Probleem met Pioneer DVD-recorders/rewriters!!
Started by CineBarkoos, September 18, 2002, 17:28:01
CineBarkoos
Waarschuwing!
Pioneer heeft een probleem met hun DVD-R/RW spelers bekend gemaakt. Een citaat uit hun persbericht:
" The DVD Forum has established new standards for high-speed recordable discs (4X for DVD-R and 2X for DVD-RW). Various media manufacturers have begun production of these discs that will soon be available in the marketplace. The source of the problem is a firmware "bug" in certain Pioneer DVD-R/RW recorders and drives, and not with the high-speed media itself. As a result, use of the new high-speed discs for recording on these particular Pioneer products may cause damage to both the loaded disc and to the drive/recorder. The following drives and recorders may be affected:
 * Pioneer DVR-7000 DVD recorder
 * Pioneer PRV-9000 Professional DVD recorder
 * Pioneer DVR-A03 computer drive
 * Pioneer DVR-103 computer drive
 * Pioneer DVR-A04 computer drive
 * Pioneer DVR-104 computer drive
In addition to the above models, certain OEM computer systems containing Pioneer-manufactured DVD-R/RW drives are affected. "
Voor meer info klik hier.
Samengevat is het advies: Update je drive zo snel mogelijk met de nieuwste firmware voordat je de nieuwe 4x R of 2x RW discs gaat gebruiken, aangezien deze je drive (en de disc) binnen een minuut of 5 vernielen.
Succes!
Gr.
Koos
CineBarkoos went digital FullHD! New -> Epson TW2000
Bezoek CineBarkoos!
Mijn Triumph Spitfire!
