Yippie
Author Topic: Optoma CinemaX P2 4K projector review  (Read 2655 times)
Offline bartvv
  • eigenaar van KlankBart
  • HT forum donateur
  • full member
  • Trade Count: (0)
  • Total likes: 3
  • Gender: Male
  • Doe alles wat je doet met hart en ziel
    • KlankBart, distributeur van Thuisbioscoop apparatuur
« on: November 25, 2020, 14:30:42 »
Optoma CinemaX P2 4K projector review bij Techradar
Optoma drops the price, but keeps the good stuff
OUR VERDICT
The beautifully-designed Optoma CinemaX P2 is proof that a projector doesn’t have to dominate your living space if you want to super-size your images. Picture quality is polished, and the onboard sound system is a blast.
FOR
Stylish Ultra Short Throw design
Excellent onboard sound system
Looks great with both 4K and HD sources
AGAINST
Less bright than its predecessor
Doesn’t support HLG HDR over HDMI
Smart app choice limited
Buy it if...
You want cinema sized images, without the hassle
The P2 has a massive projection, but its ultra short-throw tech means you won't need a ceiling mount to make use of it.
You want a gaming-capable display
The P2 improves on the latency of its predecessor, making gaming a reasonable activity for this beamer – even if, at 50ms, it's not the best out there. Three HDMI inputs will support a handful of consoles too.
You want a do-it-all sound and vision entertainment hub
The CinemaX P2 packs in capable sound as well as a decent picture – and what more could you ask for in a home cinema projector?
https://www.techradar.com/uk/reviews/optoma-cinemax-p2-4k-projector
Distributeur van: Adeo projectieschermen, Barco residentieel, B&K, DVDO, Fortress bioscoopstoelen, Gefen, KanexPro, Optoma projectoren en schermen, OS Screen, Screen Excellence met geluiddoorlatend doek.
