Yippie
Author Topic: From tomorrow Moome  (Read 24386 times)
Offline J.A.F._Doorhof
  • All your base are belong to us / JonDoe297
  • Owner
  • Forever Addicted
  • Trade Count: (+12)
  • Total likes: 3044
  • Gender: Male
  • Tja, je hebt van die dagen
    • J.A.F._Doorhof
From tomorrow Moome
« on: August 14, 2006, 17:05:36 »
Everyone knows by now the moome box, from HDMI/DVI to RGBHV conversion in a top quality box.
Now for 1 or 2 days he will answer your questions, but PLEASE keep them in English.
Have fun here Moome.
Greetings,
Offline jowi
  • HT forum donateur
  • Trade Count: (+4)
  • Total likes: 3
  • I'll be back :)
Re: From tomorrow Moome
« Reply #1 on: August 14, 2006, 18:37:53 »
Hi Moome
I've got your external dvi-box, and it works fine on my Barco 808, thanks for that. But i'm curious, why are the markings on some of the IC's removed?
Offline BarcoCRT
  • Trade (+31415)
  • HT forum legend group
  • Trade Count: (+4)
  • Total likes: 0
  • Gender: Male
  • Trade (-31415)
« Reply #2 on: August 14, 2006, 22:29:39 »
Hi Moome,
How about a special version with BNC connectors to make a proper connection between the Moome-box and a CRT-projector. Using short BNC cables will give the best possible connection.
Another good option would be additional H-phase control on the moome box.
« Last Edit: August 5, 2007, 01:32:42 by BarcoCRT »
2 * Barco Cine 9 | Da-Lite tab-tensioned 3m | Crystalio II | Meridian 568.2MM | Meridian HD621 | Chord SPM 2000 | Pioneer HLD-X9 | PS3
Pioneer LX5090 | Dune BD Prime 3.0
Offline jaco
  • HT forum donateur
  • Trade Count: (+25)
  • Total likes: 151
  • Gender: Male
« Reply #3 on: August 14, 2006, 22:56:13 »
Moome,
Thanks for making this possible.
I have found 1 issue with the box thus far. The VGA connector can not be tightend with the little bolts. They are not centered to the nuts in the HD-15 chassis plug it seems. The VGA connector i want to use fastens pretty good withouth it, so no issue. I have to try an other VGA conenctors to see if that is the problem.
Offline jantje112
  • HT forum donateur
  • Trade Count: (+5)
  • Total likes: 64
  • I love the HTforum
« Reply #4 on: August 16, 2006, 12:57:05 »
When does Moome arrive?
  • Owner
  • Forever Addicted
  • Total likes: 3044
  • Gender: Male
    • J.A.F._Doorhof
« Reply #5 on: August 16, 2006, 13:16:56 »
I have mailed him today to check in, he had some problems with the dutch forum structure but now it's in English so I guess/hope he will check in soon.
Offline moome
« Reply #6 on: August 16, 2006, 15:36:26 »
Hi Moome
they are some important IC need protect!
Offline moome
« Reply #7 on: August 16, 2006, 15:38:09 »
Hi Moome,
Reinier
the H-PHASE will be harder to implement, but the BNC version is under construction. about after october, and can RGB or YUV output
Offline moome
« Reply #8 on: August 16, 2006, 15:39:04 »
Moome,
i will have the VGA output box face out, and replace by BNC version! thanks
Offline Stress!!!!!
  • HT forum donateur
  • senior member
  • Trade Count: (+4)
  • Total likes: 0
  • Gender: Male
  • Zwarter dan zwart is er niet... Of toch wel?
    • Bouw van "the Underworld"
« Reply #9 on: August 16, 2006, 15:58:20 »
Moome,
when I want to purchase a moome box for my Barco BG808 where can I order one?
Denon AVR-4311 - JVC DLA-X3 - Oppo BDR-93EU
Offline bmateijsen
« Reply #10 on: August 16, 2006, 16:00:30 »
I believe ITC still have a couple ;)
Moome,
Offline jaco
  • HT forum donateur
  • Total likes: 151
  • Gender: Male
« Reply #11 on: August 16, 2006, 16:13:28 »
Moome, thank you for the reply. Normally a VGA connector would work, but with my box the vga connector cannot be fastened as the bolts seem not tp align with the center of the chassis nuts. As written above, i will try 1 or 2 other VGA connectors. The one om my VGA-5BNC cable might be wrong too.
But a 5 BNC output version would be welcome indeed. That seems a better physical connection, and short cables are easy to make.
  • Owner
  • Forever Addicted
  • Total likes: 3044
  • Gender: Male
    • J.A.F._Doorhof
« Reply #12 on: August 16, 2006, 17:02:31 »
ITC will support the moome units in the Netherlands indeed.
Offline Arno P
  • HT forum donateur
  • Trade Count: (+5)
  • Total likes: 8
  • Gender: Male
  • "Obviously you're not a golfer"
« Reply #13 on: August 16, 2006, 18:57:00 »
THAT would be nice....my card is not working...yet  ;)
  • Owner
  • Forever Addicted
  • Total likes: 3044
  • Gender: Male
    • J.A.F._Doorhof
« Reply #14 on: August 16, 2006, 19:00:47 »
Well, you did not buy directly from us so..... :D
That's why you pay a little bit extra to get support and we take the risc of sending back to Moome if something is not working.
If you buy direct you will have to get direct support I'm afraid, but we talked in another thread about this in length :D
Offline Arno P
  • HT forum donateur
  • Trade Count: (+5)
  • Total likes: 8
  • Gender: Male
« Reply #15 on: August 16, 2006, 19:02:40 »
Ok point taken (but I ordered before you were on track  :-\)...anyhow...Moome also gives great support...so don't hesitate to order directly ( >:D ;D ;))
  • Owner
  • Forever Addicted
  • Total likes: 3044
  • Gender: Male
    • J.A.F._Doorhof
« Reply #16 on: August 16, 2006, 19:04:35 »
I know Moome gives perfect support, but that's a different story :D
It's the simple reason why a distrubitor has to charge a little bit extra for DOA's etc. but let's continue for Moome :D
« Last Edit: August 16, 2006, 19:05:14 by J.A.F._Doorhof »
Offline jaco
  • HT forum donateur
  • Total likes: 151
  • Gender: Male
« Reply #17 on: August 17, 2006, 08:55:44 »
After testing it appears to be that my custom made VGA-5BNC cable is not good. An other VGA connector can be tightened without any problems.
Offline konniekip
  • full member
  • Trade Count: (0)
  • Total likes: 0
« Reply #18 on: August 22, 2006, 19:26:13 »
Hi moome, I will order one moome-box by that time.  :)
Offline Raphie
  • Forever Addicted
  • Trade Count: (+26)
  • Total likes: 1897
  • Gender: Male
  • Been there, Done that...
« Reply #19 on: August 22, 2006, 19:33:43 »
Moome what about a box for the other way around? (i.e. from Component or RGB to DVI?) with the next generation panels there will be a shortage of legacy inputs and plenty of digital inputs, i wouldn't mind a nice box to convert from component to DVI (or HDMI video, or even better spdif IN and merged HDMI audio/video support)
