verschillen tag mclaren av32r
Started by JeroenGRT, June 17, 2009, 07:34:29
JeroenGRT
Ik zag op Marktplaats een Tag Mclaren AV32R incl. 3.80 upgrade, verder staat er niets bij. Deze staat voor 595 euro te koop bij Art Speak.
Zit hier nu ook een 5.1 Analog Bypass op? Wat vinden jullie van de prijs?
Volgens onderstaand stukje nl. wel:
The AV-32Rbp-192
Maybe the most versatile AV processor in the world?
The design brief for the AV32R was simple: create an all-movie-standards AV processor which has outstanding audio and video quality but is easy to set up and use. The result is a benchmark; an audio-visual processor for both the present and the future; sophisticated in its performance and simple to operate.
The AV32Rbp-192 is the 12th upgrade for the AV32R, offering a 5.1 Analog Bypass for connecting SACD and DVD-Audio players; 192kHz / 24bit DACs for improved sound quality; Dolby Pro Logic II as standard; and finally the ability to record digital sources through the analog tape output.
New features in detail:
5.1 Analog Bypass
A '5.1 Analog Bypass' (also called 5.1 pass-through) allows up to six analog inputs to be directly routed to an av processor's analog outputs without being further processed. The signals bypass the av processor, hence the name.
A 5.1 Analog Bypass is required to connect an SACD or DVD-Audio player to an AV processor, as unfortunately these two digital recordingformats have been (so far?) castrated by the decision of the content providers to not allow easy and direct access to the high resolution digital information recorded on the disc.
So instead of a single, high quality digital connection, these players convert the digital information to 5.1 analog outputs: left, centre, right, surround left, surround right and subwoofer (the 0.1). These 5.1 outputs are then connected to an av processors '5.1 Analog Bypass' in order to be able to route them - unprocessed - to its power
Whilst the AV32Rbp-192 cannot correct the fundamental shortfall of SACD/DVD-technology, AV32R owners can now add advanced '5.1 Bypass' technology to their AV32R without being penalised and, as if that's not be enough, our engineers added the ability to alternatively use the 5.1 Bypass to provide three additional Stereo inputs, passing through the AV32R without ever being digitised.
The AV32Rbp-192 gets 192kHz / 24bit DACs
Much has already been written about the enhanced qualities of the new 192kHz / 24bit AK4395 DAC which we recently introduced into the DPA32R and Aphrodite. Those qualities are just as apparent in the AV32R, allowing our Golden Ears to state that the AV32Rbp-192 is not only our latest but also most refined av processor ever.
Dolby Pro Logic II as Standard
There have been many different sound formats over the years which claimed to enhance two-channel stereo through the use of 5.1 or 7.1 loudspeakers. Many took more away than they added, particularly in the enjoyment of music. Well, Dolby Pro Logic II is one of the rare exceptions, establishing itself clearly as the market leader in this field.
Well, reflecting this, we made the decision to ship the AV32Rbp-192 with Dolby Pro Logic II as standard.
Improved Tape Recording
So far, the AV32R limited tape recording to analog recording of analog sources and digital recording of digital sources.
With the AV32Rbp-192 you can now always record the left and right channel output via the tape output independent of the source type. Sometimes even the small things count!
The new AV32Rbp-192 is another clear step forward, demonstrating that the AV32R is really the choice for those who want to stay ahead of the game.
HT: Denon AVC-X3700H, Klipsch RP260F, Klipsch RP450C, Klipsch RP240S, Klipsch RP500 SA, Klipsch RP140SA, BenQ W2700 4K DLP, BK Monolith plus, Vero 4K+, LG UBK90 Ultra HD Blu-Ray Player, Apple TV 4K (2021)
Gezien de prijs lijkt me dat niet, zal dan dit wellicht de 96 hz versie zijn of mischien de SP zonder de BP toevoeging.
Even navragen, indien het een BP versie en 100% in orde is het dit het koopje van de eeuw!
Nahpets
Quote from: Blue-Eyes on June 17, 2009, 07:50:51
Ik heb vorig najaar mijn AV32R BP192 (met heel veel moeite) voor 775 EUR kunnen verkopen.
I love everybody!
Some I love to be around,
some I love to avoid,
Bart_M
Dat lag toch niet aan de prijs? ;D
JeroenGRT
De verkoper geeft aan dat er geen multikanaals analoge aansluitingen op zitten. Kunnen jullie aan de foto zien welke versie het is?
Prijs is dus aan de hoge kant als het de 96 Khz DACs heeft?
Al zou het de de 96 hz versie zijn is de prijs normaal, tenminste uitgaande van de verkoopprijs voor de BP.
