Zappiti 4K mediaplayer
Gestart door larsonator, november 22, 2014, 19:51:02
larsonator
jaco
TopGun2010
De vraag is of hij hdmi 2.0 heeft en 4K 60fps kan afspelen. Anders wachten!
papaleo
Kreeg vanavond ook de mail van Zappiti...
En volgens mij heeft de speler geen HDMI 2.0, maar blijft voorlopig steken met 1.4, dus maximaal 30fps
roelk79
helaas geen hdmi 2.0.
specs:
Connectors: HDMI 1.4 CEC, 2x USB 2.0 (at the back), 1x USB 3.0 (side), Audio/Video analogue output, Optical S/PDIF output, Ethernet 10/100/1000 Mb/s, Wi-Fi 802.11b/g/n, SD Card reader / MMC (side), AC connector, AC button On/Off (at the back), LED display on front switchable with a physical button .
homecinema: JVC N5, Blackdiamond G3 106", Marantz AV 7702mk2, Arcam FMJ P7, HDI Dune 3.0, HTPC (Madvr) front Elac 210ce jet, center Elac cc400, rear Elac 203.2, roof Elac WS 1665 sub: BK Monolith, Synology ds1513+,
Stereo: versterker Musical Fidelity A308, DAC Zodiac Antelope, Bluesound node 1,Siltech FTM3 G3, MIT-MH 750, Elac FS210A, HTPC, 55" LG Oled C7
papaleo
Hier de specs...
Processor: Realtek RTD1195.
● CPU: Dual core CPU.
● GPU: Dual core GPU.
● DSP: Video and Audio DSP with hardware acceleration .
● Cache: 512 KB L2.
● Connectors: HDMI 1.4 CEC, 2x USB 2.0 (at the back), 1x USB 3.0 (side), Audio/Video analogue output, Optical S/PDIF output, Ethernet 10/100/1000 Mb/s, Wi-Fi 802.11b/g/n, SD Card reader / MMC (side), AC connector, AC button On/Off (at the back), LED display on front switchable with a physical button .
● Internal storage: Hot swap internal SATA HDD 3.5" rack (not included). To transfer your data, connect your HDD in a docking station for eSATA / USB 3.0 for a high speed transfer between your computer and your HDD. You can also transfer your data via Wi-Fi or Ethernet Gigabit. You can finally copy/paste your files in your internal HDD from an external HDD connected via USB 3.0.
● Media sources: External HDD (USB), USB devices (USB flash drive, USB card reader, etc), built-in SD card reader (SD/SDHC/MMC), PC and NAS in local network (SMB, UPnP, HTTP), other Internet and local network media sources.
● Internet navigator: Opera, Chrome. (Possibility of installing other browsers).
● Widgets: Weather, News, Date and Time. (Possibility of installing other widgets).
● DLNA: Full support of DLNA standard (1.5 or 2.0).
● DRM: PlayReady, Widevine, HDCP, DTCP-IP.
● Video Codecs: HEVC, H.265, MVC, AVC, MPEG-2, MPEG-4, XVID, DIVX, WMV9, VC-1, H.264/x.264, CVD 1.0/2.0, SVCD, AVS, H.253, Sorenson Spark L70, VP8 ; Very High Speed video bitrates supported up to 120Mbit/s.
● Video Files format: 3D BD ISO, BD ISO, BDMV, MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, WMV, DVD-ISO, VIDEO_TS, AVCHD 2.0 (AVCHD 3D, AVHD Progressive, and AVCHD 3D / Progressive).
● Video Output Flexibility: Output video in any resolution and format from SD to 1080p (24p/PAL/NTSC) and Ultra HD (3840p 24p/25p/30p) and 4K (4096p, 24p).
● Video output framerate: automatic (according to the played content) and manual.
● Audio Codecs: AC3, DTS MPEG, AAC, LPCM, ALAC, AIFF, WAV, VSELP, FLAC, Ogg/Vorbis; lossless and audiophiles formats support (up to 192 kHz / 24-bit).
● Multichannel Audio HD: Pass through and stereo downmix.
● Subtitles formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, SUB/IDX external), PGS (BD ISO, BDMV, M2TS), DVBSUB (DVB-T, DVB-S, DVB-C).
● 3D Hardware acceleration: OpenGL.
● Photo files format: JPEG, HD JPEG.
● Audio playback functions: Wide variety of audio playback available via download from the player from Google Play with albums cover arts display and audio lossless support. (HD sound and Codecs support depend on the Apps).
● Supported Formatting: FAT16/FAT32 (read-write), EXT2/EXT3 (read-write), NTFS (read-write), Mac OS enhanced (read-write).
