Gratis Windows-software voor Topfield settings editor en file manager op PC
Started by Shorty, January 22, 2008, 11:33:43
Shorty
De Duitse Topfield-distributeur heeft een gratis te downloaden tooltje op z'n website gezet.  :-*
QuoteTop Set 2.0 is a comprehensive settings editor and file manager for your Topfield Receiver.
With Top Set 2.0 you can read the settings from your Topfield Receiver and edit them on your PC. You can sort the channel list, create new entries like frequencies or channels and you can also edit favorites or timers.
For all Topfield PVR models with a suitable USB interface, Top Set 2.0 provides a file manager. With it you can copy recordings from the harddisk of your Topfield Receiver to the PC and you can copy files to your Topfield Receiver.
Top Set 2.0 is an all-in-one tool for your Topfield Receiver and offers extensive possibilities to tune it from your PC.
Top Set 2.0 provides following features:
Up- and download of the settings
Editing of all entries (satellites, transponders, frequencies, channel list, favorites)
Creating and editing timers
Print function for all entries
Export of all entries to a text file
Import and export of timers
Up- and download of the firmware
A comprehensive search engine
Automatic search for duplicates within the channel list
Extensive possibilities to sort the settings
File manager for all Topfield PVR models with a suitable USB interface
System Requirements:
Operating Systems: Window 98/ME, Windows 2000, Windows XP, Windows Vista32
Settings Editor: USB 1.1, USB 2.0, RS232
File Manager: USB 1.1, USB 2.0
Supported Topfield Receivers (DVB-S, DVB-C, DVB-T)
Het programma is hier te downloaden.
VrGr,
Bart J.
Hanky Panky
Panic
En? Werkt het ook zo mooi en simpel als omschreven? Wil graag van mijn Comwell af en zoek iets dat qua onderhoud makkelijk bij te houden is. Met zo'n tooltje zou ik weleens voor een Topfield kunnen gaan.  8)
Thuis: [HTPC > M-Audio SuperDAC > Denon PMA-535R > Monitor Audio BR5 / Sennheiser HD-595]
Portable: [Cowon D2 > Grado SR-80 / MylarOne X3 / Head-Direct RE2]
Nadia Ali - Crash and Burn (Sultan and Ned Shepard remix)
Shorty
QuoteEn? Werkt het ook zo mooi en simpel als omschreven?
Ja, ben ik ook benieuwd naar. Mijn Topfield 7700 zit na ruim een jaar nog steeds werkeloos in z'n doos te wachten tot de verbouwing van m'n vakantiehuis klaar is.... :P
VrGr,
Bart J.
HarmanKarton!
Helaas geen mogelijkheid om de 4000PVR te uploaden. Wel Jammer..
Groet
ECH
Ik kan je vertellen dat dit programmaatje perfect werkt, althans bij mij op de TF7700HSCI.
Je heb het zo door en het scheelt werkelijk heel erg veel tijd.
Het is gewoon een kwestie van het bekende "knippen en plakken".
Je kunt ook frequenties toevoegen, hoef je de sat. receiver niet te laten zoeken......
Grtz.
