regiovrij maken
Started by wilco73, June 14, 2006, 23:03:18
wilco73
Weet iemand hoe je de Samsung dvd-hd 860 regiovrij kan maken?
Jinsu
Hoi,
QuoteThis is the code posted by "NP" for HD850 and works fine for a region 2 HD860 (thanks NP!)
This works with the Samsung remote supplied with the DVD player.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
Gebruik op eigen risico ;) .
MvGr,
Jens