● Ethernet: 10/100/1000 Mb/s.
● Wi-Fi: IEEE 802.11n with 2 antennas.
● Network playback: Special optimisation of the network, guaranteeing better performances of the local network playback no matter which type of media thanks to SMB protocol (3D BD ISO included) via Gigabit Ethernet or Ethernet 10/100.
skank1
Lees ik nu echt goed?
XBMC supported?
papaleo
skank1
This is to good to be true.
XBMC FRIENDLY
You're a fan of the XBMC (Kodi) App? No problem! Zappiti Player 4K is fully compatible with the Android App, already pre installed .
ANDROID PROOF
Zappiti Player 4K is compatible with Android Apps. Enjoy the streaming video services, VOD and SVOD, online music services, internet radio and games. Download all your Apps via Google Play and re organize your own Home Page with all your favorites Apps and widgets too (Weather, News, Photos...).
A universal media center
● Android: Android Apps friendly. Easy access with streaming contents providers, VOD/SVOD, catch up TV, musical playback, social networks, news, weather info, trailers, games, internet radio and more...
● Up-Scaling 4K: Display your videos with an ultra high quality upscaling Ultra HD 4K (3840x2160 and 4096x2160).
● 3D video friendly: Supports most of the 3D video formats such as BD ISO 3D, MVC, SBS, and Top/Bottom.
● Network Player: Connect your player on a local network and enjoy your content from a PC, a MAC or a NAS via UPnP or SMB.
● MKV Player: Playback HD and SD video in MKV containers and other modern video file formats, including top quality HD video with very high bit-rates > 120Mbp/s.
● HDD Rack Option with Hot Swap Function: Easily and quickly insert and exchange internal 3.5'' SATA HDDs.
● USB Ports: Conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices without a USB hub.
● USB Port 3.0: Read or copy your files in high speed.
● Full Range of A/V Connectors: S/PDIF Optical Audio outputs, AV analogue output via an adaptor, HDMI CEC outpout to simplify the connection of any device.
● Multichannel home cinema audio: bitstream, downmix stereo.
● High-Quality Music Playback: Plays very high-quality (up to 192 Khz / 24-bit) music files in various formats. (FLAC, AIFF, ALAC, WavPack, Monkey's Audio APE, DTS, AC3, etc.).
● Video Output Flexibility: Output video in any resolution and format from SD to 1080p (24p/PAL/NTSC) and Ultra HD (3840x2160, 24p/25p/30p) and 4K (4096x2160, 24p).
● Many shortcuts and advanced playback features:
Caps 1 to 9: Direct access from 10 to 90% of the file.
Cursor left and right: 10s rewind and forward.
● Playback memory: Resume playback from the last position.
● Long range IR remote: The Zappiti Player 4K is provided with an IR remote. Possibility of learning the remote with a universal remote.
● Air Mouse / Long range RF keyboard: Android Apps can be controlled via a RF Air Mouse. The backside of the remote feature a keyboard.
● Computer Mouse Friendly: Connect a computer mouse (air or not) to control the player and Android Apps.
● Advanced File Browser: Convenient file browser with powerful file management (copy, move, delete, rename, organize, sort).
● Open GUI: Add your own Android Apps, customize the Home Page of the player, add any widgets (weather, news, date and time...).
Zappiti Media Center V4 friendly
● Zappiti Media Center interface: Cover arts exploration system for your Movies, TV Shows and musical files with presenting informations (subtitles, actors, director, release date, ...). Automatic indexation of Movies and TV Shows by category.
Attention! A PC or a Mac is needed to run the indexation. An internal analyzing system is still at work.
● Search Engine: Easy access to your movies or TV Shows thanks to Zappiti powerful search engine combined with smart filters (actors, director, length, ratings, release date, ...).
● Zappiti edit functions: edit or delete the movie covers directly via the remote control.
Change the posters, edit the groups, edit the synopsis, change the genre of the movie, etc....
● Zappiti on start: Launch automatically Zappiti Media Center on start of the player via Android AutoStart App.
● Video sharing: Share your videos with your friends or family (require the possession of a Zappiti Player 4K or a MAC or PC).
Ik snap het niet zo goed, de android app...
Kun je dan starten en direct in xbmc komen?
skank1
Wel jammer van de chip, -> dual core, geen quadcore...
dvd-fan
Als de software maar niet zo crappy is als die van de open hour van popcornhour. Xbmc schijnt nog geen dtsmaster dolby HD te spelen.
Kijk maar een op het forum van openhour
Robin
Zappitti one , Denon X2600H, Panasonic 4k TV, Phonar LS
skank1
openhour is een ramp ja
Echter als je puur specs gewijs kijkt, is deze player veel te duur.
