CHK binding posts - speakerterminals - 3 sets
Started by PascalP, September 30, 2021, 13:40:29
PascalP
Ivm upgrade/overbodig 3 sets CHK terminals, uiteraard bruikbaar voor zowel speakers als versterkers.
Het betreft hier de 60A gold plated uitvoeringen, nieuwprijs ongeveer €30 per paar, nu 3 paar voor €30  :clapping:
This high end Binding Post is rated at 60 Amp and manufactured from gold plated brass with clear touchproof thermoplastic shroud. This product has a 4mm hole at top of captive knob for connection via 4mm banana plugs and generous 4.35mm diameter cross hole for bare wire connection or spade terminals .When using bare cable the unique "Clamp Down" feature ensures that when bare cable conductors are used to make a connection via the cross hole the conductors are not twisted or damaged unlike similar products currently on the market.
12.5mm diameter cutout required.
PascalP
