terminator 2 extreme edition in high def!
Started by Bjorn, April 11, 2003, 20:52:13
Bjorn
T2: Extreme Edition
Final specs confirm the HD Windows Media version on the disc.
April 09, 2003 - Today the final specs for Artisan's upcoming re-re-release of Terminator 2: Judgment Day arrived and they confirmed a long-running rumor that the DVD would include a high-definition version of the film using a Microsoft Windows Media Player 9 file.
This may sound strange to you, but it is actually quite cool. Microsoft has developed a low-bitrate HD compression codec that is just now being experimented with on some Artisan DVDs. It allows high-def quality video on the same amount of disc space as a regular single-layer DVD. Artisan's Standing in the Shadows of Motown includes a Windows Media Player 9 version of the film in high-def on disc two. Not only does it look incredible; it only takes up about 3 gigs on the disc.
Naturally, you'll need some horsepower to correctly run these files on your PC. You'll need at least a 1.8ghz Pentium 4 with a nice chunk of RAM and a 5.1 compatible soundcard to take advantage of the audio. However, if you have all of that the high-def version looks a lot nicer than running the regular DVD on your PC.
Here are the complete, and final, specs for the upcoming T2: Extreme Edition
2.35:1 anamorphic widescreen transfer digitally mastered from a brand-new 1080p, 24sf high-definition digital telecine transfer.
Dolby Digital 5.1 EX audio.
Dolby headphone audio track
All-new audio commentary by James Cameron and co-screenwriter William Wisher.
Extreme interactive mode with graphic commentary and behind-the-scenes footage
16 minutes of additional scenes.
"No Feat But What We Make": an all-new documentary.
"T2: On the Set" retrospective montage
"T2: High Definition": the complete theatrical version of the film in Microsoft Windows Media 9 series, playable in high resolution and 5.1 sound directly from your PC
Infiltration Unit Simulator and T2 FX Studio: morph your imported images into a T-1000 or T-800 Terminator
Skynet Combat Chassis Designer: Construct and field-test your own ultimate fighting machine and track your progress online
THX optimizer
Metal collectible sculpture embossed package
Ik ben erg benieuwd naar die wmp9 versie van terminator 2! Ik was erg onder de indruk van de hd-tv wmp9 samples die op avsforum te vinden waren, dit kan alleen maar mooier worden..:D
Robbo
Ik ben ook benieuwd.  Maar omdaar een nieuwe versie van T2 voor te kopen.  Ik dacht het niet.
Die WM9 krijg ik wel van iemand.  Als het WM9 verhaal goed werkt, denk ik dat dit het begin van een hele reeks WM9 rips.
Tijd voor een DVD brander  ;D
(blij dat ie z'n HTPC toch gehouden heeft)
Lone Ranger
Quote from: Robbo on April 15, 2003, 08:32:53
Ben eigenlijk ook wel benieuwd.
Zal ook geen nieuwe kopen.
Gr.Fred.
