netwerk-functie Marantz AV8003 versterker laten werken
Gestart door THX-UltraII, augustus 6, 2008, 17:19:32
THX-UltraII
Heb het hele verhaal ook al op het AVS-forum geplaatst dus als men het hier niet erg vindt post ik mijn verhaal even in het Engels:
having troubles with the network function of my new receiver (Marantz AV8003) which I cannot get configured.
I have a wireless network at my home with a wireless router installed at the first floor. My HT is at the third floor with my HTPC on top of my Marantz combi. My HTPC has a build in wireless adapter which connects with my router. My HTPC also has a standard build-in LAN port on the motherboard (Asus P5B-V).
What I want is that my Marantz network player can play the content/media which is stored on my HTPC (mp3s etc). (this is possible because the AV8003 has a build-in Media Player)
So, I was told that I have to make a little network of my HTPC and Marantz. I bought a UTP crossed calble and connected this from my HTPC on board LAN to the Marantz LAN port. Enabled the internal LAN port on my motherboard in the BIOS and started up Windows XP. (running SP2). Noticed that when my HTPC was started up I got an LAN icon in my taskbar with a RED CROSS in it. So next thing I did was putting ON my Marantz. The red cross in the icon changed to a 'searching' icon. After one minute or so I got a yellow triangle with a ! in the LAN icon.
So what do I need to do in order to connect my HTPC to the Marantz with my setup?
antwoorden mag gewoon in het NL  ;D
Durk
ip adressen instellen? Er zal ws geen dhcp server in de marantz zitten.
THX-UltraII
Felicimo
#3
Is een netwerkverbinding via het stroomnetwerk niks? dan kun je de marantz gemakkelijk een verbinding laten maken met je router zonder kabels te trekken.
Of een bridge verbinding met met behulp van een andere wireless router... en op die router sluit je bedraad je htpc en marantz aan.
Kef Q7 / Q5 / Q9c / JBL sub E-150p / Denon AVR-2809 / Denon PMA-1500AE / Denon DBP-2012 / Denon DCD-1500AE / Denon DNP-730AE / Micro Seiki BL-51 met Stax ua7 Toonarm / Ortofon Rondo Red / LG OLED 55inch C7 / BenQ W5000 / Dune HD Base 3D
Wishlist: mooie goeie Phono Pre
sj0er-D
Citaat van: Durk op augustus  6, 2008, 18:02:34
er moet een DHCP client in zitten. een server deelt adressen uit. een client kan ze ontvangen. ik neem aan dat het niet de bedoeling is dat de receiver ip adressen gaat zitten uitdelen?
Wim44
Meestal worden de bedrade en draadloze Ip adressen toegewezen door de router. Die heeft een DHCP en DNS instelling. Als je direct bedraad aansluit aan je HTPC dan moet je dat interface een adres geven of zorgen dat op dit adres een adres door windows wordt uitgedeeld met de DHCP en DNS service aan. In dat geval zal als de receiver indien deze als client zonder vast adres staat ingesteld een adres door de HTPC toegewezen krijgen.
Het werkt exact hetzelfde als bij pc koppelingen. Bij de 8003 werkt het gewoon.
sj0er-D
tevens is het zo dat als er een directe verbinding is via een crossed kabel en beide apparaten staan zo ingesteld dat ze een ipadres zouden moeten ontvangen, ze na een tijdje (1 minuut) een zogenaamd bogus adres krijgen (begint met 169) dit adres nemen ze zelf aan ze geen dhcp server kunnen vinden in het netwerk. een voorbeeld waarin deze "bogus" adressen ook worden gebruikt is als je 2 xbox360 spelcomputers aan elkaar koppelt om met 2 consoles tegen elkaar te kunnen spelen. ze krijgen dan allebij een "bogus" adres in dezelfde reeks en dat zorgt er weer voor dat ze met elkaar kunnen communiceren.
Wim44
Plaats eens een configuratieoverzicht van je internet aansluiting, de router en alle aan de router aangesloten apparatuur, zowel bedraad als draadloos. Wat zijn de IP adressen van de apparatuur achter de router. Geef merk/type aan van router, van de PC windowsXP Home of Pro, 32bit/64bit Vista 32bit/64bit, bedraad lan of draadloos, welke merk/type indien USB sticks gebruikt worden, ook ndien geintegreerd in PC, router merk/type/model.
Adressen kunnen dynamisch en statisch worden toegewezen op verschillende manieren.
- Als je een router gebruikt, wat meestal het geval is, dan worden de adressen automatisch toegewezen, als DHCP in de router aan staat. Je kan de adressen ook zelf toewijzen, maar dat is in de Home omgeving niet de meest gebruikelijke methode
- bij de MARANTZ AV8300: gebruik alleen een cat5 of betere kabel. Gebruik geen X-kabel (cross-kabel), dus wel een normale ethernet lan kabel (straight cable), dus niet een kabel om pc's direct zonder router of hub of switch met elkaar te koppelen, dat werkt niet altijd.
- de internet verbinding via de router wordt voor updates gebruikt
- de PC moet Windows Media Player versie 11 of hoger hebben, of een server programma dat DLNA ondersteunt.
(dat zit ook op HDD recorders en Networked HDD DLNA drives).
zie ook: Marantz Network Player AV 8300 User Guide, die is vrij duidelijk.
