Panasonic TH65PV500 Plasma Screen
Started by Marcel_T., November 2, 2005, 13:03:06
Marcel_T.
Bron
After the lukewarm reception we gave to the Panasonic frames for plasma screens yesterday, we are pleased to bring you some much more positive Panasonic news. The company has expanded it's popular Viera range with the addition of the TH65PV500. The massive screen comes in at 65in and contains a wealth of features that should fulfil any number of demands a user may put upon it.
As well as the striking Viera design ethic the TH65PV500 is fully HD compatible with both the main formats, 1080i and 720p, being supported. The screen also has a Freeview tuner built-in and a resolution of 1366 x 768. However, possibly the most interesting feature is the inclusion of an SD card slot. This can be used for viewing photos but also for recording Mpeg-4 directly from the screen for use in a personal player. This is not only typical of the fusing together of technologies we are seeing more and more, but also cements Panasonic's belief in the market for personal video players.
Strangely enough this television set does not yet appear on the Panasonic website, but check back because it'll be added soon.
Vincent
Hmmm dit zou toch het toestel moeten worden met de HD resolutie ??
Grtz
Vincent
PaulB.
Hi,
Staat al een tijdje hier op de site van Panasonic.
MvrGr. Paul
You Worry, You Die. You Don't Worry, You Die. So Don't Worry!
Marcel_T.
Prijs inclusief BTW: € 11.499,- .... das nou jammer.
Maar wel: "Plasma tv wordt geleverd inclusief plaatsingsvoet en afneembare speakers."  als kleine pleister op de wonde.
EdwinB
Quote from: Marcel_T. on November  2, 2005, 15:52:31
Maar al wel goedkoper dan een 50" drie geleden kostte, dus gewoon even geduld hebben...  ;D
papaleo
Quote from: Vincent on November  2, 2005, 14:23:58
Grtz
Vincent
Nee,dat is de TH-65PX500 met zijn "kleinere" broertje de TH-50PX500.
Hellbeast
Koop maar meteen een nieuw huis erbij i.v.m. de 7 meter aanbevolen kijkafstand!  ;D
Is er iets mis met de codec of zie je er echt zo rot uit?
frenkelh
Quote from: Hellbeast on November  5, 2005, 13:10:46
7 meter is wel heel groot
Dat is ruim 4 keer het beelddiagonaal
Ik zit 9 feet (2.6 meter) van mijn 43" plasma, en als ik zo verschillende buitenlandes fora,s doorlees is dit niet abnormaal.
Sterker nog, Ik zou niet eens moeite hebben met een 50" op deze aftand.
Fabian1
Quote from: frenkelh on November  5, 2005, 14:07:37
DAMN!!!!!!!!!  :o
Vincent
Hi
Minimale kijkafstand voor een 50" bedraagt ongeveer 3m (maar das ook afhankelijk van de inrichting
van de kamer) Persoonlijk zeg ik 3 m minimaal.
Grtz
Vincent
Vinboy
Voor een breedbeeld = 3,5x de beelddiagonaal de ideale kijkafstand wat ik hoorde bij Philips ooit.Het klassieke 4:3 is 5x de beelddiagonaal.
Voor dit toestel is dat dus 4,5 meter de ideale kijkafstand!!
Wimpie007
er staat er volgens mij zo eentje in de MediaMarkt van Antwerpen (België), maar daar vertrekt ie pas voor 15 000€ :o
CinéSas:ThemeScene H56A, Marantz SR4600, DIY - Profigold - Lapp kabels, Samsung DVD, HTPC, Wharfedale Diamond 9.1 surround,...DVD collectie
Stereo: Sony ES EV, Classé VV, Marantz CD5000, PC, Wharfedale Pacific Evolution 10,...
frenkelh
Quote from: wimpie007 on November 15, 2005, 13:30:10
En dat voor een toestel met een adviesprijs van € 11.499,-
En "Maar goed dat we vergelijken" is hun motto  ::)
Marcel_T.
In MM Groningen staat een 65" van Sony. Die mag voor 'slechts' € 18.999 weg.
