Hifisupply voegt nieuw merk toe aan assortiment: Valhalla Technology
Started by phmeijer, January 10, 2010, 13:33:40
phmeijer
Hifisupply heeft een nieuw merk aan het assortiment toegevoegd dat met name gericht is op het dempen van trillingen.
Dit Deense merk, Valhalla Techology, is begonnen met het ontwikkelen van dempers voor luidsprekers.
Van hieruit hebben zij een hele lijn ontwikkeld die inmiddels bestaat uit specifieke dempers voor luidsprekers, versterkers en spelers.
Daarnaast hebben ze een oplossing bedacht voor het dempen van spikes met speciale voetjes/cups.
Valhalla Technology's well established and highly effective series of vibration
damping loudspeaker feet, VT Feet, are the cornerstone of our sound philosophy.
All Valhalla Technology's products are designed to allow your system to perform at its best.
Speaker feet:
• significantly improved sound quality
• neighbours hear less music
• works for a speaker on a bookshelf or a stand
• suitable for a floor standing speaker on all floor types including carpet
• self-adhesive allowing repositioning without damage to surfaces
Amplifier Feet:
• disc-shaped vibration damping pads designed to be placed under equipments existing feet
• designed for amps and pre-amps
• can be used for other components that require disc-shaped feet (see weight specifications below)
• ensure superior component isolation
• improved sound and video quality compared to standard feet supplied with equipment
• components and consoles operate quieter
• improved stationing and stability of equipment
• prevents damage to surfaces
• self-adhesive designed to allow repositioning
Optical Disc Player Feet:
• designed for CD, DVD, HD-DVD, SACD, Blu-Ray players and game consoles
  e.g. Xbox, Playstation and Nintendo
• can be used for other components weighing up to 10kg that require disc-shaped feet
Loudspeaker Spikes and Spike Feet:
Spike Feet (spike shoes) for customers who prefer to use top quality spikes. Advocates of spikes comment that they improve sound stage, deliver a clearer middle and control low frequency noise.
Our unique decoupling Spike Feet complement the use of spikes by:
• Preventing spikes transmitting and receiving vibrations to or from the floor surface
• Overcoming the issue of spike effectiveness being dependent on floor composition
• Negating resonance and reflection issues
• Providing excellent stationing
• Preventing spike damage to floor surface
Connectors:
VT Banana plug:
Excellent quality audiophile connectors
Speaker cable connector type 236
4 plugs suitable for 1 speaker cable set
Maximum cable dimension: 5mm
Connector diameter: 4,2mm
Contact material: Gold Cable attachment with M4 gold plated terminal screws
VT Spade plug:
Speaker cable connector type 014
Maximum cable dimension: 7mm
Spade diameter: Conic 5,5 - 9mm
Contact material: Rhodium
Cable attachment: Non-rotating V shaped terminal piece with 9mm finger screw
VT RCA plug:
Signal cable connector type 171
Maximum cable dimension: 8mm
Connector diameter: 12mm
Cable attachment: Gold plated terminal screws and soldering pit
Extension Socket (Schuko)
• High-end mains power supply cleaner that ensures optimum operating conditions for your equipment
• Enhanced clarity, improved background and presence without the risk of voltage spikes
• Suitable for all kinds of appliances e.g. Hi-Fi, Home Cinema, LCD or Plasma screens, Computers, Consoles etc
• 5 way Schuko female distribution block (integrated filter) with end Schuko male plug
Alle artikelen zijn in de shop opgenomen en op voorraad.
Mochten er vragen zijn dan hoor ik dat graag!
