Zavfino The Fusion MK2 XLR interlink VERKOCHT
Started by metheny, May 2, 2023, 09:44:58
metheny
Zavfino The Fusion MK2 XLR interlink. Onbekend (?) maakt onbemind, maar dan heb je deze geweldige interlink nog niet gehoord. 1 meter lang en opgebouwd uit een combinatie van puur zilver draden en puur koperen draden.1 van de beste interlinks die ik heb gehad, en geloof me ik heb er heel veel gehad en gehoord in de afgelopen 50 jaar. Wegens overgang naar RCA.
Nieuwprijs rond de 400 euro
Vraagprijs 159 euro
The Fusion is the perfect synergy between Solid Pure Silver and PCOCC Single Crystal Copper. Fusion`s precise engineering gives it a sonic signature that is uniquely it`s own. Our goal was to build a cable that offers the best of both of worlds, OCC`s well rounded and robust bass matched with Pure Silver`s openness and tonal clarity. Not an easy task to achieve but after over a year of prototyping and modifying this cable`s construction we were able to hit the perfect balance of musicality and raw musical reproduction, always true to what the original artist intended.
Specificaties
Litz Construction
H-Wound™ Core
Solid Pure Silver Multi-Strand Core
Japanese PCOCC Single Crystal Copper Wires
Tight Pitch Twisted Pair Construction
Deep Cryo Treated.
Ultra Sonic-7™ Treatment
FEP Teflon Injection Extrusion
PTFE Teflon Insulating Wrap, 50% Overlap
Mylar Foil Shield + High Density Copper Braid
Anti-static PET /polyester weave sleeve
RohS Cerfified PVC jacket
5% Silver Solder on solder joints
XLR OCC copper pins, 24K Gold Plated
Martin Logan Ethos. NordOst Thor stroomfilter. GATO DIA-250S. Eversolo DMP-A8. Neotech Neet-1008 ethernet kabel. Cisco Meraki switch met upgrade
Oftewel vrijwel zeker Neotech of Furukawa - dit spul zit veel beter in elkaar dan menig Audioquest en andere dure merken...
