Auralex Monitor Isolation Pads
Started by Starred, May 9, 2006, 18:25:35
Starred
QuoteIf you've got no choice but to install your speakers on top of an entertainment center or a poorly inert stand or shelf, this is the "must have" product to decouple your speakers and eliminate resultant sound colorations caused by nasty resonances.  The variable pitch capability of these isolator pads is very useful for speaker installations that aren't at or near ear level.  The only minor gripe I had was that the MoPADs themselves are about 1.25" in height towards the front of the speaker, which will of course raise an already elevated speaker even higher. Overall, this is a small price to pay for sound isolation and properly pitching your speakers to the listening position.
While we still have compelling world issues to deal with, at least we can rest safely knowing there are companies making product to better the sound of our systems.  The Auralex MoPADs isolation devices are worth their price of admission and are highly recommended!
http://www.audioholics.com/productreviews/avhardware/AuralexMoPADsp1.php
ddejonge
Haaaa bedankt, eigenlijk precies wat zoek!
Momenteel worden mijn centerspeakers ondersteunt door spikes en vibrapod-achtige schijven. Het ziet er een beetje rommelig uit.
Ik ga ze bestellen bij de nederlandse importeur, voor die prijs kan een mens nog eens iets uitproberen  8)
THX,
Dennis
Stereo:- HTPC + Roon - Mytek Brooklyn+ DAC/Pre- NuForce R9V3SE - Nordost Valkyrja
           - Wilson Audio Sophia I
HT      :- OPPO 93 - TAG McLaren AV32R bp192 - JVC DLA-X5900 - 3x JOB 150
           - Wilson Audio CUB II surround
           - Wilson Audio Watch center
Stroom:- Aparte audiogroep - Electra Glide Ultra Kahn II kabels - HiFi tuning zekeringen
Werken ook prima om kleinere subwoofers mee te ontkoppelen. Wij passen ze regelmatig ook toe onder Velodyne SPL subs, maar ook kleinere Velodyne DD subwoofers. Overigens zijn wij ook Auralex dealer ;)
ddejonge
Heb ik een keer de kans om bij een sponsor te bestellen... zit ik weer te slapen... bestel ik bij een importeur...  :o
Goeie zet Dennis, ga zo door... ( :-* kusje voor mezelf als troost)
Bjorn, als je ook een kusje wil... ;D
ddejonge
Nou hij gaat weer lekker... Net gebeld door de importeur dat DHL het pakketje niet kan afleveren omdat ik 2x KIB (KIP) was. Dat ik niet aanwezig was kan kloppen... een mens moet ook werken...  ::) Een briefje hebben ze echter niet achtergelaten, lekker handig  >:D
Volgens de importeur gebeurt het wel vaker. Ze kunnen het adres dan moeilijk vinden en hebben dan zoiets van "laterrrrrrr"  >:(
Wel top dat de importeur even gebeld heeft!!!
(dit wilde ik effe kwijt)
genedefect
Mijn gramma was toch anders binnen een paar dagen bezorgd zonder probs.
Hoop dat je iig snel van je auralex spul kan genieten, ik vind t aardig spul  ;D
SAMSUNG 42"
TEAC tuner + SAMSUNG tuner
HARMAN/KARDON AVR130 + HK675 + HD755 + HD970 + DVD22
CANTON LE190 + JBL SCS 200.5 + REL Strata Auralex Soundcare Vivanco Van Den Hull Qed Black Rhodium
ddejonge
Tssssssssssssss pffffffffffffff  >:( DHL krijgt het niet voor elkaar... Ze rijden vast in een parallel universum rond... >:D
Maar... service, service,.. Audiopro komt ze nu ZELF brengen! APPLAUS!
Kan ik eindelijk mijn centers ontkoppelen.
Petje af voor deze zaak: de warme douche komt eraan!
Dennis
ddejonge
De monitorpads zijn netjes afgeleverd door een Audiopro medewerker. Goede service!
Ik gebruik de monitorpads nu om mijn twee Ti1000 centers te ontkoppelen van het audiorack. De pads zien er strak uit en vervormen verbazingwekkend weinig onder de druk van de zware Ti's. Je kunt de pads zo samenstellen dat je speakers onder een (beperkte) hoek naar boven of beneden wijzen. Het geheel ziet er een stuk beter uit dan mijn eigen creatie van spikes en vibrapods  :D
Het resultaat mag er zijn, zeker gezien de prijs! Er zit meer punch in het laag en het geluid komt makkelijker los van de speakers. Het luistert ook een stuk relaxter.
Aanrader!
Dennis
DA BoSS
Quote from: ddejonge on June  5, 2006, 10:40:00
Aanrader!
Dennis
Gefeliciteerd!
Hoeveel pads per center gebruik je? (2?)
En hoe ziet dat er nou in de praktijk ui? (foto zou super zijn)
En kan jij inschatten of je met die pads ook goede resultaten kan halen met frontspeakers?
mvg,
Ben ook wel benieuwd naar een fototje ervan  :)
ddejonge
#10
Ik vind het lastig om te zeggen of je fronts er ook van profiteren. Als je fronts op een houten vloer of laminaat staan zou ik het zeker proberen, zeker gezien de kosten.
Voor de twee centers gebruik ik 3 van de 4 pads. Op de foto is niet te zien dat de centers onder een hoek omhoog gericht staan.
Haaa een foto, nou dat wordt er dan een gemaakt met mijn SE P900... niet erg scherp dus!  :-\
DA BoSS
