Rel Quake
Started by ACQUA, March 11, 2007, 11:39:45
ACQUA
#50
deze vond ik ook wel mooi: voor 150E
SUB 250
The SUB 250 is equipped with an 8in woofer unit housed in the unique slotted port cabinet. It also features a powerful BASH® amplifier capable of delivering 250W of peak power. Relative to its size and price, the SUB 250 delivers outstanding performance and is capable of producing bass frequencies down to 30 Hz.
The SUB 250 has a very flat frequency response which allows it to play bass notes in a very convincing way compared to many conventional bass-reflex subwoofers. That response extends all the way up to 150Hz. That's important because the output from many subwoofers falls off dramatically at above 100Hz (or even lower with some models) making them very hard to integrate with smaller speakers.
Specifications:
system Slotted Port Cabinet
Woofer (inch/mm) 8 / 203
Impedance (Ohm) 22k
Weight (kg/lb) 13 / 28.7
Dimensions (HxWxD/mm/in) 325x267x469 / 12.8x10.5x18.5
limiter limiter
Amplifier Rated Output 250
Frequency Range 30-150
cut Off Frequency 40-150
phase Variable
http://www.jamo.com/Default.aspx?ID=5945&M=Shop&PID=17153&ProductID=17692
ACQUA
Waarschijnlijk ga ik toch voor deze Jamo gaan,de rel's gaan mijn neus voorbij qua budget alsook de velodyne's etc.
Jbl's zijn moeilijk 2de hands te verkrijgen. Als iemand nog tips heeft voor andere merken?
