MJ Acoustics Reference 1 MKIII Black Ash
Started by phmeijer, June 26, 2022, 12:26:37
phmeijer
MJ Acoustics Reference 1 MKIII Black Ash €200,=
Speaker and line level inputs with Gain Control Range 80dB plus Neutrik Speakon connectors, (High level 100k ohm) (10mtr Neutrik cable supplied) and balanced (XLR) connectors (Gold Plated) (Low level 10k ohm) and unbalanced RCA (phono) connectors (Gold Plated) (Low level 10k ohm)
2 x sophisticated crossover circuits - variable increments between 30Hz and 120Hz plus a "Straight-through" LFE Bypass filter switch with a phase control infinitely adjustable between 0º and 180º.
Specially designed cabinet structure, volume, and configuration made from inert 18mm and 30mm MDF.
270mm (10.5") Ultra Long-throw Aluminium Driver with heavy duty cast chassis magnet
2 x Digital Displays with power output meter and frequency setting
150 watt RMS, DC-coupled MOSFET Amplifier.
D.A.M.P. (Digitally Accurate MicroProcessor)
Comes complete with the MJ Acoustics - 10 metre high level lead, fitted with professional Nuetrik Speakon to solder ends.
Sub enclosure type: Inert 18 & 30mm MDF
Frequency Response at 3dB: 13 to 120Hz
Dimensions (HxWxD) in mm: 491x421x320
Integrated sub amplifier: 120 watts
Termination: Neutrik Gold Plated
Sub cross over frequency: Variable
LF Driver: 270mm long throw cast chassis
Digital Display: Twin Power level & Frequency
Nominal Impedance; 6 to 8 Ohm
Weight: 21kgs
Ralf67
Hele fijne subwoofer voor muziek.
Grote twijfel, ga er vandaag eens hard over nadenken  :D🤔
WAF vraagt of ik ze ga stapelen de subwoofers in de mancave  8)
Ralf67
Deze specs zijn van de mkiii
Die er nu bijstaan zijn van de mkI
Geloof me ik kan het weten
Tech Specs
- Double Magnet High Gauss Energized.
- 10" Driver with High Compliance Motor
- 50mm Voice Coil Ultra Pure Oxygen Free Copper Core
- Dual Layer Voice Coil Windings
- Single Powered Driver
- Port Tuned NON-Loaded (ID 102mm)
- Multi-Stage Audio Grade Power Supplies - Regulated
- Audio Grade Toroidal Transformers
- High Quality 24ct Gold Plated PCB Tracks
- Flexible FR4 PCB Material
- Audio Damped PCB Standoffs
- Vibration reduction measures for PCB Mechanical Mounting
- Reference Grade Component Matching
- Reference Grade Class Audiophile Design
- Gold Plated RCA Sockets
- Digital Display on Rear Panel
- Power Output Meter Rear Panel
- Multi-Channel Inputs
- Simultaneous Input use
- IR Remote Control enabled
- Remote Eye (for out of sight memory recall) Option
- Smart Remote Ennabled for 2 Way Communication
- Onboard IR Receiver on Rear Panel
- Speaker Level Connection - Speakon
- Stereo Line Level input L+R
- Line Level input LFE, LFE/CEN input
- Auto Display Dimmer
- D.A.M.P. 3rd Gen
- Twin X-Overs and Twin Gains
- User Memory Pre-sets x 4
- Last Setting Auto Save & Recall on Power Up.
- High Level Gain Adjustable
- Line Level Gain Adjustable
- Infinite Gain adjustment from -99 to 0db
- LFE Input with X-over adjustment 20 - 200Hz
- LFE ByPass (200Hz)
- Aditional X-over with adjustment 20 - 120Hz
- LFE Loop Out
- Infinite Phase Adjustment 0 - 180
- 12v Trigger On and Off
- Auto Power on/off Sensitivity adjustment
- Anti Thump Soft Start Power Up Circuit
- Inteligent Speaker Protection (CPU Monitored)
- High Grade Matched Linear MOSFET output Devices
- Discrete Instant High Current Power Amp Design
- ClassA/B Power Amplifier 250Watts RMS 500Watts Peak
- Frequency Response 10hz to 200Hz -3db in Room
- Dimensions (WHD): 500 x 455 x 320mm
- Weight: 26Kg
https://www.audioaffair.co.uk/mj-acoustics-reference-1-mk3-subwoofer
phmeijer
Dan had ik de verkeerde gevonden. Thanks!
Hij is inmiddels verkocht dus ik sluit het topic..
