Iemand hier met een Onkyo receiver en een subwoofer ?
Gestart door Led, juli 12, 2006, 13:06:15
Led
Ik probeer m'n sub aan de praat te krijgen,
kan het zijn dat ik "double bass" in de setup aan moet zetten voor ik m'n cd's met gebruik van subwoofer afspeel ?
DA BoSS
ik vond dit op het net voor je
CiteerOnkyo receivers remain to this day the easiest to navigate in my experience. The setup menu is broken into submenus with specific options and you use a combination of up/down/left/right/enter/return to set all of the parameters. There is a test tone for setting equal volume to each speaker, a distance menu, crossover adjustment, speaker size selection, and miscellaneous options for mono audio and Dolby Prologic II.
Speaker configuration: you can select subwoofer on/off and select Large, Small, or None for the connected speakers. The selection is divided into front, center, surround, and surround back zones. If you specify Small for the front speakers all of the other speakers must be set to Small or None.
Distance setting: you can adjust the distance of each zone in increments of 1ft from 1ft to 30ft. The center channel and subwoofer must be within +/- 5ft of the front distance. The rear zones must be within +5ft / -15ft of the front distance. Hence if your front speakers are 5ft away your surround speakers can be a maximum of 10ft away, not 30ft.
Level calibration: you can adjust each speaker from -12dB to +12dB in 1dB increments. The subwoofer can be adjusted from -15dB to +12dB. You get a completely separate level adjustment for the 5.1 analog multichannel input which is great if you use a SACD or DVD-Audio player which may have different output levels from the receiver's built in DAC.
Miscellaenous: you can adjust bass multiplexing (if you have Large main speakers and a subwoofer, choose to send the low bass to one, the other, or both), how to handle mono signals (Left only, Right only, or L+R duplicate), and panorama/dimension/center width/center image adjustment (for fine-tuning surround effect from Prologic II).
