Hulp bij crossover instellingen
Gestart door CircleRW, juli 23, 2021, 17:16:35
CircleRW
Hoi allemaal, ik ben nu al ruim een week bezig om mijn crossover in te stellen.
Na bijna een week speuren om het internet zie ik door de bomen het bos niet meer.
Wij kan mij helpen met het instellen van mijn crossover ?
Mijn speaker zijn ;
Front Unit
Type 2 Way Bass-Reflex
Impedance 6 Ω
Maximum input power 130 W
Sensitivity 84.5 dB/W/m
Frequency response 55 Hz to 50 kHz
Crossover frequency 4 kHz
Cabinet capacity 5.7 L (0.20 cubic feet)
Drivers unit 12 cm (5") Cone Woofer × 1
2.5 cm (1") Balanced Dome × 1
Terminal Spring type color coded
Other Non-magnetic shielding
Height Unit
Type Full Range Closed Box
Impedance 6 Ω
Sensitivity 81 dB/W/m
Frequency response 80 Hz to 20 kHz
Cabinet capacity 1.0 L (0.036 cubic feet)
Drivers unit 8 cm (3-1/4") Cone Speaker
Center Speaker
Impedance 6 Ω
Sensitivity 86 dB/W/m
Frequency response 65 Hz to 50 kHz
Crossover frequency 6 kHz
Cabinet capacity 2.8 L (0.10 cubic feet)
Dimensions (W × H × D) 420 mm × 115 mm × 119 mm
16-9/16" × 4-1/2" × 4-11/16"
(incl. grille and projection)
Weight 2.3 kg (5.1 lbs.)
Drivers unit 8 cm (3-1/4") Cone Woofer × 2
Keyhole slot Available
Grille Fixed
Surround Speakers
Impedance 6 Ω
Dimensions (W × H × D) 115 mm × 230 mm × 96 mm
4-1/2" × 9-1/16" × 3-3/4"
Weight 1.0 kg (2.2 lbs.)
Drivers unit 8 cm (3-1/4") Cone Speaker × 1
Grille Fixed
Powered Subwoofer
Type Bass-Reflex
Input sensitivity/Impedance
440 mV/20 kΩ
Rated output Power (IEC)
80 watts minimum continuous power,
4 ohms, driven at 100 Hz with a
maximum total harmonic distortion of
1 %
Frequency response 27 Hz to 150 Hz
Cabinet capacity 24.5 L (0.86 cubic feet)
Dimensions (W × H × D) 230 mm × 425 mm × 410 mm
9-1/16" × 16-3/4" × 16-1/8"
(incl. projection)
Weight 7.7 kg (17.0 lbs.)
Audio input 1 (RCA analog mono)
Drivers unit 20 cm (8") Cone Woofer × 1
Power supply AC 220 -240 V, 50/60 Hz
Power consumption 20 W
Other Auto Standby function
Ik kan op mijn ONKYO HT-R695 alleen maar deze crossover instellingen invoeren;
Front : Full Band, 40, 50, 60, 70, 80, 90, 100, 120, 150, 180, 200 Hz.
Center : 40, 50, 60, 70, 80, 90, 100, 120, 150, 180, 200 Hz.
Height : 40, 50, 60, 70, 80, 90, 100, 120, 150, 180, 200 Hz.
Surround : 40, 50, 60, 70, 80, 90, 100, 120, 150, 180, 200 Hz.
LPF van LFE : 80, 90, 100, 120, uit.
stevefilmfreak54
Een goeie begin is alles op 80hz zetten, luisteren en aanpassen.
PascalP
Citaat van: stevefilmfreak54 op juli 23, 2021, 19:12:44
Wel die laatste optie (LPF for LFE) op 120 laten staan.
Sources: Oppo UDP-203 Cinemike Stufe 2 - Apple TV 4K 2021 - Technics SL-1210MK2 + Ortofon Bronze + Parasound Zphono - Cisco Meraki MS220-8P
Deleted User
Welk merk luidsprekers zijn dit? Ik zie het niet echt staan..
