Links naar artikelen over kabels
Gestart door J.A.F._Doorhof, augustus 20, 2009, 12:06:40
Misschien handig om hier wat links te plaatsen naar artikelen over kabels van zowel de mensen die het horen en degene die het tegendeel willen laten zien.
Bij discussie nieuw topic openen met artikel als naam.
SpaceJS
Martijn M
AudioWisdom, Bruce Coppola
Deze site bevat een hoop informatie over de ongelofelijk misvattingen die heersen in de wereld van de hifi.
Dutch & Dutch
Rednaxela
scrutinizer
EVALUATING CABLES OBJECTIVELY
The superior fidelity of WireWorld audio cables can be demonstrated in objective listening tests, which show that they sound more like a direct connection than other cables. They also preserve square wave test signals better than other cables. However, laboratory testing and specifications can be easily misused in cable marketing and are often misleading. Test instruments are useful tools for product development and quality control, but the most important cable parameter of all is value, which can only be measured with human perception.
Some people still doubt that there are any real benefits to upgrade cables. A few double-blind ABX cable tests, which failed to prove that any cable differences were audible, would appear to support that position. However, ABX style listening tests were proven to be ineffective in the development of the compressed audio formats, such as MP3, and are therefore of questionable validity in cable testing. The listening tests performed by the Motion Picture Experts Group (MPEG) and WireWorld are 'ABC-hidden reference' tests, which utilize a 'control' such as a bypass (i.e., a direct connection). WireWorld has promoted double-blind cable tests for over a decade, because they provide valuable answers when they are done correctly.
In the fourteen years since we developed and patented The Interconnect Comparatorâ„¢, our ongoing double-blind cable bypass tests have revealed that the most consistently audible cable effects are the tonal and spatial colorations caused by electromagnetic (inductive) interaction. Material upgrades can provide worthwhile improvements in fidelity, but sonic neutrality and transparency can only be achieved by thoroughly optimizing the inductive properties of a cable until it preserves the natural harmonic structure of a direct connection.
http://www.wireworldcable.com/technology.html
Anton.
Martijn M
Hoe is hun blinde test anders dan een ABX-test? Dat wordt me niet helemaal duidelijk, ook niet als ik op hun site kijk.
Bij mijn weten zijn de MPEG-formaten gewoon ABX getest, of toch in ieder geval dubbelblind.
Dutch & Dutch
Rednaxela
scrutinizer
Citaat van: keyser op augustus 21, 2009, 10:49:48
Hoe is hun blinde test anders dan een ABX-test? Dat wordt me niet helemaal duidelijk, ook niet als ik op hun site kijk. Bij mijn weten zijn de MPEG-formaten gewoon ABX getest, of toch in ieder geval dubbelblind.
Ik heb deze comperator destijds zelf gebruikt (bestaat al even),welke door een wat onpraktische opstelling van bv. voorversterker en cd-speler, met de ruggen tegen elkaar, een ultra korte verbinding tot stand brengt.
Deze korte verbinding neemt d.m.v. een hoge kwaliteit schakelaar, 2 paar signaalkabels in een lus op, waardoor het schakelen van kabel set A, kabel set B en direct C mogelijk maakt.
Anton.
