HDDVD voorbeeld te downloaden, doe het snel
Started by J.A.F._Doorhof, March 5, 2002, 13:06:03
http://mywebpages.comcast.net/trbarry/Its_All_Here.zi
Ik weet niet hoelang dit on-line blijft, maar anders post ik het wel ergens.
Dit is een voorbeeld van wat er met HD-TV en MPEG-4 kan gebeuren.
QuoteI captured the "It's All Here" 1 minute commercial in 1080i and then deinterlaced it and processed it down to 720p at only 24 fps. I then used the open source XviD MPEG4 encoder to make a short file at only about 4.5 mbps, way less than what they are claiming the new HDVD might need.
I've placed this avi file in a zip file on my web page, called Its_All_Here.zip so folks can compare for themselves. I personally think it is as clear as many film based HDTV movies I've watched. I could have used a few more bits but I have limited web space and somewhat above 4.5 mbps some computers may have trouble playing it, at least without hardware acceleration (not available for mpeg4 yet).
Since it is only a 15 second segment (about 10.6 MB) of an advertisement I probably won't get any calls from lawyers, but in deference to AVS Forum policy I won't post a direct link here.
There are no direct links to it at all so in order to get the file you will have to type in the url / filename and then choose "save as".
Un-zip the downloaded file and play it with Zoom Player or most DVD players. You will need DivX4 installed for the codec and some way of playing AC3 sound if you want to hear it.
Anyway, I think that this bit rate, or something slightly more, could do a decent HD-DVD. And it looks like it might take about twice that or a bit more if you wanted 1080p.
Have fun,
MvrGr.
FrankL
Ziet er goed uit!
Beeld en geluid lopen niet synchroon, maar dat hebben veel DVDs ook, dus dat geeft niet  :P
Je moet toch wel een flinke pc met een erg snelle hard disc hebben als je dit op deze kwaliteit kunt capturen! Of zie ik dat verkeerd?
Marantz VP-15S1
Denon AVC-A1SR-A
Oppo 95
rijstfj
Helaas hij doet het niet meer ;D
Gr.
Frans
cinepaulis
#3
Hij doet het nog.
Frank is het laatste lettertje vergeten:
http://mywebpages.comcast.net/trbarry/Its_All_Here.zip
groeten,
Paul
CRT - You like it now, you'll learn to love it later
Visit Cinepaulis
Classe SSP-30 | Parasound HCA 2205A| 4xB&W N805 + HTM2 | BagEnd Infrasub 18 | CEC TL-51 | BarcoGraphics 808 | Projecta scherm | Philips DVD 720P
#4
Ziet er inderdaad goed uit, maar toch wel blokkerig bij bewegingen en wat smearing. Kan aan mijn speler liggen.
MvrGr.
rijstfj
#5
Werkt nog steeds niet, in mediaplayer geen hardtec gevonden ???
No suitable decompressor found, wat dat ook mag wezen.
Het bestand (zip) gedownload zowel thuis als werk.
Maar geen van beide werken op de media player nieuwste versie.
Jammer.
M.vr.gr.
Frans
#6
Ga naar www.divx.com en download daar de codec en de player.
MvrGr.
rijstfj
#7
:D oke gedaan, en het werkt.
Begrijp er uit dat dit interessant is als je juist een projector heb om resultaat tezien, ik heb juist een PC ::)
Groeten
Frans
Flint
#8
Gaaf filmpje.
Ziet er erg scherp uit. Helaas loopt ie niet helemaal lekker, maar ik denk dat het aan de pc ligt.
Hopelijk kan ik deze zeer binnenkort op 720p projecteren, dat móet gewoon gaaf uitzien  :D
