B&W Nautilus luidsprekers CDM SNT (6 stuks)
Gestart door Fox, juli 31, 2024, 12:22:13
Fox
The koop B&W surround luidsprekers, gebruikt in Dolby Atmos opstelling en geven een zeer indrukwekkend en realistisch geluid.
De luisprekers zijn in goede staat en hebben origineel de de Cherrywood kleur en zijn wrapped in witte folie.
De folie is eenvoudig te verwijderen en laat geen sporen na.
Gegevens CDM SNT Wall-mount loudspeaker
Product Summary:
The CDM SNT combines practicality and elegance with an array of technological features.
l Practically designed with its shallow profile and contoured cabinet edges the speaker can easily be mounted to a wall
with the compact bracket which is supplied and fitted to the rear of the speaker.
Available in a choice of real wood veneers to compliment the rest of the CDM NT range.
Technical highlights:
Nautilus™ Tweeter : B&W's Nautilus™ Tweeter technology ensures that the sound remains focused and time-sensitive and that the stereo-image is presented with unparalleled three dimensional accuracy.
Kevlar®: B&W developed and patented the method of using Kevlar® for loudspeaker cones to reduce unwanted standing waves. DuPont originally created Kevlar® for use in bulletproof vests.
Description        - 2-way closed-box system
Drive units          - 1 x 25mm alloy dome high-frequency
                          - 1 x 165mm woven Kevlar® cone bass/midrange
Frequency response - 75Hz – 20kHz ± 3dB on reference axis
Frequency range      - 6dB at 55Hz and 30kHz
Sensitivity                - 90dB spl (2.83V, 1m)
Nominal impedance  - 8ohm (min 4.8ohm)
Power handling - 50W - 120W into 8 ohm on unclipped
Dimensions - Height: 394mm Width: 392mm Depth: 130mm
Finishes - Cabinet: Real wood veneers Cherrywood
              - Grilles: Black cloth
Net Weight - 7.5 kg (16.5lb)
Nieuw prijs:
Speakers:  750 euro p/st x 6 = 4.500 euro
Wrappen:  125 euro p/st x 6 =  750 euro
Ophangststemen 350 euro  =  350 euro
      totaal                              = 5.600 euro
Richtprijs totaal 1.500,= euro,
1e. prijsverlaging naar 1.250,= euro
2e. prijsverlaging naar 1.000,= euro
3e. prijsverlaging naar  950,= euro
4e. prijsverlaging naar  900,= euro
5e. prijsverlaging naar  875,= euro
6e. prijsverlaging naar  850,= euro
Ook te koop in sets van 2 stuks
Ophalen in Hilversum
En meer info ed, vraag maar raak ;-)
Fox
Fox
Fox
Fox
Fox
Fox
Upje en er mag ook een bod worden gedaan.
Staan ook op MP.
Fox
Fox
Fox
Fox
#12
Met een soort pucks die je op de LS bevestigt en die schuif je dan in een houdertje die je aan het plafond hebt bevestigt.
Deze krijg je er bij. Doordat je 3 soorten puck's hebt kun je de LS ook een kleine hoek meegeven richting de luisterpositie.
Doordat ze ook iets los zijn van het plafond heb je ook minder overdracht van trillingen en ruimte om de luidspreker kabels fatsoenlijk aan te sluiten ;-)
Als er meer vragen zijn hoor ik het graag.
Citaat van: reza op oktober 20, 2024, 17:14:00?
Fox
