DVD spelers voor € 75,00 !!!!
Gestart door J.A.F._Doorhof, oktober 28, 2003, 12:12:22
Tijdelijk in de aanbieding:
YAMADA DVD 5520
Features:
• This DVD player has been modified to provide multi-region playback
• Multiple Format Disc Supporting:
CD,MP3,VCD,SVCD,DVD, CD-R,CD-RW, Kodak Picture CD(JEPG)
• Dolby digital
• Dolby & DTS SPDIF Digital out
• 5.1channel Output
• 10-bit video decoding
• Video Decompression: MPEG-1, MPEG-2
• PAL / NTSC playback
• 192K/24bit (5.1ch)
• 3D Surround (Virtual Surround)
• SCART cable not included
Citeer
Product Description:
The Yamada DVD-5520 is a top-quality DVD player without a large price tag. Offering outstanding value for money, the slimline Yamada DVD-5520 DVD player features multi-region playback straight out of the box and a host of features, including 5.1 channel-surround output, Dolby Digital decoding and multi-language support.
The Yamada DVD-5520 is more than just a DVD player, as it will also play MP3 CDs, Kodak Picture CDs and JPEG picture CDs. When viewing JPEGs you can set the player to run them continuously with different transition fades between images. The player is also compatible with the following forms of CD media: CD+G, DVD, VCD, SVCD, CVD, MP3, CD Audio, CD-R, DVD-R and DVD-RW readable.
At the back of the player you will find an array of connections including optical and coaxial outputs, SCART, S-video, RCA analogue audio and video connectors and Dolby Digital 5.1 audio outputs. When played through a suitable amplifier, Dolby Digital 5.1 delivers truly awesome audio that puts you in the middle of the movie action. The Yamada DVD-5520 will also play back NTSC DVDs on a PAL only television.
The user manual, although quite short, is very easy to understand and gives you clear guidance on which audio/video setup gives the best results. The full-function remote control allows you to access all of the player's options/features including zoom, multi-angle, volume up/down as well as all the standard DVD playback controls.
Bestellingen kunnen per mail.
MvrGr.
Snel beantwoorden
Naam:
E-mail:
Verificatie:
