TKA: McIntosh D1100: high-end reference level DAC and preamplifier
Started by Kurt, February 18, 2024, 11:30:53
Kurt
TKA aangeboden wegens upgrade.
Levering: ophalen of brengen (Antwerpen)
Vraagprijs: 5000€
* ES9018 8-channel 32-bit DAC used in Quad Balanced mode with half of it dedicated to the left audio channel and the other half to the right channel
* 9 Inputs: 3 optical, 3 coaxial (2 RCA and 1 BNC), plus 1 each of MCT, AES/EBU and USB
* USB input accepts up to 32-bit/384kHz signals and supports DSD64, DSD128, DSD256, DXD 352.8kHz and DXD 384kHz playback
* All other inputs accept up to 24-bit/192kHz
* MCT input is McIntosh exclusive and allows the high resolution audio found on SACDs
* 3 sets of balanced and unbalanced stereo outputs connect the D1100 to your system. One set of outputs has fixed volume while the other 2 have variable volume; the variable outputs can also be switched on and off for additional user configurability
* Inputs can be renamed; its 4 data ports and 4 power control triggers are fully programmable
* IR and RS232 external control
* Headphone Crossfeed Director (HXD®)
* Remote included (never used)
* Original packing material and manuals
* Invoice available
* 1st owner
* non-smoking environment
* Roon certified
Info: https://www.mcintoshlabs.com/products/preamplifiers/D1100
