Dirac Live Bass Control Single Subwoofer licentie voor Arcam AV40?
Gestart door holco, november 24, 2022, 22:32:20
holco
Kan iemand mij uitleggen wat nu precies de Dirac Live Bass Control Single Subwoofer licentie brengt ten opzichte van de standaard AV40?
Vindt eerlijk gezegd de beschrijving die Dirac zelf geeft wel heel erg karig en vaag, en aangezien ik zaterdag een AV40 op ga halen kan ik vooralsnog ook niet inschatten in hoeverre je wat mist met de standaard AV40 met een enkele sub.
Features
Correction of areas with sound gaps (bass decline)
Smoother bass reproduction in the crossover area
Visual representation of the predicted bass performance (subwoofer and speaker summation)
Input channel target curve
Flexible subwoofer placement
Supports one subwoofer
NielsLu
Dit lees ik op het AVS forum
https://www.avsforum.com/threads/arcam-avr10-20-30-av40-pa240-410-720.3098290/post-62020893
Citeer
Citeerascasuba said:
I'm using Dirac alone with a single sub. I plan on getting a second sub in the next month or so and add DLBC for multiple subs at that time. Are you saying that the single sub license is a significant upgrade over the basic Dirac license?
I added the DLBC license when I had only one subwoofer, and the improvements were not night and day in the bass, but consistent at the crossovers (checked with REW: significantly more linear for all channels, with no dips or less dips in those regions). Also, I bought the multisub license directly, because I had already decided to buy a second sub in the future (and by doing so I spent less than buying the single sub license, adding the multisub one later).
With 2 (or more) subs, the improvements are night and day, even in the bass region. ;)
Ettore
Arcam AVR5  *  Arcam BDP100  *  Marantz CD 52  *  Apple TV 4K  *  Tannoy Revolution XT8F  *  Tannoy Revolution Signature DC6LCR (center)  *  Tannoy Arena (rears)  *  Tannoy Arena (Atmos height)  *  diy tv meubel / SVS SB 3000 Clone met SVS Sledge STA1000D amp
holco
Ik kwam deze post nog tegen.
"The internal bass management on the Arcam is disabled when the DLBC filter is active on the unit. The Arcam includes an individual processing chain for the DLBC which includes the Linkwitz-Riley filters, allpass filters, gains, and delays which is only active when the BLDC filter is active. For this chain to work properly the internal Bass Management on the Arcam must be disabled and all speakers will, therefore, be set to Large.
We will check with Arcam and see if we can display the real c/o values instead of displaying Large"
holco
Nog geen tijd gehad om het volledig uit te kijken, maar dit lijkt op een goede uitleg over wat Bass Control doet.
Dirac: Measurement Based Bass Management
https://youtu.be/JY44hxqiBoA
holco
Dutch2
Hoe bevalt de AV40, en waar heb je hem gehaald als ik mag vragen?
