Guru Audio Q10 monitor speakers wit €1250
Started by phmeijer, June 26, 2022, 10:14:52
phmeijer
Guru audio Q10 1 op elkaar afgestemd paar wit €1250,-
Guru Pro Audio introduceerde de Quality Manager 10 op de Heathrow Hifi Show in 2007.
Daarna volgden New York en Las Vegas. De speaker kreeg juichende recensies van zowel bezoekende audioliefhebbers als professionals. E?n recensent concludeerde na een luistersessie: "Dit is de eerste kleine monitor speaker die niet probeert te lijken op een grote, maar die werkelijk klinkt als een grote speaker met een geweldige bassound".
De opvolger Q10 is na de QM10 TWO weer een grote stap vooruit:
Originally designed for professional use, the aim for Q10 was to make a monitor that captures, or rather recreates the whole event taking place on a music recording (or any other source of sound), timbrally accurate, in time and in space. Achieving that isn't a matter of adding a lot of subjectively "positive things" a colour is a colour, even when it's a nice one, and we don't want to add colors. The Q10 bass driver helps producing rock solid bass down to 30Hz, and the key factor is the long and linear stroke, and even more so the incredible pressure factor, exceeding that of a typical 15" driver with a factor of more than three. Choice of membrane is essential to both midrange quality and lateral inter driver integration. The mineral fibre membrane of the Guru B59mf-driver assures a perfectly controlled behaviour in it?s entire working range, and it is actually also adding an essential part of the stereo system compensation above it?s nominal working range. Timbrally and dynamically accurate sound reproduction in time and space is all about adapting to the listening room properties and avoiding and / or compensating for the inherent flaws of the stereo system ? all done with respect to our hearing properties. Or in other words ? allowing for the natural musical colours in the recording to be let free.
The Specs:
Typical in-room response........................................30 Hz - 30 kHz
Sensitivity................................................................87dB (@2.83V,1m)
Nominal impedance................................................5 ohm
Crossover band......................................................2 - 7 kHz
Recommended amplifier power.............................20 W - 160 W
Enclosure type.......................................................Helmholtz resonator
Enclosure material.................................................MDF/Aluminium
Drivers...................................................................1x 20.5 mm soft dome tweeter, 1x102 mm mineral fibre cone
Dimensions...........................................................300 x 252 x 232 mm
Placement.............................................................Bookshelf or standmount
What's it good for?
Small to medium sized rooms The Q10 is designed to be used in small to medium sized rooms.
Nearfield monitoring?
The Guru Q10 is a perfect companion for nearfield monitoring in professional studios as well as home studios.
Full Register?
The Q10 do not discriminate any frequencies below 30Hz or above 30kHz. All frequencies are created equal!
Inclusief originele verpakking.
Ook eventueel een QM10 hoogglans wit als Center erbij te kopen (€500,-)
BuSpu
phmeijer
Quote from: BuSpu on June 26, 2022, 18:25:37
Met dank aan Google translatie  :clapping:
Wat erg, in mijn snelheid niet nagekeken. Maar even de tekst van mijn eigen site gepakt! 😎
BuSpu
phmeijer
twani
Ook zeer geschikt voor plaatsing vlak tegen de achterwand als ik het goed onthouden heb.
Zeer bijzonder speakertje.👍
...edit...
dre73
Quote from: twani on July 10, 2022, 20:15:16
Klopt!
En ook heel fraai. 8)
phmeijer