Andere spelers die dezelfde chip hebben en net hetzelfde kunnen voor half de prijs.
Bv eentje om te noemen:
http://en.mele.cn/products/show/37.htm
Mele heeft ook nog een andere 4k player die wel quadcore is :
http://en.mele.cn/products/show/36.htm
papaleo
In hoeverre word dit de tegenhanger van de aangekondigde Open Hour Chameleon speler,van deze speler is ook niet bekend dat deze HDMI 2.0 aan boord heeft...heeft dan wel een quadcore chip
skank1
Op het xbmc forum kun je heel veel lezen omtrent deze playrs, de open hour belooft echt niet  veel goeds... en kan idd zelfs geen hd audio (tot nu toe)
Mensen die hem reeds in bezit hebben, hebben hun review daar gezet.
De Vidonme player, zou voorlopig de enige zijn die xbmc en 3d iso kan afspelen, maar die heeft dan weer andere problemen lol
skank1
En mede8er blijft in dit ganse verhaal ook heel stil... Komen zij nog met een nieuwe 4k player based op deze realtek chip? Who knows.
skank1
Openhour is trouwens based op de Rockvhup RK3288 chip, die is quadcore Cortex-A17 series CPU lopend op 1.8GHz en ARM Mali-T764 GPU
Die kan hdmi 2.0 hebben,  maar daarom doen ze het niet allemaal
road rebel
#16
Voorlopig geen HD surround op de zappiti, de Fransen hebben wel een prototype draaien die het kan maar die zou niet kosjer zijn qua licenties. Hij kan meerdere weergave frequenties aan (niet enkel 60Hz) maar dat is voorlopig volledig gelinkt aan resolutie. Standaard upscaling naar 4k is 30Hz, voor 60Hz moet die terug naar 1080p.
Behalve xbmc worden nog andere Android apps ondersteund.
Wim76
Waarom komen bedrijven nou gewoon niet met een 4k speler die wel de juiste tools aan boort heeft?
Waarom niet gelijk een bouwen met hdmi 2.0 etc etc
Denon x4000 | Denon 1713 | Infinity kappa 70 | Dali LCR center | Dali zensor 1 rear | SVS PB12 nsd | AC ryan mediaspeler 3.5TB | Samsung 40UE8000
skank1
Momenteel Heb je de 2 interessantste chips realtek 1195 en rockchip 3288
Verder dan dat is er niks!
Zoiezo wordt alles android, dat zie je zo al.
Ik vrees dat zappiti hier ech niet goed aan doet. Los daarvan zou je moeten dom zijn voor zappiti te gaan terwijl alle andere spelers based op de realtek net hetzelfde doen voor half de prijs.
Enkel voor zappitis gui het dubbele te betalen is me te gek voor woorden.
Firmware staat nog bij beide spelers in kinderschoenen.
Ze beloven allemaal hd audio en 3d maar er is nog geen enkele die beide kan met de huidige firmware.
jaco
De codecc kosten houden ze ook het liefst verborgen volgens mij.
Je ziet dat ook met Atmos,  auro3d nu, de een vraagt 149 € er voor Auro3d de ander 2500€
De standaard Dolby en DTS HD codecs kosten denk ik niet heel veel.
marz01
opvolger voor mn dune d1 met 4 maal 2tb via usb...
Hopelijk hier geen beperking voor maximale formaat externe harde schijf >4tb?
Ondersteuning voor IOS bediening?
Of toch maar voor een flexibeler Intel Nuc gaan?
pana 65st50E , b&w m1,velodyne spl1000ultra, apple tv4, synlogy ds216j, yamaha rx-v673, subdude
Robbo
Citaat van: jaco op november 23, 2014, 09:23:28
Ik snap dat wel.  De ene fabrikant zet duizenden apparaten om, en de ander als ze geluk hebben een paar honderd.   De implementatiekosten om het op hun platform betrouwbaar werkzaam te krijgen zullen niet veel verschillen.
TopGun2010
Ik begrijp niet waarom ze niet even wachten tot geheel duidelijk is wat de specificaties van hdmi 2.0 zijn.
stevefilmfreak54
Citaat van: skank1 op november 22, 2014, 22:23:16
€114 is niet duur voor deze speler, jammer dat alles uit china zo onbekend is, toch?
skank1
Citaat van: marz01 op november 23, 2014, 11:39:15
Nu een nuc kiezen is immo niet zo slim. We staan op punt van een nieuwe generatie.
De zappiti heeft niks meer met dune te maken
