Yippie
Author Topic: Test speakerkabels  (Read 1389 times)
Offline Starred
  • Thanks: Gave 41, Got 283
  • Trade Count: (+2)
  • Total likes: 61
  • I no
Test speakerkabels
« on: March 29, 2006, 00:14:29 »
http://www.avreview.co.uk/news/article/mps/UAN/632/v/3/
Quote
Group test verdict
The cables in this group are all extremely good. At these sort of prices they should be of course but the world of wire is not immune to over pricing. If your budget is tight then the QED is an attractive and entertaining option, its lively balance will suit budget and midrange systems well.
The Kimber is very strong for the money and probably represents the best value in the group. The KSL and Harmonic Technology are both charmers, the former offering greater dynamic thrill power while the latter is super smooth.
The two top runners are quite different, Chord Co's Signature is precise and demonstrative while Supra's Sword is revealing and refined. Which you prefer though will depend on your loudspeakers and your taste - don't be shy about trying them out at a decent dealer before you buy.
