bluMe True Hi-Fi Bluetooth Music Receiver 24bit /192kHz AK4396 chip SNR of 120dB
Gestart door Sonority audio, januari 29, 2016, 22:48:48
Sonority audio
Experience stunning, high resolution wireless audio quality thanks to its cutting edge electronics.
Features the AK4396 Chip by AKM
It's a true Hi-Fi 24bit / 192kHz upsampling audiophile DAC sporting a high SNR of 120dB
                 ENHANCED BEAUTY, OUTSTANDING SOUND
True Hi-Fi experience that blends with the finest high-end audio components.
Citeer
About Us
Founded in 2013, Auris, Inc. is team of friends, engineers, audio geeks, designers and explorers based in Las Vegas.
We are bound together with one sole purpose in mind: creating audio solutions that simplify and enhance modern lifestyle.
We believe in simplicity in design and deftness in function.
In the age of streaming, our goal is to liberate music from the slavery of stationary listening and to give it the freedom modern wireless technology allows.
At Auris, Inc. we continually strive to work on products that provide people with an enduring magical experience of convenience and musical pleasure.
CiteerExperience True Immersion
Audiophile DAC
bluMe is more than a Bluetooth music receiver; it's also a Digital to Analog Converter (DAC). Digital tracks are simple sequences of code. To turn this code into a signal that speakers can recognize, you need digital-to-analogue converters (DACs for short). bluMe features the world renowned 'Miracle DAC' AK4396 by AKM. It's a true Hi-Fi 24bit / 192kHz upsampling audiophile DAC sporting a high SNR of 120dB that is well regarded for its impressive low noise and low distortion characteristics. In short, this means that the sound you hear is crystal clear, rich and retains a wonderfully full dynamic range.
CiteerPure Digital Sound
Bluetooth, aptX® & AAC
bluMe applies the latest in Bluetooth technology, the Bluetooth 4.1 to stream any format of music from your smart device, laptop or PC. Most devices use the basic SBC Bluetooth music codec. While this may be okay for some, but if you want great quality, it's simply not good enough. bluMe uses Advanced Audio Coding (AAC) and aptX®, a superior performance digital audio codec. This combination of advanced hardware and firmware preserves all the musical detail, dynamic range and full bandwidth response, bringing out the best possible sound from your digital sources, for a sound that is far superior to standard Bluetooth streamed music.
CiteerAlways Synchronized
aptX® Low Latency
The delay between your TV and speakers is a common problem within many wireless audio solutions. With bluMe, enjoy great movies knowing that picture and sound will always sync perfectly. bluMe features the latest aptX® Low Latency technology that reduces this latency down to less than 40 ms, eliminating lip-sync issues to give you the smoothest audio/visual experience available.
FAREWELL TO AUDIO DROPOUTS
Superior wireless solution allowing you to enjoy your music while you move around your home with no loss in audio quality.
CiteerEnhanced Wireless Range
High Gain Antenna
Limited range and signal dropouts have traditionally plagued Bluetooth audio systems. To combat this issue, bluMe employs special circuitry and a precision-tuned external high gain antenna to extend the wireless range, ensuring consistent, stable, strong, and glitch-free performance for 30 meters (100 feet), providing much more versatility than other Bluetooth receivers.
CiteerClear Frequency
High Interference Tolerance
bluMe's cutting edge technology maintains a robust and balanced wireless sound experience that is unaffected by interference from surrounding wireless networks. This results in superior 24-bit, upsampled audio that will completely redefine your perception of wireless sound.
SEAMLESS INTEGRATION
bluMe is designed to integrate perfectly with your favorite products for true high resolution audio.
CiteerDesigned for Connectivity
RCA & Optical Out
bluMe has two high quality gold-plated RCA jacks that operate as analog outputs. Any audio system with a standard analog audio input can connect to bluMe with the supplied RCA-RCA signal cable. For systems that have 3.5mm "mini" jack input, use the supplied RCA-mini cable. bluMe also features a Digital Optical (SPIDF) Out so that you can connect to an outboard DAC or the digital input of a surround receiver, giving you a 100% pure high-res digital signal through to your sound system.
CiteerPlay, Plug and Pair
Simple, Easy Setup
Pairing any smart device to bluMe is a breeze. Simply push the control button on the front of the unit briefly and it automatically goes into pairing mode. Activate Bluetooth in your smart device, select "auris bluMe " from the list of available devices and you're ready to rock! bluMe can connect to one smart device at a time, but is capable of remembering up to 8 devices. When more than one device needs to stream through bluMe, just turn Bluetooth off in the first device, turn Bluetooth on in the second, and select "auris bluMe " as the device. There is no need to reset bluMe and press its control button a second time once the device is stored. Even powering bluMe is easy. Draw power from a wall socket, or from the included USB cable, which means you can power it directly from your PC, Laptop, and more recent TVs and sound systems.
ENDLESS POSSIBILITIES
Tune in to your favourite music apps, like Last.fm, Pandora and Mixcloud,all wirelessly in Hi-Fi quality.
CiteerUnlimited Music Access
Every Song, Wirelessly
bluMe can play any audio source a Bluetooth enabled device can access, opening up a virtually unlimited universe of music to enjoy through your Hi-Fi audio system. So you're always in control not just of the music that's stored on your device but also access music streaming services such as Pandora and Spotify, internet radio stations, podcasts and even music libraries connected to a wireless home network...all instantly, wirelessly in Hi-Fi quality.
CiteerSolid, Premium Finish
Aerospace Grade Aluminum
Result of an elaborate manufacturing process, the chassis is extruded out of aerospace grade aluminum and high quality anodizing provides optimum protection and finish. bluMe is a premium product in every sense which completely blends while sitting next to even the costliest and most attractive home audio components.
CiteerSounds better than Wired
High-end DAC, aptX®Low Latency, AAC
Vast majority of us tend to hard wire our smart devices to an audio system by either using a dock that pulls analog out of the device or by hooking up to the headphone output jack. In both cases the digital signal is processed by cheap low fidelity DAC used in all smart devices. With bluMe the digital signal is processed by its high-end DAC and audio decoders. No wonder bluMe sounds better than wired hookups!
TECHNICAL SPECIFICATIONS
ONLY THE FINEST WILL DO
Comparison:
Informeer en bestelling bij:
[email protected]
prijs 179,- incl verzending.
www.sonority-audio.nl
Schiit audio : www.schiit-europe.com
Ludic Audio Cables :new Affordable standards
Mrspeakers: www.mrspeakers-europe.com
Soundaware streamers : www.soundaware-europe.com
