Sony develops wireless power system for TVs
Started by Starred, October 5, 2009, 07:42:23
Starred
Ahead of the CEATEC Japan 2009 show, which opens on Tuesday, Sony has announced details of a wireless power transmission system said to be suitable for TV sets.
The prototype system is able to transfer up to 60W of electrical energy over a distance of 50cm, with 80% efficiency, or 60% including the high speed rectifier used.  And the company says this can be extended to 80cm with the use of passive extender units, without any loss of efficiency. The Sony system uses "a form of contactless electrical energy transmission technology based on magnetic resonance.
'Electromagnetic energy is only transferred to recipient devices that share the identical resonant frequencies as the energy source, so energy transfer efficiency is maintained, even when misalignment occurs. "Furthermore, even if there are metal objects located between the transmitter and receiver, no heat induction occurs."
The company says that the system is well-suited to powering devices such as PCs and TVs, and adds that "although relatively large transmitter and receiver units are generally required for transferring energy over long distances, passive extender units can be used to relay power between small-sized transmitter and receiver units."
http://whathifi.com/News/JAPAN-Sony-develops-wireless-power-system-for-TVs/
Rob G
Leuk dat ze er mee bezig zijn, maar eerlijk gezegd snap ik deze introductie niet zo goed. 25% meer energieverbruik om zo één kabel minder weg te hoeven werken lijkt mij in deze tijden van energiebesparing niet bepaald iets om wereldwijd reclame mee te maken.
Nahpets
Het zou mij niet verbazen als in veel huishoudens het energieverbruik zal moeten wijken voor de WAF.
I love everybody!
Some I love to be around,
some I love to avoid,
Rob G
Niet alleen de WAF hoor, ikzelf heb ook een plasma i.p.v. 'zuinige' LCD hangen.
Maar ook met draadloze stroom is er een kabel minder nodig, maar de rest moet nog steeds worden weggewerkt. Het voordeel is dus niet geen eigenlijk niet zo relevant.
Miesepies
Ik denk dat het idee is om zowel stroom als beeld draadloos te doen. D.w.z. dat er dus geen kabel naar de tv meer nodig is. Je hebt straks gewoon 1 extra apparaat in je kast staan naast je versterker en dvd/br die stroom en beeld draadloos naar het lcd paneel stuurt. Lijkt mij best wel WAF en vriendelijk en scheelt gekl**t met kabels over muren, kabelgootjes en andere ongein.