Alleen zou ik dan wel op zoek gaan naar een BP versie, die is significant beter en heeft 5.1/7.1 ingangen, handig voor Blu-Ray analoog aansluiten.
Nahpets
Quote from: JeroenGRT on June 17, 2009, 14:18:34
Het verschil tussen de 96 en 192 khz DAC's is alleen te zien aan het typenummers van de DAC's op de printplaat.
Ik zou voor de BP192 versie gaan.
I love everybody!
JeroenGRT
Bedankt voor de reacties, de BP ( by pass?) versie heeft dus alleen analoge 5.1 / 7.1 aansluitingen voor gebruik bij een bluray speler?
Ja, BP betekend ook ByPass.
Nog beter is de DP versie, maar die is fors duurder en nauwelijks aangeboden.
De DP outperformed nog steeds het merendeel van de huidige PRE's, mist alleen HDMI en HD audio.
Nahpets
Volgens mij zijn er in principe 5 uitvoeringen:
1) AV32R 96khz (de eerste versie)
2) AV32R 96khz met BP
3) AV32R 192khz zonder BP
4) AV32R 192khz met BP
5) AV32R DP
Daarnaast zijn er nog een aantal opties (zowel hardware als software) die op ongeveer elke versie kunnen zitten. Denk aan 2 extra kanalen, switches, HDCD, Dolby headphone etc.
Versies 2 en 3 kom je niet veel tegen. Het probleem is dat versies 1 t/m 4 erg moeilijk uit elkaar te houden zijn.
I love everybody!
Nahpets
Op diverse fora wordt/werd inderdaad geschreven dat de BP en 192khz upgrade alleen tegelijk uitgevoerd konden worden. Op de prijslijst van de Nederlandse importeur stonden ze echter apart vermeld.
I love everybody!
Nahpets
Op audiomarkt.de staat nu een zilveren AV32R BP192 in 7.1 uitvoering te koop voor 675 EUR.
I love everybody!
JeroenGRT
Dat is een mooie prijs denk ik, maar even over denken :)
simsatit
Ik heb nog steeds erg veel plezier van mijn dp, laatst zag ik er een te koop voor zo een 1150 euro geloof ik, gewoon even wachten, komen vanzelf wel weer voorbij ;)
>>>see you space cowboy<<<
daihatsu cuore 0.9, bic pen (navulbaar), gemêleerd servies: klinkt allemaal erg goed!
JeroenGRT
Ik heb er inderdaad 1 op het oog, maar deze kost iets meer. Maar goed twijfel nog steeds een beetje tussen een TAG AV32R DP, of een stereo set met theater throughput + processor. Je hebt trouwens een leuke set staan! Ook met zelfbouw bezig zag ik al wel, mooi hoor. En ik zie ook dat je van de TAG eindversterking voor de fronts ben afgestapt, en naar de Classe CA-201 bent overgestapt.
Hoe klinkt dat nu omdat je voor de fronts andere versterking gebruikt dan voor de center en rears?
Audiofiel
Quote from: simsatit on July 12, 2009, 01:26:42
Zo goedkoop heb ik ze nog nooit gezien, tenminste niet een echte DP. Die gaan vaak al richting de 2000 euro. Er staat wel een set van een DP met een Tag eindversterker te koop in het Oosten van het land.
simsatit
Quote from: JeroenGRT on July 12, 2009, 09:29:08
Ik moet zeggen het klinkt nu echt heel goed, mijn filter is nu zo dat het heel zuiver staat te spelen en de Accuton drivers geven een waanzinnig detail, de Classe versterking vind ik heel goed, zeker voor het geld waar je deze nu 2dehands voor kunt kopen (denk aan een CA200 bv, vaak voor rond de 1500 vraagprijs, going rond de 1250-1350).
Classe matcht veel mooier met TAG dan hun eigen versterking (vind ik), let wel ik heb deze vergeleken met een 5x100R, die heeft natuurlijk veel minder power dan een CA-201 het zou kunnen dat de mono's van Tag het ook prima doen, geen ervaring mee.
De dp is gewoon een hele goede dac ook (stereo), samen met een dvd32flr een hele mooie combi, liefst zou ik een buizen ev's en buizen pre en een mooie dac en loopwerk hebben alles gebalanceerd etc. maar $$$... en eigenlijk qua prijs verhouding staat het nu al zo op een hoog nivo te spelen dat ik wel weer even tevreden ben.
Ik ga mijn center nu bouwen (precies hetzelfde als mijn fronts) en ga een Classe ev daar op bruggen), misschien de CA150 van Robbiedobbie, als die hem nog niet verkocht heeft:-).
De rears interesseren me nog even niet zo, misschien als er straks een HELE goede bd speler uitkomt met over de analoge uit bassmanagement en goede speakerinstellingen en een echte goede interne processing/dacs dat ik voor de 4g misschien de rears ook nog wel bouw, maar voorlopig even niet.
Voor films klinkt het echt al super nu.
JeroenGRT
Voor een CA200 wordt doorgaans nog wel meer gevraagd, op Marktplaats staat er nu een te koop voor 2250 euro, dat lijkt me ook wel aan de hoge kant zie http://link.marktplaats.nl/262752035 . Dan lijkt me de Krell KAV-500 nog een betere koop die hier op het forum wordt aangeboden.
Voor de TAG AV32R DP wordt inderdaad ook wel eens meer gevraagd, ik begreep alleen dat ze in 2005 in het buitenland wel voor erg weinig werden verkocht, ik las dat een htforum lid (SOS-Master) er destijds 1599 euro voor betaald heeft!
Audiofiel
De versterker uit die link is de CA-201, niet de 200. De 201 en 301 zijn nieuwere en intern verbeterde versies van de 200 en 300 (bij de 100-101, de 150-151 en de 400-401 is dan niet het geval, die hebben alleen een nieuw frontje gekregen). De 201 is daarmee ook jonger meer waard dan de 200. Maar €2250 is natuurlijk te veel, de nieuwprijs van dit nieuwe model lag op €4900. Ik denk dat die maximaal rond de €2000 waard is. ;)
simsatit
Robbiedobbie heeft een CA300 te koop staan hier op t forum voor even minder dan 2000, ik zou zeggen pm hem eens voor een 'onderhandeling' ;)
Das wel bang voor de buck 8)
Greets
JeroenGRT
Quote from: Audiofiel on July 12, 2009, 14:09:02
:-[ oops mijn fout, ik dacht dat het de CA-200 was, te snel gelezen. Als deze 4900 euro  :o nieuw heeft gekost dan valt de prijs mee.
simsatit
Ik denk dat als je de mp verkoper mailt met een bod van 1800 dat je wel kunt onderhandelen, persoonlijk zou ik voor deze CA-201 niet meer dan 1800 a 1850 over hebben.
Als je echt interesse hebt in een CA-201 kun je mij wel pm-en ik heb een CA-201 en wil eigenlijk upgraden naar BAT eindversterking.
Greets,
Simon
JeroenGRT
Bedankt voor de tip, ik zag dat Robbiedobbie ook een CA150 te koop heeft staan voor 950 euro, op audioreview.com lees ik dat de CA150 niet veel onderdoet voor een CA200.
Of dit waar is weet ik natuurlijk niet aangezien ik ze zelf nog nooit gehoord heb. Is het nu zo dat de Classe in ieder geval wat warmer klinkt dan de TAG 100x5R?
De CA150 is dan misschien ook een leuke optie voor de fronts, en dan een Parasound HCA-1203A 3 kanaals eindversterker voor de center en rears.
Audiofiel
De CA-150 is niet hetzelfde als de CA-200 qua prestaties. Ik heb ze beide gehad (net als de 100, 300 en 400 trouwens). De 100-150-200 reeks is simpelweg netjes oplopend. Ieder volgend model heeft 2 extra transistors per kanaal (4 voor de 100, 6 voor de 150 en 8 voor de 200), meer elco's en een dikkere trafo. Ze klinken ook steeds een stapje beter.
Voor mijn (moeilijke) electrostaten is de CA-200 eigenlijk wel het minimum wil het 'goed' klinken. Voor een ander ligt dat wellicht heel anders. Maar dan nog zal gelden dat de hogere modellen simpelweg beter presteren. Het is dus belangrijk vooraf te weten wat je er aan uit wilt geven. ;D
simsatit
Als je de mogelijkheid hebt moet je deze gewoon in je eigen set gaan beluisteren dan weet je pas echt wat het doet en of het een verbetering is tov jou marantz (ik denk het wel ;)) maar let op, de match met je speakers moet goed zijn, wat dat betreft is het ook verstandig om bv een Krell of een goede Chinese amp te beluisteren (Xindak/Shanling bv), nooit al je geld op een paard zetten voordat je zeker weet dat het het winnende paard is ;D
Ook is zo een zoektocht best leerzaam en leuk voor jezelf en natuurlijk ook voor de lezers op het forum want jij gaat natuurlijk uitgebrijd jou ervaringen neerzetten :P ;D
Greets,
