Plasma Break-In?
Gestart door Oracle, mei 11, 2005, 15:25:37
Oracle
Al eens van gehoord?
Citeer
Like a fine new automobile, the performance of a plasma TV can be optimized by allowing a break-in period. By properly following these simple break-in instructions, you should be rewarded with long-term enjoyment of your plasma TV.
Plasma phosphors are most susceptible to image retention in the first hundred hours of use. The panel becomes considerably less sensitive to burn-in after this period.
Very often, televisions, including plasma, are shipped from the factory with the contrast control at a high setting to provide a bright picture under typical dealer showroom lighting conditions. In your home, the room light levels are usually one half or less than that in retail showrooms. The contrast control may need to be lowered in your home for comfortable contrast levels that donot induce eye strain.
When the plasma is initially installed, videophiles say it is best to do the following:
·       Make sure the display is in a viewing mode (aspect ratio) that completely fills the screen
        (there are often three or more settings from which to
·       choose). The panel is shipped in this condition, in what is called the "Just" mode.
·       Turn down the picture control (contrast) to 50% or less.
·       Briefly engage the 4:3 mode to confirm the side bars are set to mid-gray
        (there is usually an adjustment in the Set Up menu that takes the
        sidebars from black to gray) to minimize the chance of burn-in.
·       Return the set to a "full screen" (Just, Zoom, Full) position during the
·       During the first hundred hours of use it is best not to view the same
        channel for extended periods. This should prevent channel logos and
        other fixed images found on some channels from being retained.
·       Avoid any static images (video games, computer images, DVD title
        screens, etc.) during the hundred-hour break-in.
After the hundred-hour break-in period, during the next nine-hundred hours:
·       Continue to retain the picture setting at 50% or less.
·       Limit the use of 4:3 aspect ratio mode (traditional picture size that does
        not fill the entire screen) to 15% of viewing time.
·       Limit the use of static images (computer, video games, etc.) to less than
       10% of viewing time.
After one-thousand viewing hours, panels are much less likely to experience image burn-in.
Bron: panasonic.com
Zit hier wat in, of is dit marketing?
Mark
Bengbeng
Het schijnt dat de handleiding van Panasonic (en andere merken), welke bij een plasma zelf zit, niets bevat over
dit run-in fenomeen en hoe dit te doen. Dus mensen zonder internet of die toevallig dat artikel niet hebben gelezen
kunnen het niet weten. Zó belangrijk vinden fabrikanten het dus ook weer niet.  ;)
Aan de andere kant lijkt het me geen kwaad kunnen om de eerste
paar dagen het rustig aan te doen met de contrast setting, dus even niet op de schijnwerper stand
waar winkels 'm vaak op hebben staan.   :D
Pioneer Kuro KRP-500M & 4280XA | Dreambox 8000 | UPC HDTV-DVR mediabox
Johnny_Bravo
Mij is hetzelfde verhaal verteld....
En terecht.
Een vriend heeft een Pioneer plasma die na 180 uur al permanent was ingebrand.
kippekop
en inbranden zit niet in de garantie  :-X
Ik vind het inderdaad raar dat dit soort berichten niet in de handleiding staan, Jan van Vliet op de hoek zal dit soort dingen minder snel weten dan mensen hier op het forum, ook al omdat bijvoorbeeld de plasma's standaard op dynamic staan om op te vallen in showrooms.
TV: Sony kdl-40d3500
Speakers: Focal Dome
Jaguar
Fabrikanten vertellen nu eenmaal niet graag negatieve dingen over hun producten. Daarom staat ook niet in de handleiding dat je in het begin voorzichtig moet zijn met inbranden.
Heb zelf ook een Pioneer. Deze zijn door hun technische contructie in het begin extra gevoelig voor inbranden. Deze toestellen worden gewoon erg heet. Had er na 4 dagen ook al last van. Heb die zender toen meerdere dagen gemeden en het is gelukkig nog helemaal weggegaan.
Na zo'n 200 uur is het wel veilig.
Wees gewaarschuwd. Draai het contrast terug en niet langer dan 1 uur een zender met logo aanzetten. 3 keer 1 uur is 3 uur ;-)
