Je weet dat de wereld ten onder gaat als ....
Started by Erik, May 24, 2005, 19:15:05
Erik
#50
Yoshua: ik kan het cpu niet beter vetrellen dan jij net hebt gedaan, ben het dan ook helemaal met jou eens. Voor de rest laat ik het hierbij want het wordt toch een wellis/nietes spelletje ;D
En dat soort discuusies voer ik liever mondeling onder het genot van een pilsje ;D
- Winston Churchill
Erik
Nog meer leuk leesvoer.
" I'm going to keep this brief, so please write me with the questions you have and any tests you want run on one of the dev kits. I will have one of my own next week as well.
First, the thing is fast. Native apps readily beat a single 2.7 G5, and sometimes beat duals. Really.
(I asked about real-world apps - if any were already available in native code-Mike)
All the iLife apps other than iTunes, plus all the other apps that come with the OS are already universal binaries....
They are using a Pentium 4 660. This is a 3.6 GHz chip. It supports 64 bit extensions, but Apple does not support that *yet*. The 660 is a single core processor. However, the engineers said that this chip would not be used in a shipping product and that we need to look at Intel's roadmap for that time to see what Apple will ship.
It uses DDR-2 RAM at 533 MHz. SATA-2. It is using Intel GMA 900 integrated graphics and it supports Quartz Extreme. The Intel 900 doesn't compare favorably to any shipping card from ATi or nVidia. The Apple engineers says they dev kit will work with regular PC graphics cards, but that you need a driver. Apple does not write ANY graphics drivers. They just submit bug reports to ATi/nVidia. So, when we asked where to get drivers for better cards the engineers said "The ATI guys are here." He's right, they've been in the compatibility lab several times.
It has FireWire 400, but not 800. USB 2 as well. USB 2 booting is supported, FireWire booting is not. NetBoot works.
The machines do not have Open Firmware. They use a Phoenix BIOS. That;s right, a Mac with a BIOS.
(I asked if the Bios had any tweaks like Memory Timing which is common for many PC motherboards, although Intel OEM motherboards don't usually have any end user tweaks like that.-Mike)
They won't tell us how to get in the BIOS. I'm sure we can figure it out when out dev kits arrive.
They run Windows fine. All the chipset is standard Intel stuff, so you can download drivers and run XP on the box.
Rosetta is amazing. (see earlier post on limitations of the Rosetta emulator - it's a G3 emulator basically - will not run Altivec code, etc. and performance isn't going to be as good as native code, but most Mac apps will run on a G3.-Mike) The tests I've run, both app tests and benchmarks, peg it at between a dual 800 MHz G4 and and a dual 2 G5 depending on what you are doing.
(I mentioned to him the limitations of Rosetta (posted below)-Mike)
It's true Rosetta does not support Altivec, but most apps run on a G3, right? Rosetta tells PPC apps that it is a G3. Apps should fall back to their G3 code tree. Everyone I tested did.
The UI tests in Xbench exceed a dual 2.7 by a large margin. (other specific tests are much lower than a G5 per Xbench site results.-Mike)
I've been talking to and watching a lot of devs. There are a lot of apps from big names running in the Compatibility lab already. Some people face more pain, sure, but Jobs wasn't kidding when he said that this transition would be less painful than OS 9 to OS X or 68K to PPC.
Game devs seem optimistic. They see porting Windows/x86 to Mac/x86 as much easier. They look forward to the day they don't have to support PPC.
I was talking to a (game Developer) that said about 1/3 of the process is handling endian issues, the rest is Win32/DirectX. For the next 3-5 years, their job will be harder since they have to port to two processor architectures and most bugs *are* endian related and that they will have a hard time making the PPC versions run as well as the x86 versions.
This transition is not about current P4 vs G5. It is about the future directions of the processor families. Intel is committed to desktop/notebook and server in a big way. Freescale/IBM are chasing the embedded market and console market. Apple would have been in a lurch in 2 years.
Also, all the cell people and the AMD people need to be quiet. Apple evaluated both. AMD has the same, if not worse, supply problems as IBM. Their roadmap is fine, but the production capacity is not.
The tested Cell as well. That processor is NOT intended for PC applications. (it was designed for game systems, not as a general use CPU) The lack of out of order execution and ILP control logic creates very poor performance with existing software. Having developers rewrite for cell would have been MUCH more work than reworking for Intel. And that's what this is, you rework your codebase in ALL cases, not rewrite it
- Winston Churchill
vinnie411
je op een ochtend op je bookmark "htforum" klikt en dan de melding krijgt van "pagina niet gevonden"!!!
Dan weet je het zeker, eerst het forum daarna de rest van de wereld.
Zelfbouw Buizen eindversterker met kt88 JJ 4x
Zelfbouw Buizen Phone-pre o.b.v. Phonodude met JJ buizen
Zelfbouw Passive Volume/source met stapped attenuator Takman weerstanden.
Denon dcd725 SRM Tech arezzo ultra platenspeler.
)p(
Jobs refereerde in de keynote speech ook aan het feit dat er nog steeds geen g5 powerbook verkrijgbaar is. Ik zou mij niet verbazen, gezien het alsmaar groeiende marktaandeel van laptops, dat Intels inspanningen met de pentium-m een rol heeft gespeeld bij de keuze voor intel. G4 powerbooks dreigen onderhand een lachertje te worden als het om performance gaat in vergelijking met de nieuwste pentium-m laptops.
peter
klaas123
Quote from: vpv on June  8, 2005, 23:31:28
Zeer zeker, dat is wat ik bedoel met Intel's "totaal pakket".
Optoma ThemeScene H30
Projecta matwit scherm
HTPC (Windows XP + Meedio)
Dreambox DM 7000-S / Triax-88 draaibaar Carver voor- en eindversterker Rogers transmissielijnen (gebaseerd op Kef B139) geen subwoofer nodig dus :)
