Nieuwe (beta) firmware MB200 beschikbaar
Started by daniel.benjamins, February 15, 2007, 21:09:23
daniel.benjamins
"Beta firmware, version 1.3.6.12 with Internet Radio (SHOUTcast) support"
ChangeLog:
- added Internet Radio (SHOUTcast) feature for listening to many online radio station using the .pls file.
In order to play a radio station, HD MediaBox needs to be connected to the internet via a suitable router and to be configured correctly. Please make sure you have proper Internet connection in DHCP mode. If you use static IP on the Mediabox, please make sure to enter the correct Gateway and DNS config in Setup->IP->Static.
The information HD MediaBox needs in order to access a radio station is contained within the .psl file which can be downloaded from the shoutcast.com website. Simply right-click on the TUNE-IN button and "Save Link As" (Firefox) or "Save Target As" (Internet Explorer). It is easiest to rename the .pls file to match the name of the radio station. This file can then be selected to play within HD MediaBox in the same way as any other audio file.
- improved FTP stability
- improved NFS stability
- fixed NFS path longer than 12 characters bootup crash issue
http://www.pixelmagicforum.com/forum/showthread.php?t=2432
Quick Reply
Warning: this topic has not been posted in for at least 60 days.
Unless you're sure you want to reply, please consider starting a new topic.
Name:
Email:
Verification:
Please leave this box empty:
Type the letters shown in the picture
Listen to the letters / Request another image
Type the letters shown in the picture:
Onze vlag is blauw, wit en:
Wat is de hoofdstad van Nederland:
Shortcuts: ALT+S post or ALT+P preview
