REL Quake uitzetten
Gestart door ll0ll, juni 29, 2019, 09:58:39
ll0ll
Ik heb sinds kort een REL Quake, er zit geen aan/uit knop op. Hoe zet ik de subwoofer uit? Ik kan er in de handleiding niks over terug vinden. Had vroeger een BK Gemini, die had netjes een aan/uit knop..
Iemand een idee?
Philips LHH1000 | Philips LHH900R | Marantz Project D1 | Philips LHH A200 | Philips LHH300R | Shure SHR1540
http://www.dutchaudioclassics.nl
ll0ll
Ah wacht, toch gevonden in de handleiding  :pompom:
Citeer
POWER SAVING EFFICIENCY
All REL Sub-Bass Systems are designed for maximum power efficiency, both when passing a signal through to its resultant output sound into the room and also when silent.
REL circuitry is designed for "power starvation" operation under no signal conditions. This means that immediately when there is a gap in the signal the sub is instantly at maximum power saving efficiency, yet remains at maximum readiness to respond immediately to a sudden transient signal, such as an explosion in a movie, even after a long quiet period and at whatever level.
This compares to some "auto power on/off systems" which remain powered up for a set period of no- signal condition (up to 10-15 minutes) and which need to power-up on receipt of a sudden transient thus failing to catch the start of that transient. There is also the possibility of the sub remaining inoperative during listening sessions where the overall volume is low.
It is not necessary to switch off between listening sessions - it will not significantly shorten its life by leaving it switched on. On the other hand, it will not harm sound quality if it is always switched off. The power consumption in the quiescent (no signal) state is negligible. REL's power starvation technology uses less than 4w when idle (less than 1/25th the power of a standard light bulb).
jeepee
4 watt hele jaar is niet negligible. Daar kan je 30 keer een wasmachine mee draaien.
Ralf67
Citaat van: jeepee op november  9, 2023, 17:35:374 watt hele jaar is niet negligible. Daar kan je 30 keer een wasmachine mee draaien.
Met 4 watt ? Lekkah, welke machine is dat ? Die wil ik ook.
Refie
0,004kW*8760=35kWh per jaar aan verloren energie. Een "goede" was op een gemiddelde wasmachine 1kWh/wasbeurt.
resultaat 35 wasjes.
De Rel uitlaten staan kost je (gelang je contract) 35x0,33=€11,55 per jaar.
Wassen is eigenlijk best goedkoop.
Loxone, Tesla
wasbeer2006
Jaen zo staan er waarschijnlijk lijk nog 20 dingen aan in je huis die 3 a 4 watt gebruiken.
Zo baal ik er ook van dat er geen harde aan/uit op een quoker zit, dan zou je die met een tijdklok de hele nacht uit kunne zetten, maar dat volledig offtopic 8)
TV              - LG C2 2022 65 inch
Game          -playstation 5
Reciever      -Denon AVR x6700
B&W 702 S3         -premium 22 Center.  Sub             -Peerless 13" Sub Rear            -Vifa premium 11 rear
