiio K13 en Darkside/ Trans Audio N2/ Duson 2202/ Maithur TR60/ Echte en nep Nordost kabels
Wijx wondere wereld
#17
Citaat van: DA BoSS op september 24, 2006, 18:50:29
bijna onverkoopbaar 2de hands spullen. Ik heb ervaren dat hoe goed het ook klinkt, je er maar weinig voor terug krijgt.
Ik vind 2500 ook wel erg veel voor een zelfbouwcdspeler. Ik snap best dat de researchkosten er ook uit moeten, maar ik vraag me af of er wel markt voor is.
Hopelijk klinkt ie een heel stuk beter als die dac van tentlabs
Versterking: Gryphon Attila
Bron: Benchmark dac 3B
Luidsprekers: Milestones
hifiman
Citaat van: The one and only Wijx op september 24, 2006, 22:13:17
Wat is er mis met die DAC dan  ???
advr
ik zou hem best wel eens naast mijn Unico willen hebben. maar ik weet niet of ie gebalanceerd te beluisteren is. :o
ik zal Guido eens mailen, kijken wat die ervan zegt ;D
Shorty
Citaat van: Duck Twacy op september 24, 2006, 03:15:45
Ik schreef niet "diy gepruts", Duck! Ik heb groot respect voor mensen die de moed hebben zélf dingen uit te vogelen! Ik schreef "SMD-gepruts", omdat je met SMD's met een pincet, een loupe en speciaal soldeergereedschap (of pasta) aan de gang moet. En als je daarmee geen enkele ervaring hebt, zoals ik, dan wordt dat helaas prutswerk....
VrGr,
Bart J.
reMC
Wijx wondere wereld
Citaat van: Audioloog op september 25, 2006, 10:01:51
lijkt wel een straalkachel zo warm klinkt die
reMC
Ik zie dat Jo Mullers 'm op sommige punten beter vindt dan de 47labs Flatfish. Nu ben ik eigenlijk wel verplicht om de Tentlabs te gaan luisteren en ook een oordeeltje te vellen >:D
B.J.
Citaat van: reMC op september 25, 2006, 15:57:54
We kunnen van te voren wel vertellen welke jij beter gaat vinden  >:D >:D >:D ;) ;D
