NEW! Schiit Vali 2 Tube Hybrid Headphone Amplifier
Gestart door Sonority audio, december 31, 2015, 12:27:54
Sonority audio
Welcome to the most affordable serious tube hybrid amp on the planet—with performance and versatility that eclipse amps costing much, much more.
The all-new Vali 2 is a great way to get started with tube sound, without needing a second mortgage!
The Most Serious Tube Design—Far Beyond its Price
Some inexpensive (and not-so-inexpensive) tube amps don't use tubes to their full potential, "starving" them with low plate voltages or using op-amp buffers for output. Not Vali 2. Vali 2 uses a unique, class-leading power supply that gives us 60V on the plate. Combined with a fully discrete, current-mode noninverting hybrid topology, Vali 2 redefines what you can expect from an affordable tube amp, even at 2x its price.
Roll Your Own Sound
Vali 2 is supplied with a single NOS 6BZ7 tube, which can be swapped for the same tubes we use in Lyr 2 and Mjolnir 2—feel free to use virtually any ECC88, 6922, 6DJ8, 2492, etc to "roll" the sound to your own preference. Plus, you only need a single tube, so rolling is easy and more affordable!
Serious Power, Gain Switching, Preamp Outputs
Vali delivers 1W into 32 ohms for hard-to-drive headphones—and, at the same time, offers a low gain mode for low-noise performance with sensitive headphones. You can also use the preamp outputs to add a tube preamp to your power amp or powered monitors.
Made in USA. Really.
By "made in USA," we mean made in USA. The vast majority of the total production cost of Vali 2—chassis, boards, assembly, etc—goes to US companies manufacturing in the US. Our board house is 20 minutes away from our office in Newhall. Our chassis guys are just over the hill in the Valley. Yep, the wall wart is from China, but there you go. There is some give and take to reach this price point.
Specs:
Citeer
Frequency Response: 20Hz-20Khz, -0.2db, 5Hz-150KHz, -3dB
Maximum Power, 16 ohms: 1300mW RMS per channel
Maximum Power, 32 ohms: 1000mW RMS per channel
Maximum Power, 50 ohms: 650mW RMS per channel
Maximum Power, 300 ohms: 270mW RMS per channel
Maximum Power, 600 ohms: 140mW RMS per channel
THD: <0.03%, 20Hz-20KHz, at 1V RMS, low gain
IMD: <0.05%, CCIR, low gain
SNR: >99db, unweighted, referenced to 1V RMS, low gain
Crosstalk: -68dB, 20Hz-20KHz
Output Impedance: 1.2 ohms in low gain mode, 5.8 ohms in high gain mode
Gain: 5 (14dB) or 1.25 (2dB)
Topology: Tube voltage gain with convolved bipolar current mode inverter and discrete bipolar class AB output stage
Protection: delayed start and fast shut-down with muting relay
Power Supply: wall wart with 24VAC and 6VAC outputs, regulated HV and LV rails for tube and bipolar components, 6V AC heater
Power Consumption: 9W
Size: 5 x 3.5 x 2.75"
Weight: 1 lb
FAQ:
Citeer
What? A Vali 2 with preamp outputs! And more power! And a gain switch! And that allows you to roll tubes, like, externally, like a real tube amp? For only 189,-?
-Yes, we see you have a good grasp of the particulars of this amp. Congratulations! You probably do very well in school.
And this thing is powerful enough for inefficient headphones and quiet enough for IEMs, as in, I can use it with pretty much all of my headphones?
-Yes. Pretty much. It may not be ideal, say, for HiFiMan HE-6s, which are very, very hard to drive. Beyond that, yep, it's a great little tube amp that you can use with almost anything.
And I can connect those preamp outputs to my powered monitors on my desk?
-Yep! Or a power amp. It's a nice little single-input tube hybrid preamp.
Hey, I'm new to tubes, how long do they last?
-About 5,000 hours, give or take. Probably longer in Vali 2, since the tubes are run very conservatively. And...don't panic. Humans lived for decades with only this electronic technology at their disposal. We even went into space and stuff with it.
And when the tube goes bad?
-You replace it. We sell single 6BZ7 tubes, matched to 2%, for $10. But there are a lot of other options out there, including 6DJ8, 6922, ECC88, 2492, and even more. Pretty much any tube with a 6DJ8 pinout, 6V heater, and 600mA or less of heater current will work fine in Vali 2.
So wait, how do you match a single tube?
-Good question! The tubes we use are "double triodes," meaning they have two triodes per tube (how else could a single tube work in a stereo amp?) The two triodes inside each tube have to be matched for gain, or else there may be some channel imbalance. When you order tubes for rolling, make sure both triodes are matched (some tube resellers call them "sections.")
-Ah, I said I was new to this tube thing, I don't want to spend megabucks on getting a dozen different tubes to try!
That's fine. The tubes we supply are very nice. Sit back, relax, and enjoy them!
-But...heck, why should I buy a Lyr 2 when you have this?
Lyr 2 is a much more powerful and capable amplifier. It looks about 10,000x more manly sitting on your desk. It has a lot more aluminum...yeah, we're reaching here. Bottom line, both are very good choices, but Vali 2 is a perfect way to get started with tubes without spending a ton of money.
So you probably cheaped out and left the protection off this amp, or something stupid like that, right?
-No. Vali 2 has a relay mute for delayed startup and fast shut-down. You can leave your headphones plugged in all the time.
So what's this big deal about the power supply? 60V doesn't seem like a lot for a tube.
-Have you asked the other guys what they're running the tube plate at? We're running a full 60V on the plate (not the rail...consider that Lyr 2 uses a 200V rail for 100V on the plate). This is plenty for the tube types we recommend, and it is far in excess of many amps selling for much more than Vali 2.
So how can you deliver those high volts? I bet it's a switching supply!
-Think again. Vali 2's power supply is 100% linear, with regulation on every voltage rail. A unique wall-wart with 2 AC voltages allows us to provide for the needs of the tube heater, the low-voltage rail for the output, and the high-voltage rail for the tube. You may have noticed the funny DIN-plug connector on the amp. Hey, at least you won't mistake this wall-wart for anything else!
Hey, you say "exceptional thermal efficiency," but this thing runs warm!
-Yes, it does. Welcome to tube amps.
Hey, can you use LISST in this?
-Sure you can, but why? Magni 2 Uber is a better, more powerful, and less expensive choice for a solid-state amp.
I heard that ultimate accuracy is the result of exemplary measurements, including vanishingly low THD, low noise, and low output impedance, so I don't know how this thing can sound very good.
-Are you going to let others think for you, or are you going to listen for yourself?
What the hell is Vali?
-In Norse mythology, Vali is the son of Odin and the giantess Rindr. There's this amazing resource called Wikipedia. You may have heard of it.
I want a combined DAC/amp! Why didn't you put a DAC in here?
-We did. It's just in a different chassis and costs another $99 or $149. It's called "Modi 2" or "Modi 2 Uber." Stack with Vali 2 for a combined tube hybrid DAC/Amp.
manual:
http://schiit.com/public/upload/PDF/vali_2_manual.pdf
see our website for prices and for order:
http://www.schiit-europe.com/index.php/
mail: [email protected]
website: www.sonority-audio.nl
Schiit audio : www.schiit-europe.com
Ludic Audio Cables :new Affordable standards
Mrspeakers: www.mrspeakers-europe.com
Soundaware streamers : www.soundaware-europe.com
